Hello ,
I have a kerlink ifemtocell which points to my kerlink LNS account via OpenVPN. For testing purposes I would like to make the GW to point to a different server and thus I need to disable OpenVPN at startup.
I would appreciate it if somebody could give me some guidance on this topic.
If you use keros 4.3 (which you should!) you can use any LNS by changing the packet forwarder conf (see conf file path in /etc/default/lorafwd). If you want to disable openvpn you may do so by removing the init script in /etc/rcU.d and monit.
