Gateways (x4) not appearing on map
We have four gateways which are not appearing on the map:
  • eui-008000000000c4c8 (Heptonstall)
  • eui-00800000a00009a7 (Tenterfields)
  • eui-00800000a00009a9 (Hebble End)
  • eui-00800000a0000eaf (Wainhouse Tower)
All are connected fine and forwarding traffic. Tried deleting and recreating, to no avail.
Any ideas?
EDIT: wondering if it’s related to:
Gateway disappeared on the map
@dodo @htdvisser ?
Hi Andrew,
I fixed it, can you check ?
Bests,
Dorian
Hi Dorian,
Brilliant, thanks!
Does this mean gateways using the legacy protocol may need to be manually added now (seemed OK with MP forwarder)? Or was it just temporary glitch?
Best,
Andrew
I noticed that the Wainhouse Tower gateway (eui-00800000a0000eaf) isn’t appearing on TTN mapper anymore. Is it having the same problem again? I’m receiving packets via this gateway so it seems to be up and running.
Phil
