On the Generic Node v1.1 the VCC and GND labels are reversed on PCB bottom side
For GNSE v1.1 be aware that two pins are incorrectly labeled in the silkscreen on the bottom side of the PCB:
For the connector that also contains the TxD and RxD pins, the labels of the GND and VCC pins are reversed on bottom side of the PCB. The labels of GND and VCC pins of the other connector (that also contains the PA11 pin) are correct.
The labels on top side of the PCB are correct so use the labels on the top side.
