akaka
(Akaka)
1
ttnctl user login < Authorization code from https://eu1.cloud.thethings.network/oauth/authorize?client_id=cli&redirect_uri=code&response_type=code>
doesn’t work and gives this: FATAL Login failed error=Code not found
When I use the access code from
it logs in my v2 account.
thanks
Jeff-UK
(Jeff Uk)
2
Ttnctl is for V2 hence
Big clue there you need the V3 cli… docs & forum search are your friend
netskink
(Netskink)
3
Hmm. My understanding is that the cli only works for V2. Would that not be the correct answer?
descartes
(Nick McCloud)
6
Depends on what you mean by “it”.
As a wise man said 3h ago, docs & forum search for the win.
system
(system)
Closed
7
