Gateway receive uplink message but there is no activity in application
hye, im new to this lora…i hope no one judge me,
my problem is that my device for application is on and my gateway have receive the uplink message from the device, but when i look at the end device section, the last activity shown about few hours…
gateway
this is from the gateway show it receive the uplink message from the end device
last activity end device
this is the end device status that there are not activity receive in 7 hours
can someone help me fix this problem?
Are you sure this is your device and registered in TTN?
FF start - so ABP vs OTAA? Not an experimental node address - 00/01 xx xx xx?
& WTF are you doing wrt TX repetition rate and duty cycles etc…W A Y too often and even with no payload and on SF7 likely a massive abuse of the airwaves and FUP…No duty cycle self limiting from node? Where in the world are you? Malaysia? Think TX rep in the order of minutes and hours not second/seconds!
Need more info - what are the downlinks in live data? What are RSSI & SNR values? what GW? (I assume you got your RAK2245+RPi4b working ok?) What do device and GW logs show?
thanks for the awesome information.
