I am working with my gateway Waveshare SX1302_HAL, STM32WLE5 end-device, TTS Sandbox. The gateway library is GitHub - Lora-net/sx1302_hal: SX1302/SX1303 Hardware Abstraction Layer and Tools (packet forwarder...). The uplink and downlink RX1 work fine. However, when trying to send downlink RX2 in freq 869.525MHz, the gateway reboots itself unexpectedly. This downlink eventually still reaches the end-node but the packet forwarder does not work anymore.
Can you help me with this issue?
Thanks in advance.
Which platform are you using it with? A Pi? Which model?
Where you say
Have you tried with all SF’s? and long payloads?
If you are testing and close likely node running SF7/8?
My initial suspicion would be a PSU issue especially if using are e.g. later/higher powered Pi and with marginal supply.
Tx sucks juice and a long payload (what is the SF9 RX2 downlink payload?) may be just enough to tip over the edge as SF9 ~2-4x ToA c/w lower SF’s and PSU may be sagging, esp if Txing at full power.
Try better PSU, test all SF’s for RX1 and push to limits to see if repeatable…
Many thanks to @Jeff-UK@kersing.
It’s true that the problem comes from power supply. In the global_conf.json file, I reduced the maximum value of rf_power from 27 to 24. It means that even though the packet sent from TTN with power 27dbm, the gateway finally transmits it to end nodes with 24dbm. It works fine for now. But the problem might be raised in the future.
To be sure, I have some question:
How TTN decides the power of a downlink pkt?
Is there any way for my gateway (or Raspberry) can suffer higher power (even more than 27 dbm)?
You can’t set it for a specific frequency. Just update the global lookup table that is used to translate the LNS settings to the gateway specific hardware.
So in terms of LoRaWAN, for anyone coming at this from a Google search, the potential higher output on 869.525 is somewhat academic.
Particularly if combined with the imbalance in the send / receive power - a gateway with a good antenna may hear a device right at the limit of the devices capabilities, facilitate a join because it can boom out the join accept, but on a typical day, the device isn’t being heard.
