Hello folks,
I have been working on integrating some hardware into Datacake and I have reached an impasse. I was hoping someone would be able to possibly give me some insight.
I have a sensor that is sending time of flight data to TTS and using a webhook sending that payload to Datacake. I am using a payload decoder that I wrote in TTS and Im able to see that decoded payload in the debug console of Datacake, but I have no idea how to format the decoder properly so that Datacake can extrapolate the proper fields for use in the dashboard.
I have read through all of the documentation that I can find, but I am unable to get the fixes that are referenced to work. This article is explaining what I need to do, but when I add the “Converter for TTN Payload” to the end of my payload decoder in Datacake, that extra function is unable to reference the data fields earlier in the code.
I should note that I am pretty new to javascript, so i apologize if this is a stupid question. That being said, i have had the TTS → Datacake integration working great for all of my other sensor arrays. Up until now though, those have all been more simple readings like temp, humidity, etc. The time of flight data that I am sending now is separated into many channels and is a bit more complicated.
Below is my payload formatter that I am using successfully in TTS and trying to adapt to Datacake. Any help is really really appreciated. Ive been trying to figure this out for a few days and im hitting a wall.
function Bytes2Float32(bytes) {
var sign = (bytes & 0x80000000) ? -1 : 1;
var exponent = ((bytes >> 23) & 0xFF) - 127;
var significand = (bytes & ~(-1 << 23));
if (exponent == 128)
return sign * ((significand) ? Number.NaN : Number.POSITIVE_INFINITY);
if (exponent == -127) {
if (significand == 0) return sign * 0.0;
exponent = -126;
significand /= (1 << 22);
} else significand = (significand | (1 << 23)) / (1 << 23);
return sign * significand * Math.pow(2, exponent);
var data1 = {};
var data2 = {};
var data3 = {};
var data4 = {};
var data5 = {};
var data6 = {};
var data7 = {};
var data8 = {};
var data = {};
var fportcaller = [input.fPort];
var events = {
1: "setup",
2: "5 Minute",
3: "1 Hour",
4: "6 Hour pt. 1",
5: "6 Hour pt. 2",
6: "6 Hour pt. 3",
7: "6 Hour pt. 4",
//Startup
data1.event = events[input.fPort];
data1.status =(input.bytes[0]);
data1.heading = (input.bytes[1]) + (input.bytes[2]);
data1.pitch = (input.bytes[3]);
data1.roll = (input.bytes[4]);
data1.altitude = (input.bytes[4] <<34);
data1.temperature = (((input.bytes[5] & 0x80 ? input.bytes[5] - 0x100 : input.bytes[5]) << 8) + input.bytes[5]) / 100;
data1.humidity = (((input.bytes[6] & 0x80 ? input.bytes[6] - 0x100 : input.bytes[6]) << 8) + input.bytes[6]) / 100;
data1.current = (input.bytes[7] << 1);
data1.voltage = (input.bytes[8] << 1);
data1.firmware = (input.bytes[8] << 4);
data1.gpslong = (input.bytes[8] << 43);
data1.gpslat = (input.bytes[8] << 23);
//5 Minute
data2.event = events[input.fPort];
data2.status =(input.bytes[0]);
data2.VL53L5CX_Range_CH1 = (input.bytes[1]) + (input.bytes[2]);
data2.VL53L5CX_Range_CH2 = (input.bytes[3]) + (input.bytes[4]);
data2.VL53L5CX_Range_CH3 = (input.bytes[5]) + (input.bytes[6]);
data2.VL53L5CX_Range_CH4 = (input.bytes[7]) + (input.bytes[8]);
data2.VL53L5CX_Range_CH5 = (input.bytes[9]) + (input.bytes[10]);
data2.VL53L5CX_Range_CH6 = (input.bytes[11]) + (input.bytes[12]);
