Gateway not connected Rak833
linaro@tinkerboard011:/opt/iotloragateway$ ./mp_pkt_fwd
18:28:33  *** Multi Protocol Packet Forwarder for Lora Gateway ***
Version: 3.0.20
18:28:33  *** Lora concentrator HAL library version info ***
Version: 5.0.1; Options: native;
18:28:33  INFO: Little endian host
18:28:33  INFO: found global configuration file /opt/iotloragateway/global_conf.json, parsing it
18:28:33  INFO: /opt/iotloragateway/global_conf.json does contain a JSON object named SX1301_conf, parsing SX1301 parameters
18:28:33  INFO: lorawan_public 1, clksrc 1
18:28:33  INFO: no configuration for LBT
18:28:33  INFO: antenna_gain 0 dBi
18:28:33  INFO: Configuring TX LUT with 16 indexes
18:28:33  INFO: radio 0 enabled (type SX1257), center frequency 917200000, RSSI offset -166.000000, tx enabled 1
18:28:33  INFO: radio 1 enabled (type SX1257), center frequency 917900000, RSSI offset -166.000000, tx enabled 0
18:28:33  INFO: Lora multi-SF channel 0>  radio 0, IF -400000 Hz, 125 kHz bw, SF 7 to 12
18:28:33  INFO: Lora multi-SF channel 1>  radio 0, IF -200000 Hz, 125 kHz bw, SF 7 to 12
18:28:33  INFO: Lora multi-SF channel 2>  radio 0, IF 0 Hz, 125 kHz bw, SF 7 to 12
18:28:33  INFO: Lora multi-SF channel 3>  radio 0, IF 200000 Hz, 125 kHz bw, SF 7 to 12
18:28:33  INFO: Lora multi-SF channel 4>  radio 1, IF -300000 Hz, 125 kHz bw, SF 7 to 12
18:28:33  INFO: Lora multi-SF channel 5>  radio 1, IF -100000 Hz, 125 kHz bw, SF 7 to 12
18:28:33  INFO: Lora multi-SF channel 6>  radio 1, IF 100000 Hz, 125 kHz bw, SF 7 to 12
18:28:33  INFO: Lora multi-SF channel 7>  radio 1, IF 300000 Hz, 125 kHz bw, SF 7 to 12
18:28:33  INFO: Lora std channel> radio 0, IF 300000 Hz, 500000 Hz bw, SF 8
18:28:33  INFO: FSK channel 8 disabled
18:28:33  INFO: /opt/iotloragateway/global_conf.json does contain a JSON object named gateway_conf, parsing gateway parameters
18:28:33  INFO: Found 1 servers in array.
18:28:33  INFO: Server 0 configured to "thethings.meshed.com.au"
18:28:33  INFO: packets received with a valid CRC will be forwarded
18:28:33  INFO: packets received with a CRC error will NOT be forwarded
18:28:33  INFO: packets received with no CRC will NOT be forwarded
18:28:33  INFO: GPS is disabled
18:28:33  INFO: Upstream data is enabled
18:28:33  INFO: Downstream data is enabled
18:28:33  INFO: Ghoststream data is disabled
18:28:33  INFO: Radiostream data is enabled
18:28:33  INFO: Statusstream data is enabled
18:28:33  INFO: Beacon is disabled
18:28:33  INFO: Packet logger is disabled
18:28:33  INFO: Flush output after statistic is disabled
18:28:33  INFO: Flush after each line of output is disabled
18:28:33  INFO: Watchdog is disabled
18:28:33  INFO: found local configuration file /opt/iotloragateway/local_conf.json, parsing it
18:28:33  INFO: redefined parameters will overwrite global parameters
18:28:33  INFO: /opt/iotloragateway/local_conf.json does not contain a JSON object named SX1301_conf
18:28:33  INFO: /opt/iotloragateway/local_conf.json does contain a JSON object named gateway_conf, parsing gateway parameters
18:28:33  INFO: gateway MAC address is configured to 0000000000000000
18:28:33  INFO: GPS serial port path is configured to "/dev/serial1"
18:28:33  INFO: Reference latitude is configured to -33.044258 deg
18:28:33  INFO: Reference longitude is configured to -71.373367 deg
18:28:33  INFO: Reference altitude is configured to 10 meters
18:28:33  INFO: Contact email configured to "jose.nunez@citysense.co"
18:28:33  INFO: Description configured to "Compile tutorial Teset"
18:28:33  INFO: [Transports] Initializing protocol for 1 servers
18:28:35  INFO: [TTN] server "thethings.meshed.com.au" connected
18:28:35  INFO: [main] Starting the concentrator
18:28:38  INFO: [main] concentrator started, radio packets can now be received.
