@Jeff-UK the sensor and the ttn gateway are in adjoining rooms. The rssi is -51
@bnnorman see below the test.log
2023-02-26 18:00:45,367 - __init__ - 78 - INFO - __init__ starting
2023-02-26 18:00:45,796 - setCacheDefaults - 413 - INFO - Setting default MAC values using user config values
2023-02-26 18:00:45,796 - getFrequencyPlan - 342 - INFO - loading frequency plan
2023-02-26 18:00:45,796 - getFrequencyPlan - 345 - INFO - Frequency Plan is EU_863_870_TTN
2023-02-26 18:00:45,797 - getFrequencyPlan - 354 - INFO - Frequency Plan loaded ok
2023-02-26 18:00:45,797 - setCacheDefaults - 479 - INFO - MAC default settings finished
2023-02-26 18:00:45,797 - __init__ - 104 - DEBUG - Setting self.cache[fCntUp] to 0
2023-02-26 18:00:45,797 - __init__ - 104 - DEBUG - Setting self.cache[fCntDn] to 0
2023-02-26 18:00:45,797 - __init__ - 104 - DEBUG - Setting self.cache[rx1_delay] to 5
2023-02-26 18:00:45,798 - __init__ - 104 - DEBUG - Setting self.cache[rx2_delay] to 1
2023-02-26 18:00:45,798 - __init__ - 104 - DEBUG - Setting self.cache[rx1_DR] to 3
2023-02-26 18:00:45,798 - __init__ - 104 - DEBUG - Setting self.cache[rx2_DR] to 3
2023-02-26 18:00:45,798 - __init__ - 108 - INFO - missing TTN section key rx1_freq_fixed ignored
2023-02-26 18:00:45,798 - __init__ - 108 - INFO - missing TTN section key rx1_frequency ignored
2023-02-26 18:00:45,798 - __init__ - 104 - DEBUG - Setting self.cache[rx2_frequency] to 869.525
2023-02-26 18:00:45,798 - __init__ - 108 - INFO - missing TTN section key duty_cycle ignored
2023-02-26 18:00:45,799 - __init__ - 104 - DEBUG - Setting self.cache[data_rate] to 3
2023-02-26 18:00:45,799 - __init__ - 116 - DEBUG - Setting self.cache[devaddr] to [0, 0, 0, 0]
2023-02-26 18:00:45,799 - __init__ - 116 - DEBUG - Setting self.cache[deveui] to [228, 95, 1, 255, 255, 134, 124, 64]
2023-02-26 18:00:45,799 - __init__ - 119 - INFO - Missing OTAA TTN key nwkskey ignored
2023-02-26 18:00:45,799 - __init__ - 119 - INFO - Missing OTAA TTN key appskey ignored
2023-02-26 18:00:45,799 - __init__ - 116 - DEBUG - Setting self.cache[appeui] to [0, 0, 0, 0, 0, 0, 0, 0]
2023-02-26 18:00:45,799 - __init__ - 116 - DEBUG - Setting self.cache[appkey] to [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1]
2023-02-26 18:00:45,800 - loadCache - 524 - INFO - Loading MAC settings
2023-02-26 18:00:45,800 - loadCache - 542 - INFO - cached settings load failed [Errno 2] No such file or directory: 'cache.json'. Saving current defaults
2023-02-26 18:00:45,800 - saveCache - 489 - INFO - Saving MAC settings
2023-02-26 18:00:45,801 - saveCache - 495 - INFO - Saving MAC settings failed Object of type bytearray is not JSON serializable.
2023-02-26 18:00:45,801 - saveCache - 489 - INFO - Saving MAC settings
2023-02-26 18:00:45,802 - saveCache - 495 - INFO - Saving MAC settings failed Object of type bytearray is not JSON serializable.
