Gateway not connected to the ttn_console
Hi All
I am new to lorawan and ttn server . I am facing an issue . I am using RHF0M301+ RPI as a gateway .
I configured that gateway as per following link
https://www.thethingsnetwork.org/labs/story/seedstudio-lorawan-gateway-built-on-risinghf/step/install-to-connect#step-anchor
After doing all the steps as mentioned in above steps i am unable to connect my gateway with the ttn_console gateway . I am using the router.us.thethings.network US 902-928.With this region with loriot server i successfully connected my gateway but on ttn server facing the issue.local_conf.txt (429 Bytes) local_conf.txt (429 Bytes)
I have attached the log file , global_conf.json ,local_conf.json and image of ttn_console .
Thanks in advance for the help .
us_global_json.txt (4.3 KB) gateway_console_ttn logfile.txt (4.9 KB)
I’m a new user since 6 months and the gateway connected to
ttn-router-us-west was working very well, but since 2 days a is is sporadict……
For now I’m off…
Paul
Hi Paul
Thanks for the response , do you mean to say its the ttn-router issue ? I have also changed it to AU but same issue . Have you seen my attached files ? Have you seen any thing wrong in the files .
Usman
Key is: does it work?
See also Gateway is shown as "not connected" but works!?
Sorry I need to learn how to manage the forum.Yes its US router.The files when I received are okay I haven’t received
I’m on line now
Paul
Last hour, gateway not connected on console, but all the data is in the data base.!!!
Follow the link given above, this is a known issue.
Thanks to all ,
For the help , i will look into it and update the results soon .
Thank You !
Hi All
Thanks for the help , today i reinstalledconnected the OS and all the packages again .Now successfully connected . I have attached the image .
BR
Usman
See: TTN Console not working properly all the time
