I’m curious to understand how the provisioning of this sensor work.
The pdf linked in that web page say (pag.7):
Commands to Level Monitor
_Key parameters are stored on the device in non-volatile memory. The value of these parameters can be changed using a downlink, i.e. data (commands) sent to the device from the network server. _
All data is sent in hexadecimal and should be directed to port 5.
On data being sent to the device, it is acknowledged by the devic…bla bla bla
my doubt is… how can I send a downlink message to this sensor to set all join parameters of the node… if the node itself is not already joined to the network??
Alex