18:28:38  INFO: JIT thread activated.
18:28:38  INFO: [up] Thread activated for all servers.
18:28:38  INFO: Disabling GPS mode for concentrator's counter...
18:28:38  INFO: host/sx1301 time offset=(1603315716s:303815µs) - drift=129739719µs
18:28:38  INFO: Enabling GPS mode for concentrator's counter.
2020-10-21 21:29:08 GMT #####
 [UPSTREAM] ###
 RF packets received by concentrator: 0
 CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
 RF packets forwarded: 0 (0 bytes)
 PUSH_DATA datagrams sent: 0 (0 bytes)
 PUSH_DATA acknowledged: 0.00%
 [DOWNSTREAM] ###
 PULL_DATA sent: 0 (0.00% acknowledged)
 PULL_RESP(onse) datagrams received: 0 (0 bytes)
 RF packets sent to concentrator: 0 (0 bytes)
 TX errors: 0
 BEACON IS DISABLED!
 [JIT] ###
 INFO: JIT queue contains 0 packets.
 INFO: JIT queue contains 0 beacons.
 GPS IS DISABLED!
 [PERFORMANCE] ###
 Upstream radio packet quality: 0.00%.
 [ CONNECTIONS ] ###
 thethings.meshed.com.au: Connected
 Semtech status report send.
 END #####
18:29:08  INFO: [TTN] thethings.meshed.com.au RTT 460
18:29:09  INFO: [TTN] send status success for thethings.meshed.com.au
18:29:38  INFO: Disabling GPS mode for concentrator's counter...
18:29:38  INFO: host/sx1301 time offset=(1603315729s:342324µs) - drift=13038509µs
18:29:38  INFO: Enabling GPS mode for concentrator's counter.
 2020-10-21 21:29:39 GMT #####
 [UPSTREAM] ###
 [DOWNSTREAM] ###
 TX errors: 0
 BEACON IS DISABLED!
 [JIT] ###
 GPS IS DISABLED!
 [PERFORMANCE] ###
 [ CONNECTIONS ] ###
 END #####
18:29:39  INFO: [TTN] thethings.meshed.com.au RTT 622
18:29:40  INFO: [TTN] send status success for thethings.meshed.com.au
 2020-10-21 21:30:10 GMT #####
 [UPSTREAM] ###
 [DOWNSTREAM] ###
 TX errors: 0
 BEACON IS DISABLED!
 [JIT] ###
 GPS IS DISABLED!
 [PERFORMANCE] ###
 [ CONNECTIONS ] ###
 END #####
18:30:10  INFO: [TTN] thethings.meshed.com.au RTT 570
18:30:10  INFO: [TTN] send status success for thethings.meshed.com.au
18:30:38  INFO: Disabling GPS mode for concentrator's counter...
18:30:38  INFO: host/sx1301 time offset=(1603315729s:344400µs) - drift=2076µs
18:30:38  INFO: Enabling GPS mode for concentrator's counter.
i am using a RAK833
Any help?
RAK833 is hardware, but this seems to be a software or Internet problem.
What software are you using? Is this RAK’s SD card image, or did you install components yourself?
RAK’s image has recently had problem with broken DNS, so you might see if you can ping random sites from the box.
Your log is a little confusing… at first glance it looks like it never got any push or pull acks from the server and so maybe gave up for lack of backhaul connectivity, but it also kind of looks like it never really sent anything towards the server.
Do you have any node running in range of the gateway? If not, it may be hard to validate…
It would be rather useful if you could tell us what you’ve got this attached to and what YOU think the problem is, there must be a reason you chucked a log at us.
MP forwarder doesn’t use the push/pull counters for the TTN transport. The message ‘18:29:09 INFO: [TTN] send status success for thethings.meshed.com.au’ shows it is talking to the backend alright.
