Hi TTN-Fellows,
I am not asking to find a away to avoid the TTN Fair Policy but I’d like to troubleshoot why a sensor node in the field has stopped working. The sensor node was programmed to send each 15min with SF8 corresponding to an airtime of around 100ms. This would result in a daily airtime of 96seconds. However, due to some software malfunction, the sensor node started sending each 50seconds over around 12h, which yielded to an airtime of 86seconds in 12h, so in total over 90seconds airtime in 24h.
The malfunction was caused since I used softwareserial, which caused a watchdog timer interrupt.
How can I know when TTN blocked me? Probably this information shouldn’t be revealed to the public eventually. In the Fair Policy it just reads the daily air time shouldn’t exceed an average of 30seconds.
Thank you!
