I have several Laird Gateways that are connected and endpoints are communicating, but the gateway is hidden in the “Gateways” section. How do I unhide these?
What do you mean by hidden?
Did you add the gateways yourself? Did you add a collaborator to the gateways? Did you modify your own rights (in the collaborator menu)?
Or did you even more them over from v2, because if you didn’t, they will still be working but not listed in the v3 console because you haven’t moved them over.
