So, I reset my gateway and connected everything according to the guide. Now the gateway keeps rapidly flashing green. And when I use the TTN console my node connects with a different gateway far away after some time. In TTN the gateway shows offline no traffic is passing. It is connected to wifi but not operating correctly what could be the problem?
In the The Things Network console. We first used it in TTI-console had a problem with a 5 minute timeout for device class C and wanted to test if it was the same on TTN-console.
So, I tried switching back to TTI. But the led keeps blinking rapidly green. Looks like it can’t connect to the LNS. I’ve searched the forum, the problems been known before but have not found a fix. Turning it on and off a couple of times could fix it, but hasn’t worked as of yet. Any ideas?
