If my node was send 1 time but gateway unacceptable. I want to resend which the interval to resend I can determined.
What I have to do like this with this code below ???
#include <lmic.h>
#include <hal/hal.h>
#include <SPI.h>
#include <DHT.h>
#include <DHT_U.h>
#include <Wire.h>
#include <LowPower.h>
#define DHTPIN 9 //DHT pin
#define DHTTYPE DHT11 // DHT22 or DHT11
DHT dht(DHTPIN, DHTTYPE);
#include <BH1750.h>
BH1750 lightMeter;
#include <Arduino.h>
static const PROGMEM u1_t NWKSKEY[16] = { };
static const u1_t PROGMEM APPSKEY[16] = { };
static const u4_t DEVADDR = 0x ;
static osjob_t sendjob;
// cycle limitations).
const unsigned TX_INTERVAL = 3600;
// Pin mapping
.nss = 10,
.rxtx = LMIC_UNUSED_PIN,
.rst = 5,
.dio = {2, 3},
void onEvent (ev_t ev) {
Serial.println(F("TXCOMPLETE"));
// Schedule next transmission
for (int i=0; i<int(TX_INTERVAL/8); i++) {
// Use library from https://github.com/rocketscream/Low-Power
LowPower.powerDown(SLEEP_8S, ADC_OFF, BOD_OFF);
delay(1000);
do_send(&sendjob);
void do_send(osjob_t* j){
} else {
byte payload[8];
int analogPin = A0;
int analogRead_value = 0;
float scale_voltage = 0;
float Final_voltage = 0;
analogRead_value = analogRead(analogPin);
scale_voltage = map(analogRead_value,0,1023,0,900);
Final_voltage = scale_voltage/100;
//uint32_t Battery_percentage = (Final_voltage-2.7)*100.0/6.3*100;
uint32_t Battery_percentage = (Final_voltage*10000)/9;
//Serial.println(analogRead_value);
//Serial.println(Final_voltage);
//Serial.println(Battery_percentage,HEX);
uint32_t humid = dht.readHumidity(false) * 100;
uint32_t temp = dht.readTemperature(false) * 100;
Serial.println(humid);
Serial.println(temp);
uint16_t s_value;
uint16_t lux = lightMeter.readLightLevel();
s_value=lux;
payload[4]=s_value&0xFF; //lower byte
payload[5]=s_value>>8; //higher byte
payload[6]=highByte(Battery_percentage);
payload[7]=lowByte(Battery_percentage);
Serial.println("high low hum temp");
Serial.println(highByte(humid),HEX);
Serial.println(lowByte(humid),HEX);
Serial.println(highByte(temp),HEX);
Serial.println(lowByte(temp),HEX);
Serial.println("---------------");
payload[0] = highByte(humid);
payload[1] = lowByte(humid);
payload[2] = highByte(temp);
payload[3] = lowByte(temp);
Serial.println(payload[0]);
Serial.println(payload[1]);
Serial.println(payload[2]);
Serial.println(payload[3]);
LMIC_setTxData2(1, (uint8_t*)payload, sizeof(payload), 0);
void setup() {
Serial.begin(115200);
//Start sensor setup
// pinMode(sensor, INPUT); //declaring sensor as an output
lightMeter.begin();
dht.begin();
Wire.begin();
//lightMeter.begin();
// onetime-measure:
// LMIC init
os_init();
LMIC_reset();
#ifdef PROGMEM
LMIC_setSession (0x1, DEVADDR, nwkskey, appskey);
#else
LMIC_setSession (0x1, DEVADDR, NWKSKEY, APPSKEY);
#endif
LMIC_setupChannel(0, 923200000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(1, 923400000, DR_RANGE_MAP(DR_SF12, DR_SF7B), BAND_CENTI); // g-band
LMIC_setupChannel(2, 923600000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(3, 923800000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(4, 924000000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(5, 924200000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(6, 924400000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(7, 924600000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setLinkCheckMode(0);
LMIC.dn2Dr = DR_SF9;
// Set data rate and transmit power for uplink (note: txpow seems to be ignored by the library)
LMIC_setDrTxpow(DR_SF7,14);
// Start job
do_send(&sendjob);
void loop() {
os_runloop_once();
