Hola. Estoy intentando hacer un GateWay. Uso LoraWAN1300. Como se puede conectarse al gateWay para después ir a aplicación? No puedo encotrar la información el Internet. Gracias.
Hi there, by agreement all posts must be in English, even if you use Google Translate, but you can put your original text in place. You must repost with the English translation please.
‘descartes’ was actually French, I’m English but I speak enough Spanish to tell you that the Arduino MKRWAN 1300 is a device. If you don’t have a gateway near by, you will need your own gateway. You can not use it as a gateway, they are very different.
I’m surprised that you can’t find information on the internet for setting up the MKRWAN - Arduino has a tutorial.
You can learn about LoRaWAN by following the Learn link at the top of the page.
This is also a thread hijack and is unrelated to your issue. So moving …
PS, Forum search will reveal resources on the MKRWAN as well