2023-02-26 18:00:45,803 - __init__ - 141 - INFO - __init__ done
2023-02-26 18:00:45,803 - __init__ - 96 - WARNING - Not enabling GPS (see enableGPS param)
2023-02-26 18:00:45,804 - __init__ - 133 - INFO - __init__ done
2023-02-26 18:00:45,804 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:00:45,804 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:00:45,804 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:00:45,805 - join - 484 - INFO - Performing OTAA Join
2023-02-26 18:00:45,805 - getJoinSettings - 230 - DEBUG - using join settings: freq 868.5 sf 9 bw 7
2023-02-26 18:00:45,805 - configureRadio - 173 - INFO - freq=868.5 sf=9 bw=7
2023-02-26 18:00:45,807 - _tryToJoin - 497 - INFO - trying to join TTN
2023-02-26 18:00:45,807 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:00:45,807 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:00:45,807 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:00:45,807 - _tryToJoin - 507 - DEBUG - App key = [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1]
2023-02-26 18:00:45,807 - _tryToJoin - 508 - DEBUG - App eui = [0, 0, 0, 0, 0, 0, 0, 0]
2023-02-26 18:00:45,808 - _tryToJoin - 509 - DEBUG - Dev eui = [228, 95, 1, 255, 255, 134, 124, 64]
2023-02-26 18:00:45,808 - _tryToJoin - 510 - DEBUG - Devnonce= [231, 156]
2023-02-26 18:00:45,809 - _tryToJoin - 521 - DEBUG - sending packet [0, 0, 0, 0, 0, 0, 0, 0, 0, 64, 124, 134, 255, 255, 1, 95, 228, 231, 156, 190, 168, 14, 231]
2023-02-26 18:00:45,810 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:00:45,810 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:00:45,810 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:00:47,812 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:00:47,813 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:00:47,813 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:00:49,815 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:00:49,816 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:00:49,816 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:00:51,819 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:00:51,819 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:00:51,819 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:00:53,822 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:00:53,822 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:00:53,822 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:00:55,825 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:00:55,825 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:00:55,825 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:00:57,828 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:00:57,828 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:00:57,828 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:00:59,831 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:00:59,831 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:00:59,831 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:01:01,834 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:01:01,834 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:01:01,835 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:01:03,837 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:01:03,838 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:01:03,838 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:01:05,840 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:01:05,841 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:01:05,841 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:01:07,843 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:01:07,844 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:01:07,844 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:01:09,846 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:01:09,847 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:01:09,847 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:01:11,849 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:01:11,850 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:01:11,850 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:01:13,852 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:01:13,853 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:01:13,853 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:01:15,855 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:01:15,856 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:01:15,856 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:01:17,859 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:01:17,859 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:01:17,859 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:01:19,862 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:01:19,862 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:01:19,862 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:01:21,865 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:01:21,865 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:01:21,865 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:01:23,868 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:01:23,868 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:01:23,868 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:01:25,871 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:01:25,871 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:01:25,871 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:01:27,874 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:01:27,874 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:01:27,874 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:01:29,877 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:01:29,877 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:01:29,878 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:01:31,880 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:01:31,880 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:01:31,881 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:01:33,883 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:01:33,883 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:01:33,884 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:01:35,886 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:01:35,886 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:01:35,887 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:01:37,889 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:01:37,889 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:01:37,890 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:01:39,892 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:01:39,893 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:01:39,893 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:01:41,895 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:01:41,896 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:01:41,896 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:01:43,898 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:01:43,899 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:01:43,899 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:01:45,901 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:01:45,902 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:01:45,902 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:01:47,904 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:01:47,905 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:01:47,905 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:01:49,907 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:01:49,908 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:01:49,908 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:01:51,910 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:01:51,911 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:01:51,911 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:01:53,914 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:01:53,914 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:01:53,914 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:01:55,917 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:01:55,917 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:01:55,917 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:01:57,920 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:01:57,920 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:01:57,920 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:01:59,923 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:01:59,923 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:01:59,923 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:02:01,926 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:02:01,926 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:02:01,927 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:02:03,929 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:02:03,929 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:02:03,930 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:02:05,932 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:02:05,933 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:02:05,933 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:02:07,935 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:02:07,936 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:02:07,936 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:02:09,938 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:02:09,939 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:02:09,939 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:02:11,941 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:02:11,942 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:02:11,942 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:02:13,944 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:02:13,945 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:02:13,945 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:02:15,948 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:02:15,948 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:02:15,948 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:02:17,951 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:02:17,951 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:02:17,951 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:02:19,954 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:02:19,954 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:02:19,954 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:02:21,957 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:02:21,957 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:02:21,958 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:02:23,960 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:02:23,961 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:02:23,961 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:02:25,963 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:02:25,964 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:02:25,964 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:02:27,967 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:02:27,967 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:02:27,967 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:02:29,970 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:02:29,970 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:02:29,971 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:02:31,973 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:02:31,973 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:02:31,974 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:02:33,976 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:02:33,976 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:02:33,977 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:02:35,979 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:02:35,979 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:02:35,980 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:02:37,982 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:02:37,983 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:02:37,983 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:02:39,985 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:02:39,986 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:02:39,986 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:02:41,988 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:02:41,989 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:02:41,989 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:02:43,991 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:02:43,992 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:02:43,992 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:02:45,994 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:02:45,995 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:02:45,995 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:02:47,997 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:02:47,998 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:02:47,998 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:02:50,000 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:02:50,001 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:02:50,001 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:02:52,003 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:02:52,004 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:02:52,004 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:02:54,007 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:02:54,007 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:02:54,007 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:02:56,010 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:02:56,010 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:02:56,010 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:02:58,013 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:02:58,013 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:02:58,013 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:03:00,016 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:03:00,016 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:03:00,016 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:03:02,019 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:03:02,019 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:03:02,020 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:03:04,022 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:03:04,023 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:03:04,023 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:03:06,025 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:03:06,026 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:03:06,026 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:03:08,028 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:03:08,029 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:03:08,029 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:03:10,032 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:03:10,032 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:03:10,032 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:03:12,035 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:03:12,035 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:03:12,035 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:03:14,038 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:03:14,038 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:03:14,038 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:03:16,040 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:03:16,040 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:03:16,040 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:03:18,043 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:03:18,043 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:03:18,043 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:03:20,046 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:03:20,046 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:03:20,046 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:03:22,049 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:03:22,049 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:03:22,049 - registered - 564 - DEBUG - devaddr not assigned
2023-02-26 18:03:24,052 - registered - 550 - INFO - checking if already registered.
2023-02-26 18:03:24,052 - registered - 556 - INFO - devaddr [0, 0, 0, 0] len 4.
2023-02-26 18:03:24,052 - registered - 564 - DEBUG - devaddr not assigned
