Hi there, need advice on how to remove myself from a community group? I can see the join buttons on the communities section of the main website but cant see the leave button?
Jez
Jez
Last thing I remember, I was
Running for the door
I had to find the passage back to the place I was before
’Relax’ said the night man,
'We are programmed to receive.
You can check out any time you like,
But you can never leave!’
Hotel California
Eagles
I don’t know, maybe the admin from that community can delete you ?
Apparently not, I have to delete my account to remove myself from a community ? crazy
The Leave this community
button somehow disappeared after the last update. I’ll add it again.
For now, you can use: https://www.thethingsnetwork.org/community/NAME_OF_COMMUNTIY/leave
Did that leave group thing, yet my gateways are still associated with the group, even a gateway setup after leaving
Not sure but suspect that any GW’s deployed within the ‘coverage radius’ defined for a given community get automatically added to that community…are the ones you refer to still inside that radius? or are they placed elsewhere on the TTN Map/Registration?
@Jeff-UK correct!
@jezd the gateways on the communtiy map are not related to the members of the community. All gateways in a certain radius are displayed on the map.
There are a number of community specific topics and a lot of technical explanations of building a LoRa network, but can someone indicate where we could discuss more generally about strategies of building communities etc.