data2.VL53L5CX_SigStrength_CH1 = (input.bytes[13]);
data2.VL53L5CX_SigStrength_CH2 = (input.bytes[14]);
data2.VL53L5CX_SigStrength_CH3 = (input.bytes[15]);
data2.VL53L5CX_SigStrength_CH4 = (input.bytes[16]);
data2.VL53L5CX_SigStrength_CH5 = (input.bytes[17]);
data2.VL53L5CX_SigStrength_CH6 = (input.bytes[18]);
data2.VL53L5CX_AmbientLight_CH1 = (input.bytes[19]);
data2.VL53L5CX_AmbientLight_CH2 = (input.bytes[20]);
data2.VL53L5CX_AmbientLight_CH3 = (input.bytes[21]);
data2.VL53L5CX_AmbientLight_CH4 = (input.bytes[22]);
data2.VL53L5CX_AmbientLight_CH5 = (input.bytes[23]);
data2.VL53L5CX_AmbientLight_CH6 = (input.bytes[24]);
data2.VL53L5CX_UltrasonicRange_CH1 = (input.bytes[25]);
data2.VL53L5CX_UltrasonicRange_CH2 = (input.bytes[26]);
//1 Hour
data3.event = events[input.fPort];
data3.status =(input.bytes[2]);
data3.heading = (input.bytes[1]) + (input.bytes[2]);
data3.pitch = (input.bytes[1]<< 8);
data3.roll = (input.bytes[4] << 8);
data3.temperature = (((input.bytes[5] & 0x80 ? input.bytes[5] - 0x100 : input.bytes[5]) << 8) + input.bytes[5]) / 100;
data3.humidity = (((input.bytes[6] & 0x80 ? input.bytes[6] - 0x100 : input.bytes[6]) << 8) + input.bytes[6]) / 100;
data3.current = (input.bytes[3] << 1);
data3.voltage = (input.bytes[3] << 1);
//24 Hour
data4.event = events[input.fPort];
data4.status =(input.bytes[0]);
data4.firmware = (input.bytes[1]);
data4.accuracy = (input.bytes[2]);
data4.altitude = (input.bytes[3]) + (input.bytes[4]);
data4.gpslong = (input.bytes[5]) + (input.bytes[6]) + (input.bytes[7]) + (input.bytes[8]);
data4.gpslong = (input.bytes[9]) + (input.bytes[10]) + (input.bytes[11]) + (input.bytes[12]);
//6 Hour Part 1
data5.event = events[input.fPort];
data5.VL53L5CX_Range_CH1 = (input.bytes[0]) + (input.bytes[1]);
data5.VL53L5CX_Range_CH2 = (input.bytes[2]) + (input.bytes[3]);
data5.VL53L5CX_Range_CH3 = (input.bytes[4]) + (input.bytes[5]);
data5.VL53L5CX_Range_CH4 = (input.bytes[6]) + (input.bytes[7]);
data5.VL53L5CX_Range_CH5 = (input.bytes[8]) + (input.bytes[9]);
data5.VL53L5CX_Range_CH6 = (input.bytes[10]) + (input.bytes[11]);
data5.VL53L5CX_Range_CH7 = (input.bytes[12]) + (input.bytes[13]);
data5.VL53L5CX_Range_CH8 = (input.bytes[14]) + (input.bytes[15]);
data5.VL53L5CX_Range_CH9 = (input.bytes[16]) + (input.bytes[17]);
data5.VL53L5CX_Range_CH10 = (input.bytes[18]) + (input.bytes[19]);
data5.VL53L5CX_Range_CH11 = (input.bytes[20]) + (input.bytes[21]);
data5.VL53L5CX_Range_CH12 = (input.bytes[22]) + (input.bytes[23]);
data5.VL53L5CX_Range_CH13 = (input.bytes[24]) + (input.bytes[25]);
data5.VL53L5CX_Range_CH14 = (input.bytes[26]) + (input.bytes[27]);
data5.VL53L5CX_Range_CH15 = (input.bytes[28]) + (input.bytes[29]);
data5.VL53L5CX_Range_CH16 = (input.bytes[30]) + (input.bytes[31]);
data5.VL53L5CX_Range_CH17 = (input.bytes[32]) + (input.bytes[33]);
data5.VL53L5CX_Range_CH18 = (input.bytes[34]) + (input.bytes[35]);
data5.VL53L5CX_Range_CH19 = (input.bytes[36]) + (input.bytes[37]);
data5.VL53L5CX_Range_CH20 = (input.bytes[38]) + (input.bytes[39]);
data5.VL53L5CX_Range_CH21 = (input.bytes[40]) + (input.bytes[41]);
data5.VL53L5CX_Range_CH22 = (input.bytes[42]) + (input.bytes[43]);
data5.VL53L5CX_Range_CH23 = (input.bytes[44]) + (input.bytes[45]);
data5.VL53L5CX_Range_CH24 = (input.bytes[46]) + (input.bytes[47]);
data5.VL53L5CX_Range_CH25 = (input.bytes[48]) + (input.bytes[49]);
