I have a problem with the correct working of this gateway.
Gateway Lorank 8
BeagleBoard.org Debian Image 2016-05-13
Linux lorank8 4.4.9-ti-r25 #1 SMP Thu May 5 23:08:13 UTC 2016 armv7l GNU/Linux
running Poly-packet forwarder,
TTN entry in global_conf.json:
{ “server_address”: “router.eu.thethings.network”,
“serv_port_up”: 1700,
“serv_port_down”: 1700,
and: “stat_format”: “semtech”,
added in local_conf.json:
“gps”: true,
“fake_gps”: true,
Frequency Plan : Europe868MHz
Router; ttn-router-eu
Starting poly_pkt_fwd in foreground:
##### 2018-08-23 18:46:40 GMT #####
### [UPSTREAM] ###
# RF packets received by concentrator: 2
# CRC_OK: 100.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
# RF packets forwarded: 2 (104 bytes)
# PUSH_DATA datagrams sent: 3 (816 bytes)
# PUSH_DATA acknowledged: 0.00%
### [DOWNSTREAM] ###
# PULL_DATA sent: 3 (0.00% acknowledged)
# TX errors: 0
### BEACON IS DISABLED!
### [JIT] ###
# INFO: JIT queue contains 0 packets.
# INFO: JIT queue contains 0 beacons.
### [GPS] ###
# No time keeping possible due to fake gps.
# Manual GPS coordinates: latitude 51.41279, longitude 5.47990, altitude 18 m
### [PERFORMANCE] ###
# Upstream radio packet quality: 100.00%.
# Upstream datagram acknowledgment quality for server "52.18.106.103" is 0.00%.
# Upstream datagram acknowledgment quality for server "router.eu.thethings.network" is 0.00%.
# Downstream heart beat acknowledgment quality for server "52.18.106.103" is 0.00%.
# Downstream heart beat acknowledgment quality for server "router.eu.thethings.network" is 0.00%.
# Downstream datagram content quality for server "52.18.106.103" is 0.00%.
# Downstream datagram content quality for server "router.eu.thethings.network" is 0.00%.
# Downstream radio transmission quality for server "52.18.106.103" is 0.00%.
# Downstream radio transmission quality for server "router.eu.thethings.network" is 0.00%.
# Semtech status report send.
##### END #####
This gateway has a static IP address and has recently been registered.
The status remains “not connected”, and although it seems that data is forwarded, it is not visible at the TTN Console.
The gateway is visible on http://noc.thethingsnetwork.org: and I can ping to 8.8.8.8 (google) but tracroute gives:
root@lorank8:~# traceroute www.google.com
www.google.com: Name or service not known
I created a dns-nameservers 8.8.8.8 8.8.4.4 entry in /etc/network/interfaces but that had no effect
Is this a DNS issue? Does anyone have an idea how I can solve this?
Kind regard,
Marco
