Hi, I am getting a “Failed to send webhook” error that shows on the “Live Data” section of my end node.
This happens after an uplink of a 200 byte payload, I can see the values on the “Live Data” but nothing gets stored on my webhook. For my webhook I am using a custom template, with JSON format and no Downlink API key.
Does anyone know if this error relates to the webhook configuration? I have been able to store smaller payloads on this same webhook.
Here is the error metadata:
"name": "as.webhook.fail",
"time": "2021-11-10T07:35:16.575491631Z",
"identifiers": [
"device_ids": {
"device_id": "test-node-v2",
"application_ids": {
"application_id": "stm32wl-test-applications"
"device_ids": {
"dev_eui": "8080E1150500B78D",
"join_eui": "0101010101010101",
"dev_addr": "260DCAAE"
"data": {
"namespace": "pkg/applicationserver/io/web",
"name": "request",
"message_format": "request",
"correlation_id": "83ba66983a43440e854c38ee4c448f37",
"code": 14,
"details": [
"@type": "type.googleapis.com/google.protobuf.Struct",
"value": {
"body": "Failed storing dump\n",
"status_code": 500,
"url": "http://ptsv2.com/t/zkudc-1620192826/post",
"webhook_id": "test-app-webhook"
"correlation_ids": [
"as:up:01FM4CBEJRG7EMRDTJ0C8MK39E",
"gs:conn:01FM2REF0E24B6JQP555E0EZ5J",
"gs:up:host:01FM2REF8XEK52VBNSQ5YFF88Y",
"gs:uplink:01FM4CBEC5DH39H7372NR58VA5",
"ns:uplink:01FM4CBEC7FTSC8XZDQ65ZKYWG",
"rpc:/ttn.lorawan.v3.GsNs/HandleUplink:01FM4CBEC7X8530Z08NY5BFE6W",
"rpc:/ttn.lorawan.v3.NsAs/HandleUplink:01FM4CBEJQN86JR5J7XN2C9CR1"
"origin": "ip-10-102-14-148.ap-southeast-2.compute.internal",
"context": {
"tenant-id": "CgN0dG4="
"visibility": {
"rights": [
"RIGHT_APPLICATION_TRAFFIC_READ",
"unique_id": "01FM4CBFAZXVT7XAS8H0P54R1S"
Cheers,