data5.VL53L5CX_Range_CH26 = (input.bytes[50]) + (input.bytes[51]);
//6 Hour Part 2
data6.event = events[input.fPort];
data6.VL53L5CX_Range_CH27 = (input.bytes[0]) + (input.bytes[1]);
data6.VL53L5CX_Range_CH28 = (input.bytes[2]) + (input.bytes[3]);
data6.VL53L5CX_Range_CH29 = (input.bytes[4]) + (input.bytes[5]);
data6.VL53L5CX_Range_CH30 = (input.bytes[6]) + (input.bytes[7]);
data6.VL53L5CX_Range_CH31 = (input.bytes[8]) + (input.bytes[9]);
data6.VL53L5CX_Range_CH32 = (input.bytes[10]) + (input.bytes[11]);
data6.VL53L5CX_Range_CH33 = (input.bytes[12]) + (input.bytes[13]);
data6.VL53L5CX_Range_CH34 = (input.bytes[14]) + (input.bytes[15]);
data6.VL53L5CX_Range_CH35 = (input.bytes[16]) + (input.bytes[17]);
data6.VL53L5CX_Range_CH36 = (input.bytes[18]) + (input.bytes[19]);
data6.VL53L5CX_Range_CH37 = (input.bytes[20]) + (input.bytes[21]);
data6.VL53L5CX_Range_CH38 = (input.bytes[22]) + (input.bytes[23]);
data6.VL53L5CX_Range_CH39 = (input.bytes[24]) + (input.bytes[25]);
data6.VL53L5CX_Range_CH40 = (input.bytes[26]) + (input.bytes[27]);
data6.VL53L5CX_Range_CH41 = (input.bytes[28]) + (input.bytes[29]);
data6.VL53L5CX_Range_CH42 = (input.bytes[30]) + (input.bytes[31]);
data6.VL53L5CX_Range_CH43 = (input.bytes[32]) + (input.bytes[33]);
data6.VL53L5CX_Range_CH44 = (input.bytes[34]) + (input.bytes[35]);
data6.VL53L5CX_Range_CH45 = (input.bytes[36]) + (input.bytes[37]);
data6.VL53L5CX_Range_CH46 = (input.bytes[38]) + (input.bytes[39]);
data6.VL53L5CX_Range_CH47 = (input.bytes[40]) + (input.bytes[41]);
data6.VL53L5CX_Range_CH48 = (input.bytes[42]) + (input.bytes[43]);
data6.VL53L5CX_Range_CH49 = (input.bytes[44]) + (input.bytes[45]);
data6.VL53L5CX_Range_CH50 = (input.bytes[46]) + (input.bytes[47]);
data6.VL53L5CX_Range_CH51 = (input.bytes[48]) + (input.bytes[49]);
data6.VL53L5CX_Range_CH52 = (input.bytes[50]) + (input.bytes[51]);
//6 Hour Part 3
data7.event = events[input.fPort];
data7.VL53L5CX_Range_CH53 = (input.bytes[0]) + (input.bytes[1]);
data7.VL53L5CX_Range_CH54 = (input.bytes[2]) + (input.bytes[3]);
data7.VL53L5CX_Range_CH55 = (input.bytes[4]) + (input.bytes[5]);
data7.VL53L5CX_Range_CH56 = (input.bytes[6]) + (input.bytes[7]);
data7.VL53L5CX_Range_CH57 = (input.bytes[8]) + (input.bytes[9]);
data7.VL53L5CX_Range_CH58 = (input.bytes[10]) + (input.bytes[11]);
data7.VL53L5CX_Range_CH59 = (input.bytes[12]) + (input.bytes[13]);
data7.VL53L5CX_Range_CH60 = (input.bytes[14]) + (input.bytes[15]);
data7.VL53L5CX_Range_CH61 = (input.bytes[16]) + (input.bytes[17]);
data7.VL53L5CX_Range_CH62 = (input.bytes[18]) + (input.bytes[19]);
data7.VL53L5CX_Range_CH63= (input.bytes[20]) + (input.bytes[21]);
data7.VL53L5CX_Range_CH64 = (input.bytes[22]) + (input.bytes[23]);
data7.VL53L5CX_SigStrength_CH1 = (input.bytes[24]);
data7.VL53L5CX_SigStrength_CH2 = (input.bytes[25]);
data7.VL53L5CX_SigStrength_CH3 = (input.bytes[26]);
data7.VL53L5CX_SigStrength_CH4 = (input.bytes[27]);
data7.VL53L5CX_SigStrength_CH5 = (input.bytes[28]);
data7.VL53L5CX_SigStrength_CH6 = (input.bytes[29]);
data7.VL53L5CX_SigStrength_CH7 = (input.bytes[30]);
data7.VL53L5CX_SigStrength_CH8 = (input.bytes[31]);
data7.VL53L5CX_SigStrength_CH9 = (input.bytes[32]);
data7.VL53L5CX_SigStrength_CH10 = (input.bytes[33]);
data7.VL53L5CX_SigStrength_CH11 = (input.bytes[34]);
data7.VL53L5CX_SigStrength_CH12 = (input.bytes[35]);
data7.VL53L5CX_SigStrength_CH13 = (input.bytes[36]);
data7.VL53L5CX_SigStrength_CH14 = (input.bytes[37]);
