How do i sent my position data that receive from gps module and display on my mobile application.
I think i will connect lora device with gps module and arduino board and then send position data to cloud server and send it to my mobile application that i make it, and display on google map.
Did i have going with a right way? Pls recommended me.
Very Thankful for everyone that interest my problem and sorry for my bad english skill.
Bike and tracker on bike.
can i update real time? or maybe 30 seconds.
i’m from Thailand and i think i will use CAT telecom(Lorawan Provider) for TTN gateways.
Yes. GW’s just ‘transparently’ forward all valid LoRaWAN messages received to the Network Server/Back End Application handling. If your sensor node/device is registered in TTN then messages won’t be dropped but instead will be forwarded to any Application or Storage Integration you have set up.
If you can contribute GW coverage great but if not it is an open network per the manifesto available to all. Please just be mindful of fair use and regulator policies wrt on air time, limiting downlinks, etc. Have fun!
