Dears,
I’m facing a problem with my Gateway based on Semtech PicoCell chip.
On TTN Dashboard I see it as Not Connected, but when I launch the packet forwarder I see on console:
INFO: [up] PUSH_ACK received in 36 ms
INFO: [down] PULL_ACK received in 35 ms
INFO: [down] PULL_ACK received in 34 ms
I had properly configured:
“server_address”: “router.eu.thethings.network”,
“serv_port_up”: 1700,
“serv_port_down”: 1700
and
“gateway_ID” with information provided on TTN dashboard.
Could You kindly give me some suggestion?
Thanks,
Giorgio
I’m guessing that you’re using a generic Semtech packet forwarder implementation. Did you make sure you selected the “legacy” option when registering your gateway?
Hi Eelviny,
I choose LEGACY option for sure.
The DevEUI is the 8 bytes provided by semtech chip itself.
I can suppose that when I use the global_conf file You linked, I also have to add
“gateway_ID”: “eui-3037343253002600” where 3037… are the 8 bytes Semtech chip provides me ad EUI.
