How to connect seeeduino board with cayenne dashboard
hello
i am having a problem with my seeeduino board , am trying tho send data to the cayenne dashboard but nothing it showing to the cayenne dashboard
  1. i did register my devices to the ttn
  2. i did add cayenne as integration
  3. to the cayenne side (https://cayenne.mydevices.com/cayenne/dashboard/lora/cf74fce0-d563-11e9-b49d-5f4b6757b1bf)
4 .and am using this code
#include <LoRaWan.h>
#include <DHT.h>
#include <TheThingsNetwork.h>
#include <CayenneLPP.h>
#define DHTPIN A0 // the pin we’re connected the temperature and humidity sensor
#define DHTTYPE DHT11 // DHT 11
DHT dht(DHTPIN, DHTTYPE);
#define moisture A2 // the pin we’re connected the moisture sensor
int moistureval;
// Set your AppEUI and AppKey
const char *appEui = “xxxxxxxxxxxxxx”;
const char *appKey = “xxxxxxxxxxxxxxxxxxxxxxxxxxx”;
#define loraSerial SerialUSB
#define debugSerial SerialUSB
// Replace REPLACE_ME with TTN_FP_EU868 or TTN_FP_US915
#define freqPlan TTN_FP_EU868
TheThingsNetwork ttn(loraSerial, debugSerial, freqPlan);
CayenneLPP lpp(51);
//define and int variables
//unit16_t induval = 0;
uint16_t induVal = 0;
bool induState = false;
//uint16_t lightVal = 0;
//bool errorState = false;
uint16_t humidity = 0;
uint16_t temperature = 0;
//uint8_t addTemperature(uint8_t channel, float celsius);
//uint8_t addRelativeHumidity(uint8_t channel, float rh);
void setup()
//loraSerial.begin(57600);
//while(!SerialUSB);
debugSerial.begin(115200);
pinMode(moisture,INPUT);
// Wait a maximum of 10s for Serial Monitor
while (!debugSerial && millis() < 1000)
debugSerial.println("-- STATUS");
ttn.showStatus();
debugSerial.println("-- JOIN");
ttn.join(appEui, appKey);
dht.begin();
void loop()
debugSerial.println("-- LOOP");
debugSerial.println("----------------------------------");
//ttn.showStatus();
debugSerial.println();
debugSerial.println(“sensor information”);
debugSerial.println(“DATA”);
temperature =dht.readTemperature()*100 ;
humidity =dht.readHumidity()*100;
moistureval = analogRead(moisture);
debugSerial.print(“Temperature”);
debugSerial.println(“Temperature”);
debugSerial.print(“Humidity”);
debugSerial.println(“Humidity”);
debugSerial.print(“moisture”);
debugSerial.println(“moisture”);
float t = temperature;
float h = humidity;
lpp.reset();
lpp.addTemperature(1, t);
lpp.addRelativeHumidity(2,h );
// lpp.addmoisture(3, m);
//lpp.addBarometricPressure(2, 1073.21);
//lpp.addGPS(3, 52.37365, 4.88650, 2);
debugSerial.println(“payload”);
byte payload[4]={0};
payload[0] = highByte(temperature);
payload[1] = lowByte(temperature);
payload[2] = highByte(humidity);
payload[3] = lowByte(humidity);
// payload[4] = highByte(moistureval);
// payload[5] = lowByte(moistureval);
int loop;
for(loop=0; loop < 4; loop++)
debugSerial.println(payload[loop]);
// Send it off
// ttn.sendBytes(lpp.getBuffer(), lpp.getSize());
// SerialUSB.print("Temperature: "+String (temperature));
//SerialUSB.print("humidity: "+String (humidity));
ttn.sendBytes(payload, sizeof(payload));
delay(10000);
please help me how to fix this problem
I don’t see a ‘normal’ cayenne dashboard … did you make that , with widgets ect.
probably you placed the wrong link
for the cayenne dashboard i did created it like this
step 1. click to new devices\ widgets
step 2. click to lora
step 3. click to the things network
step 4 select the board (see technology seeeduino LORAWAN)
you can generate an external dashboard link So we may see it
but i think it gonna ask my detail before to log in
i did also try this code but it does not want to connect to the ttn (+KEY: NWKSKEY 3FB33E70EECACFB206D4589FFD44980E
+KEY: APPSKEY 3FB33E70EECACFB206D4589FFD44980E
+KEY: APPKEY 3FB33E70EECACFB206D4589FFD44980E
+MODE: LWOTAA
+DR: EU868
+DR: DR0
+DR: EU868 DR0 SF12 BW125K
+CH: 0,867700000,DR0:DR5
+CH: 1,867900000,DR0:DR5
+CH: 2,868800000,DR0:DR5
+RXWIN1: 0,867700000
+RXWIN2: 869500000,DR3
+LW: DC, OFF, 0
+LW: JDC, OFF
+POWER: 14
+MSGHEX: Please join network first
code
#include <DHT.h>
unsigned char data[2] = {1, 2};
char buffer[256];
CayenneLPP lpp(51);
void setup(void)
dht.begin();
SerialUSB.begin(115200);
lora.init();
memset(buffer, 0, 256);
lora.getVersion(buffer, 256, 1);
SerialUSB.print(buffer);
lora.getId(buffer, 256, 1);
// void setID( char *DevAddr, char *DevEUI, char *AppEUI);
// lora.setId(NULL, “xxxxxxxxxxxx” , “xxxxxxxxxxxxxxxxxxx”);
//setKey(char *NwKSKey, char *AppSKey, char *AppKey);
// lora.setKey(NULL, NULL, “xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx”);
lora.setKey(“2B7E151628AED2A6ABF7158809CF4F3C”, “2B7E151628AED2A6ABF7158809CF4F3C”, “2B7E151628AED2A6ABF7158809CF4F3C”);
lora.setDeciveMode(LWOTAA);
lora.setDataRate(DR0, EU868);
lora.setChannel(0, 867.7);
lora.setChannel(1, 867.9);
lora.setChannel(2, 868.8);
lora.setReceiceWindowFirst(0, 867.7);
lora.setReceiceWindowSecond(869.5, DR3);
lora.setDutyCycle(false);
lora.setJoinDutyCycle(false);
lora.setPower(14);
void loop(void)
bool result = false;
delay(10000);
int h = dht.readHumidity();
int t = dht.readTemperature();
lpp.reset();
lpp.addBarometricPressure(2, h);
result = lora.transferPacket(lpp.getBuffer(), lpp.getSize(), 10);
if (result)
short length;
short rssi;
length = lora.receivePacket(buffer, 256, &rssi);
if (length)
  SerialUSB.print("Length is: ");
  SerialUSB.println(length);
  SerialUSB.print("RSSI is: ");
  SerialUSB.println(rssi);
  SerialUSB.print("Data is: ");
  for (unsigned char i = 0; i < length; i ++)
    SerialUSB.print("0x");
    SerialUSB.print(buffer[i], HEX);
    SerialUSB.print(" ");
  SerialUSB.println();
You can ‘share’ a dashboard you’ve created. (search docs)
I don’t want your 'log in ’ page :sunglasses:
just want to make sure your Cayenne setup is ok before looking at codes&nodes
but you have more ‘problems’
1 - your gateway, is it connected to TTN and is it lorawan compatible
2 - your node(s) … can they connect OTAA to TTN and you see their data coming in
3 - Cayenne integration… do you receive data in Cayenne
1 yes my gateway running on the ttn (working nicely)
  1. yes i am bale to send data to the ttn ( temeperature , humidity and moisture)
3 i did add cayenne to the integration but am not able to receive data to cayenne dashboard
https://cayenne.mydevices.com/shared/5d7b5a4633ed91791a67ad39
@BoRRoZ did i well set up the cayenne dashboard?
Hi sorry… bit busy
I see an empty dashboard with no widgets
I’m missing some widgets ?
lpp.reset();
lpp.addBarometricPressure](https://lpp.addBarometricPressure)(2, 1073.21);
lpp.addGPS](https://lpp.addGPS)(3, 52.37365, 4.88650, 2);
anyway in your live dashboard you can exactly see what data is received (in this case from ttn)
see some tab … sorry, I don’t have time to look everthing up for you now, haven’t worked in a long time with Cayenne So maybe things changed :wink:
@BoRRoZ thank you … its working now :sunglasses:
