I try to set up a lora connection through arduino nano 33ble sense and SX1278 LoRa Module 433MHz.
Through the registration of GATEWAY I see that for Europe (Greece) the only option is 868MHz.
Do you have any suggestion ?
Thank you,
P.A.
Thank you,
P.A.
My suggestion is that 433 MHz is not supported by TTN (V3) yet.
On the other hand EU433 is listed here: GitHub - TheThingsNetwork/lorawan-frequency-plans: LoRaWAN Frequency Plans for The Things Stack
A proposal could be 16 channels from 433.175 to 434.665 MHz, 200kHz channel spacing, 10 dBm ERP.
Do you have a gateway for 433MHz?
Thank you very much!!
to my knowledge, only 868MHz is supported. 433 is unsupported.
Thanks, I am going to try 868.
