My Kickstarter gateway (firmware 1.0.8) has the status ‘Disconnected’ for a few days. I’m using the V3. Before that everything was OK (with the V3). I did a fresh reset and reconfigure the gateway but the third LED is fastly flashing (bad configuration).
That’s what I get with my serial monitor. I can see regularly an LGMD:Rejected packet (0x11)
error. Where can this error come from?
* The Things Network *
* G A T E W A Y *
Firmware name: AmazingAckermann, type: 0, version: 1.0.8, commit: 846da98b, timestamp: 1574945235
Bootloader revision: 2, commit: c463e87e, timestamp: 1519396960
Build time: Nov 28 2019 12:48:18
Reboot reason: 0x03
BOOT: (persisted info) 6F 72 72 65 01 03 DD 8F EA 84 27 2A F2 3B FF 3C
WIFI: Entering state 0
WIFI: Entering SCAN state 0
MAIN: Initialisation complete
LORA: Changing state from 0 to 0
MAIN: Leaving state 0
MAIN: Entering state 1
FLASH: Magic bytes found: wifi config present
FLASH: Magic bytes found: activation data present
FLASH: Magic bytes not found: no stored FOTA data present
FLASH: Loading Firmware Data
CNFG: (Firmware HASH (sha256)) FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
FLASH: Loading WiFi Data
CNFG: WiFi SSID: [REMOVED]
CNFG: WiFi key: ***
CNFG: WiFi conn_type: 1
CNFG: WiFi sec_type: 4
FLASH: Loading Activation Data
CNFG: Gateway ID: [REMOVED]
CNFG: Gateway Key: ***
CNFG: Account Server URL: https://eu1.cloud.thethings.network
CNFG: Locked: false
CNFG: Locked first time: true
MAIN: Leaving state 1
MAIN: Entering state 2
INET: State change to 0
LORA: Initialisation complete
LORA: Changing state from 0 to 1
WIFI: Entering state 1
ETH: IP Address: 0.0.0.0
WIFI: Entering state 2
WIFI: Disabling modules
Head magic match void: trying to free an already freed block, ignore
WIFI: Entering state 3
WIFI: Enabling modules for client
WIFI: Entering state 6
>WIFI: IP Address: 0.0.0.0
SNTP: State change from 0 to 1
INET: Gateway has Ethernet
INET: State change to 2
INET: Connected to a network, waiting for DHCP lease, checking validity with ping
SNTP: State change from 1 to 2
ETH: IP Address: 192.168.0.54
INET: State change to 3
INET: Ping probe
INET: Error sending probe on WiFi
INET: Ping response from PIC32INT, set as default
INET: State change to 4
LORA: Wait init complete, waiting for application.
LORA: Changing state from 1 to 2
SNTP: State change from 2 to 3
MON: SYS Stack size: 3967
MON: TCPIP Stack size: 3785
MON: APP Stack size: 8008
MON: LoRa Stack size: 3911
MON: heap usage: 179KB (188KB), free: 160KB
CB: SNTP: State change from 3 to 4
SNTP: State change from 4 to 5
SNTP: State change from 5 to 6
SNTP: State change from 6 to 7
INET: State change to 5
MAIN: Leaving state 2
MAIN: Entering state 3
CNFG: Load online user config state change to 4
HTTP: Close active socket 0
HTTP: Starting connection
MON: SYS Stack size: 3965
MON: TCPIP Stack size: 3759
MON: APP Stack size: 4215
MON: heap usage: 184KB (188KB), free: 155KB
MON: SYS Stack size: 3959
MON: heap usage: 185KB (188KB), free: 154KB
