I would like to get into ttn.
I bought 2 ttgo t-beam for the sensors and an SX1262 module for the raspberry (https://www.amazon.fr/Waveshare-Multi-Level-Configuration-Fixed-Point-Transmission/dp/B07VQZ5ZXY ) in order to make the gateway.
Despite all my research and testing, I can’t connect it to ttn. It always appears offline.
Does it work with the SX1262? Can you help me?
Thanking you,
Olivier
kersing
(Jac Kersing)
June 13, 2021, 4:01pm
2
An sx1262 can not be used to create a LoRaWAN compatible gateway. You need a LoRaWAN compliant concentrator board for that purpose. Or (cheaper) get yourself a TTIG.
Thank you for your reply.
Okay. Too bad.
Can I use it to make a device?
descartes
(Nick McCloud)
June 13, 2021, 6:43pm
4
Yes, but you will need to keep the load on your Pi to a minimum when it is active so that it can meet it’s timing deadlines.
Thank for your answer.
With a TTGO T-BEAM, can i do a gateway ?
descartes
(Nick McCloud)
June 15, 2021, 3:41pm
6
Absolutely not - it only has a single radio chip and a gateway has the equivalent of eight.
You may see software that claims it can make a gateway, but it’s not and it causes all sorts of problems.
Okay I see.
What can you advise me as a gateway? Not too expensive ?
descartes
(Nick McCloud)
June 15, 2021, 3:45pm
8
TTIG or Dragino LIG16 - search the forum for recent posts.
