Hi there
has anyone written a payload decoder BME680 for the Multisensor Example from Heltec ?
thanks a lot
Hi there
thanks a lot
You mean something like this:
var decoded = {};
// if (port === 1) decoded.led = bytes[0];
decoded.Temperature = (bytes[1] << 8) + bytes[0];
decoded.Temperature=decoded.Temperature/100.0
decoded.Pressure = (bytes[3] << 8) + bytes[2];
decoded.Humidity = (bytes[5] << 8) + bytes[4];
decoded.Humidity=decoded.Humidity/100.0
return decoded;
This converts bytes “01 02 03 04 05 06” to 2 bytes = Temperature, next 2 bytes to Pressure and the final 2 bytes to Humidity.
Naming the return variables like decode.xxx wil return a json object that has this xxx=value.
I may have misunderstood the question.
Are you referring to the payload bytes sent from the sensor to the loRaWan gateway and to be decoded in your application?
Or are you referring how to read the sensor data on the Heltec Cube Cell Decoder and convert this to the LoRaWan payload to be transmitted?
exactly
i refer to the data sent by the cubecell to be decoded within the TTN
Beware that this does not support negative values.
That is an extremely valid point! Negative values
