The new gateway is a low-cost standard LoRaWAN gateway positioned for indoor environments, it’s based on the ESP32 and SX1308 + SX1255/7, it’s ready for sale now. https://heltec.org/project/ht-m01s/
Use this coupon to get a 20% discount (Valid in January 2021): ht2101060001
If you advertise your product on the TTN forum, then it would be nice to have a link to TTN on the product page as well and not just to a private LoRa Server solution.
With the launch of the V3 TTN option at the TTConf 21 late Jan you might also want to quickly move to update your docs to show option for V3 registration as well as the current V2 Console implementation. Also look for PM to follow.
What plans for others? Note with move to V3 TTN recommendation is avoid/move away from the SMTC legacy UDP solution… @kersing ‘s MPpf supports useful abilities like user friendly device naming (vs cryptic eui-12345fffe67890ab types), and of course LoRa BasicStation now de rigure…
The HT-M01S is ESP32 based so does not run Linux. The best (alternative) would be LoRa Basics Station which has been proven to run on the even less powerfull ESP8266 (but latter is closed source).
I have one HT-M01S (firmware Rev.1.2) and I´m trying to connect to TTN servers without success. After some time (the message below shows that the connection was made), the message “Disconnect from server. Please check network” is displayed (I´ve checked all the network connectio and it´s fine). Is there any compatibility problem between this device and TTN?
Local UDP port=1700, Connection successful
LoraWan Server : brazil.thethings.network, port: 1700
Have you read any of the messages above yours? Heltec successfully tested against V3. May-be you should try V3 as well as V2 will be schutdown later this year. Add new gateways to V3 to avoid having to migrate later this year.
Thank you so much for helping me in this issue. Changing to TTN V3 made my HT-M01S works like a charm. I got the message “Connect gateway” at the new V3 console interface and I´m now able to receive information from my gateway. I want to apologize for not reading the previous messages in this thread since I was in a hurry. Tks again.
