During first semester 2021 ( up to may), I have registered LG01 GW on TTN, and device, region europe and with the server router.eu.thethings.network. We have updated the MCU with the MCU version single_pkt_fwd_v002The configuration was running correctly, we observe the ED traffic on TTN , and add the decoder, no problem.
After TTN changes ( V2 to V3 I think) , the GW disappear . So I have re-registered them, changing the adress of the server (still in europe :eu1.cloud.thethings.network) in the configuration of the Dragino. no other modifications
However, the 2 GW appear always disconnected.
So I do not see what is wrong ? Do we have also to upgrade the MCU of the LG01 GW ?
If somebody can help me ?Thanks , Fabienne
Thanks for your answer. Is it possible to update the MCU firmware of the LG01, I have LG01-P ?
I have used the LG01 upto may 2021 with TTN, and since they have changed ( and the GW registration disappear), and even I have re-registered the GW, the GW appear disconnected
F.
No, it does not have the correct hardware to be a fully compliant 8 channel gateway, please search the forum for Single Channel Packet Forwarder or SCPF. As @LoRaTracker has noted, the manufacturer says it should not be connected to TTN on the product page.
You will be disrupting the network by using it, please disconnect.
