Go SDK can not connect to discovery server
I’m using the Go SDK to get a list of devices but the connection to the discovery server just hangs ‘forever’.
I also tried the Python SDK, but after 10 seconds I get a connection failure. (see below)
It does not seem to be a firewall/connectivity issue because running curl(1) returns a response.
$ curl -vv discovery.thethings.network:1900
* Rebuilt URL to: discovery.thethings.network:1900/
*   Trying 52.178.215.58...
* Connected to discovery.thethings.network (52.178.215.58) port 1900 (#0)
> GET / HTTP/1.1
> Host: discovery.thethings.network:1900
> User-Agent: curl/7.47.0
> Accept: */*
* Connection #0 to host discovery.thethings.network left intact
Below is the Python and Go code I’m testing with.
If anyone can help me diagnose the problem I’d appreciate it. I suspect a gRPC configuration error, but I’m not sure where to start looking and I can’t see anything obvious in /var/log
Thank you.
The following Python code returns a gRPC error - StatusCode.UNAVAILABLE,
$ python
Python 3.5.2 (default, Nov 17 2016, 17:05:23)
[GCC 5.4.0 20160609] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import time
>>> from ttn import MQTTClient as mqtt_client
>>> my_client = mqtt_client("wfs-sodaq-app","ttn-account-v2.7y48***************")
>>> my_client.connect()
Traceback (most recent call last):
  File "<stdin>", line 1, in <module>
  File "/home/ian/env/test/lib/python3.5/site-packages/ttn/ttnmqtt.py", line 110, in connect
    res = stub.GetByAppID(req)
  File "/home/ian/env/test/lib/python3.5/site-packages/grpc/_channel.py", line 484, in __call__
    return _end_unary_response_blocking(state, call, False, deadline)
  File "/home/ian/env/test/lib/python3.5/site-packages/grpc/_channel.py", line 434, in _end_unary_response_blocking
    raise _Rendezvous(state, None, None, deadline)
grpc._channel._Rendezvous: <_Rendezvous of RPC that terminated with (StatusCode.UNAVAILABLE, Connect Failed)>
For the Go code I get,
$ go run main.go
 DEBUG wfs-sodaq-app ttn-account-v2.7y48Aq*************************
 DEBUG here
 DEBUG ttn-sdk: Connecting to discovery...      Address=discovery.thethings.network:1900
and it never returns or raises any errors.
main.go - A copy of the first example in the SDK docs.
package main
import (
	"fmt"
	"os"
	ttnsdk "github.com/TheThingsNetwork/go-app-sdk"
	ttnlog "github.com/TheThingsNetwork/go-utils/log"
	"github.com/TheThingsNetwork/go-utils/log/apex"
const (
	sdkClientName = "my-amazing-app"
func main() {
	log := apex.Stdout() // We use a cli logger at Stdout
	log.MustParseLevel("debug")
	ttnlog.Set(log) // Set the logger as default for TTN
	// We get the application ID and application access key from the environment
	appID := os.Getenv("TTN_APP_ID")
	appAccessKey := os.Getenv("TTN_APP_ACCESS_KEY")
	log.Debug(appID + " " + appAccessKey)
	// Create a new SDK configuration for the public community network
	config := ttnsdk.NewCommunityConfig(sdkClientName)
	config.ClientVersion = "2.0.5" // The version of the application
	// Create a new SDK client for the application
	client := config.NewClient(appID, appAccessKey)
	// Make sure the client is closed before the function returns
	// In your application, you should call this before the application shuts down
	defer client.Close()
	log.Debug("here")
	// Manage devices for the application.
	devices, err := client.ManageDevices()
	if err != nil {
		log.WithError(err).Fatal("my-amazing-app: could not get device manager")
	log.Debug("here2")
	// List the first 10 devices
	deviceList, err := devices.List(10, 0)
	if err != nil {
		log.WithError(err).Fatal("my-amazing-app: could not get devices")
	log.Info("my-amazing-app: found devices")
	for _, device := range deviceList {
		fmt.Printf("- %s", device.DevID)
Have you found any solution for this?
Yes - don’t use Virgin Business Broadband :slight_smile:
Seriously - the problem was down to the Internet connection blocking TLS responses (?) I sent Wireshark traces etc. but they were not helpful.
The same code on my home broadband and AWS servers worked perfectly.
see