data7.VL53L5CX_SigStrength_CH15 = (input.bytes[38]);
data7.VL53L5CX_SigStrength_CH16 = (input.bytes[39]);
data7.VL53L5CX_SigStrength_CH17 = (input.bytes[40]);
data7.VL53L5CX_SigStrength_CH18 = (input.bytes[41]);
data7.VL53L5CX_SigStrength_CH19 = (input.bytes[42]);
data7.VL53L5CX_SigStrength_CH20 = (input.bytes[43]);
data7.VL53L5CX_SigStrength_CH21 = (input.bytes[44]);
data7.VL53L5CX_SigStrength_CH22 = (input.bytes[45]);
data7.VL53L5CX_SigStrength_CH23 = (input.bytes[46]);
data7.VL53L5CX_SigStrength_CH24 = (input.bytes[47]);
data7.VL53L5CX_SigStrength_CH25 = (input.bytes[48]);
data7.VL53L5CX_SigStrength_CH26 = (input.bytes[49]);
data7.VL53L5CX_SigStrength_CH27 = (input.bytes[50]);
data7.VL53L5CX_SigStrength_CH28 = (input.bytes[51]);
//6 Hour Part 4
data8.VL53L5CX_SigStrength_CH29 = (input.bytes[0]);
data8.VL53L5CX_SigStrength_CH30 = (input.bytes[1]);
data8.VL53L5CX_SigStrength_CH31 = (input.bytes[2]);
data8.VL53L5CX_SigStrength_CH32 = (input.bytes[3]);
data8.VL53L5CX_SigStrength_CH33 = (input.bytes[4]);
data8.VL53L5CX_SigStrength_CH34 = (input.bytes[5]);
data8.VL53L5CX_SigStrength_CH35 = (input.bytes[6]);
data8.VL53L5CX_SigStrength_CH36 = (input.bytes[7]);
data8.VL53L5CX_SigStrength_CH37 = (input.bytes[8]);
data8.VL53L5CX_SigStrength_CH38 = (input.bytes[9]);
data8.VL53L5CX_SigStrength_CH39 = (input.bytes[10]);
data8.VL53L5CX_SigStrength_CH40 = (input.bytes[11]);
data8.VL53L5CX_SigStrength_CH41 = (input.bytes[12]);
data8.VL53L5CX_SigStrength_CH42 = (input.bytes[13]);
data8.VL53L5CX_SigStrength_CH43 = (input.bytes[14]);
data8.VL53L5CX_SigStrength_CH44 = (input.bytes[15]);
data8.VL53L5CX_SigStrength_CH45 = (input.bytes[16]);
data8.VL53L5CX_SigStrength_CH46 = (input.bytes[17]);
data8.VL53L5CX_SigStrength_CH47 = (input.bytes[18]);
data8.VL53L5CX_SigStrength_CH48 = (input.bytes[19]);
data8.VL53L5CX_SigStrength_CH49 = (input.bytes[20]);
data8.VL53L5CX_SigStrength_CH50 = (input.bytes[21]);
data8.VL53L5CX_SigStrength_CH51 = (input.bytes[22]);
data8.VL53L5CX_SigStrength_CH52 = (input.bytes[23]);
data8.VL53L5CX_SigStrength_CH53 = (input.bytes[24]);
data8.VL53L5CX_SigStrength_CH54 = (input.bytes[25]);
data8.VL53L5CX_SigStrength_CH55 = (input.bytes[26]);
data8.VL53L5CX_SigStrength_CH56 = (input.bytes[27]);
data8.VL53L5CX_SigStrength_CH57 = (input.bytes[28]);
data8.VL53L5CX_SigStrength_CH58 = (input.bytes[29]);
data8.VL53L5CX_SigStrength_CH59 = (input.bytes[30]);
data8.VL53L5CX_SigStrength_CH60 = (input.bytes[31]);
data8.VL53L5CX_SigStrength_CH61 = (input.bytes[32]);
data8.VL53L5CX_SigStrength_CH62 = (input.bytes[33]);
data8.VL53L5CX_SigStrength_CH63 = (input.bytes[34]);
data8.VL53L5CX_SigStrength_CH64 = (input.bytes[35]);
data8.VL53L5CX_AmbientLight_CH1 = (input.bytes[36]);
data8.VL53L5CX_AmbientLight_CH2 = (input.bytes[37]);
data8.VL53L5CX_AmbientLight_CH3 = (input.bytes[38]);
data8.VL53L5CX_AmbientLight_CH4 = (input.bytes[39]);
data.depth = data8.VL53L5CX_AmbientLight_CH4;
var warnings = [x];
if (data1.temperature < -10) {
warnings.push("it's cold");
if(fportcaller == 1) {
return {
data:data1
}else if(fportcaller == 2) {
return{
data:data2
}else if(fportcaller == 3) {
return{
data:data3
}else if(fportcaller == 4) {
return{
data:data4
}else if(fportcaller == 5) {
return{
data:data5
}else if(fportcaller == 6) {
return{
data:data6
}else if(fportcaller == 7) {
return{
data:data7
}else if(fportcaller == 8) {
return{
data:data8
