How to contact the owner of a TTN gateway, bad position settings
i did some ttnmapping in the adriatic sea, a gateway is seeing me, but the gateway location is set to lat 10, lon 20, altitude -1 (which seems to be default values).
How can i contact the owner to inform him of the bad config and to get the real position of the gateway?
I just want to know how far my node was received.
that will be very difficult… maybe he/she doesn’t want you to know the location.
you know the gateway ID… maybe ask the owner of GW ID xxxx to contact you ?
Describe where you were and give GW ID so maybe they will contact you here :smiley:
