How to Change v2 App Key
As per this section of the migration guide:
The recommended practice is to change the AppKey in The Things Network V2.
I’m poking around in the v2 ttn console and I feel like a bit of a dunce as I can’t find where or how to change the app key for my devices. Also, do I have to do this for each device individually or is there a script I can run to do this en masse for all the devices in my application?
Found it under:
Applications > my application id > Devices > some device id > Settings
Still would rather not have to click through hundreds of devices to do this if there’s a less Byzantine approach… anyone know? I guess I could see what the console does in dev-tools and write a NodeJS script…
Or use the ttn-lw-migrate tool
I didn’t realize the ttn-lw-migrate tool could do that… the help certainly doesn’t suggest that it can:
Available Commands:
  application Export all devices of an application
  device      Export devices by DevEUI
  help        Help about any command
  sources     List available sources
  version     Print version information
Flags:
      --dev-id-prefix string         (optional) value to be prefixed to the resulting device IDs
      --dry-run                      Do everything except resetting root and session keys of exported devices
      --frequency-plans-url string   URL for fetching frequency plans (default "https://raw.githubusercontent.com/TheThingsNetwork/lorawan-frequency-plans/master")
  -h, --help                         help for ttn-lw-migrate
      --verbose                      Verbose output
Use "ttn-lw-migrate [command] --help" for more information about a command.
Anyway, I got it done with a simple-enough node script, copied my cookie and authorization headers out of dev tools in Chrome and ran this (using the devices I exported using the ttn-lw-migrate tool). Basically just a PATCH to https://v2console.thethingsnetwork.org/api/applications{app_id}/devices/{dev_id} with a body that looks like this:
      app_eui,
      app_key: 'randomly-generated-appkey',
      description,
      dev_eui,
      disable_fcnt_check: false,
      method: 'OTAA',
      uses_32bit_fcnt: false
Seems like it worked, so I think I’m ok.
:wink:
The docs do:
--ttnv2.with-session=false
