Gateway disconnected after updated to V3
Hi all,
I have a gateway Model RAK7258. It worked well in the TTN V2. After being upgraded to V3, it works for a few minutes, then it is disconnected. The internet is ok. Here are some settings of the gateway:
These are some settings I think may be related to the problem. Other settings are all default. I will provide any necessary information.
Thanks.
Here are some system logs. I’m not sure if they are helpful.
Thu Sep 30 05:15:31 2021 user.notice lora_pkt_fwd[4664]: ### [UPSTREAM] ###
Thu Sep 30 05:15:31 2021 user.notice lora_pkt_fwd[4664]: # RF packets received by concentrator: 0
Thu Sep 30 05:15:31 2021 user.notice lora_pkt_fwd[4664]: # CRC_OK: 0.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Thu Sep 30 05:15:31 2021 user.notice lora_pkt_fwd[4664]: # RF packets forwarded: 0 (0 bytes)
Thu Sep 30 05:15:31 2021 user.notice lora_pkt_fwd[4664]: # PUSH_DATA datagrams sent: 1 (133 bytes)
Thu Sep 30 05:15:31 2021 user.notice lora_pkt_fwd[4664]: # PUSH_DATA acknowledged: 0.00
Thu Sep 30 05:15:31 2021 user.notice lora_pkt_fwd[4664]: ### [DOWNSTREAM] ###
Thu Sep 30 05:15:31 2021 user.notice lora_pkt_fwd[4664]: # PULL_DATA sent: 6 (0.00 acknowledged)
Thu Sep 30 05:15:31 2021 user.notice lora_pkt_fwd[4664]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 05:15:31 2021 user.notice lora_pkt_fwd[4664]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 05:15:31 2021 user.notice lora_pkt_fwd[4664]: # TX errors: 0
Thu Sep 30 05:15:31 2021 user.notice lora_pkt_fwd[4664]: # BEACON queued: 0
Thu Sep 30 05:15:31 2021 user.notice lora_pkt_fwd[4664]: # BEACON sent so far: 0
Thu Sep 30 05:15:31 2021 user.notice lora_pkt_fwd[4664]: # BEACON rejected: 0
Thu Sep 30 05:15:31 2021 user.notice lora_pkt_fwd[4664]: ### [JIT] ###
Thu Sep 30 05:15:31 2021 user.notice lora_pkt_fwd[4664]: # SX1301 time (PPS): 72961272, offset us 0
Thu Sep 30 05:15:31 2021 user.notice lora_pkt_fwd[4664]: ### [GPS] ###
Thu Sep 30 05:15:31 2021 user.notice lora_pkt_fwd[4664]: # Invalid time reference (age: 1632978931 sec)
Thu Sep 30 05:15:31 2021 user.notice lora_pkt_fwd[4664]: # no valid GPS coordinates available yet
Thu Sep 30 05:15:31 2021 user.notice lora_pkt_fwd[4664]: ##### END #####
Thu Sep 30 05:16:01 2021 user.notice lora_pkt_fwd[4664]:
2021-09-30 05:16:01 UTC
Thu Sep 30 05:16:01 2021 user.notice lora_pkt_fwd[4664]: ### [UPSTREAM] ###
Thu Sep 30 05:16:01 2021 user.notice lora_pkt_fwd[4664]: # RF packets received by concentrator: 0
Thu Sep 30 05:16:01 2021 user.notice lora_pkt_fwd[4664]: # CRC_OK: 0.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Thu Sep 30 05:16:01 2021 user.notice lora_pkt_fwd[4664]: # RF packets forwarded: 0 (0 bytes)
Thu Sep 30 05:16:01 2021 user.notice lora_pkt_fwd[4664]: # PUSH_DATA datagrams sent: 1 (133 bytes)
Thu Sep 30 05:16:01 2021 user.notice lora_pkt_fwd[4664]: # PUSH_DATA acknowledged: 0.00
Thu Sep 30 05:16:01 2021 user.notice lora_pkt_fwd[4664]: ### [DOWNSTREAM] ###
Thu Sep 30 05:16:01 2021 user.notice lora_pkt_fwd[4664]: # PULL_DATA sent: 6 (0.00 acknowledged)
Thu Sep 30 05:16:01 2021 user.notice lora_pkt_fwd[4664]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 05:16:01 2021 user.notice lora_pkt_fwd[4664]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 05:16:01 2021 user.notice lora_pkt_fwd[4664]: # SX1301 time (PPS): 72961272, offset us 0
Thu Sep 30 05:16:01 2021 user.notice lora_pkt_fwd[4664]: ### [GPS] ###
Thu Sep 30 05:16:01 2021 user.notice lora_pkt_fwd[4664]: # Invalid time reference (age: 1632978961 sec)
Thu Sep 30 05:16:01 2021 user.notice lora_pkt_fwd[4664]: # no valid GPS coordinates available yet
Thu Sep 30 05:16:01 2021 user.notice lora_pkt_fwd[4664]: ##### END #####
Thu Sep 30 05:16:31 2021 user.notice lora_pkt_fwd[4664]:
2021-09-30 05:16:31 UTC
Thu Sep 30 05:16:31 2021 user.notice lora_pkt_fwd[4664]: ### [UPSTREAM] ###
Thu Sep 30 05:16:31 2021 user.notice lora_pkt_fwd[4664]: # RF packets received by concentrator: 0
Thu Sep 30 05:16:31 2021 user.notice lora_pkt_fwd[4664]: # CRC_OK: 0.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Thu Sep 30 05:16:31 2021 user.notice lora_pkt_fwd[4664]: # RF packets forwarded: 0 (0 bytes)
Thu Sep 30 05:16:31 2021 user.notice lora_pkt_fwd[4664]: # PUSH_DATA datagrams sent: 1 (133 bytes)
Thu Sep 30 05:16:31 2021 user.notice lora_pkt_fwd[4664]: # PUSH_DATA acknowledged: 0.00
Thu Sep 30 05:16:31 2021 user.notice lora_pkt_fwd[4664]: ### [DOWNSTREAM] ###
Thu Sep 30 05:16:31 2021 user.notice lora_pkt_fwd[4664]: # PULL_DATA sent: 6 (0.00 acknowledged)
Thu Sep 30 05:16:31 2021 user.notice lora_pkt_fwd[4664]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 05:16:31 2021 user.notice lora_pkt_fwd[4664]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 05:16:31 2021 user.notice lora_pkt_fwd[4664]: # SX1301 time (PPS): 132960629, offset us 0
Thu Sep 30 05:16:31 2021 user.notice lora_pkt_fwd[4664]: ### [GPS] ###
Thu Sep 30 05:16:31 2021 user.notice lora_pkt_fwd[4664]: # Invalid time reference (age: 1632978991 sec)
Thu Sep 30 05:16:31 2021 user.notice lora_pkt_fwd[4664]: # no valid GPS coordinates available yet
Thu Sep 30 05:16:31 2021 user.notice lora_pkt_fwd[4664]: ##### END #####
Thu Sep 30 05:17:01 2021 user.notice lora_pkt_fwd[4664]:
2021-09-30 05:17:01 UTC
Thu Sep 30 05:17:01 2021 user.notice lora_pkt_fwd[4664]: ### [UPSTREAM] ###
Thu Sep 30 05:17:01 2021 user.notice lora_pkt_fwd[4664]: # RF packets received by concentrator: 1
Thu Sep 30 05:17:01 2021 user.notice lora_pkt_fwd[4664]: # CRC_OK: 0.00, CRC_FAIL: 100.00, NO_CRC: 0.00
Thu Sep 30 05:17:01 2021 user.notice lora_pkt_fwd[4664]: # RF packets forwarded: 0 (0 bytes)
Thu Sep 30 05:17:01 2021 user.notice lora_pkt_fwd[4664]: # PUSH_DATA datagrams sent: 1 (133 bytes)
Thu Sep 30 05:17:01 2021 user.notice lora_pkt_fwd[4664]: # PUSH_DATA acknowledged: 0.00
Thu Sep 30 05:17:01 2021 user.notice lora_pkt_fwd[4664]: ### [DOWNSTREAM] ###
Thu Sep 30 05:17:01 2021 user.notice lora_pkt_fwd[4664]: # PULL_DATA sent: 5 (0.00 acknowledged)
Thu Sep 30 05:17:01 2021 user.notice lora_pkt_fwd[4664]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 05:17:01 2021 user.notice lora_pkt_fwd[4664]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 05:17:01 2021 user.notice lora_pkt_fwd[4664]: # SX1301 time (PPS): 132960629, offset us 0
Thu Sep 30 05:17:01 2021 user.notice lora_pkt_fwd[4664]: ### [GPS] ###
Thu Sep 30 05:17:01 2021 user.notice lora_pkt_fwd[4664]: # Invalid time reference (age: 1632979021 sec)
Thu Sep 30 05:17:01 2021 user.notice lora_pkt_fwd[4664]: # no valid GPS coordinates available yet
Thu Sep 30 05:17:01 2021 user.notice lora_pkt_fwd[4664]: ##### END #####
Thu Sep 30 05:17:07 2021 user.crit lora_pkt_fwd[4664]: INFO: [down] the last 30 PULL_DATA were not ACKed, exiting application
Thu Sep 30 05:17:29 2021 daemon.info db[1494]: DataBase Backup
Thu Sep 30 05:17:31 2021 user.notice lora_pkt_fwd[4664]:
2021-09-30 05:17:31 UTC
Thu Sep 30 05:17:31 2021 user.notice lora_pkt_fwd[4664]: ### [UPSTREAM] ###
Thu Sep 30 05:17:31 2021 user.notice lora_pkt_fwd[4664]: # RF packets received by concentrator: 0
Thu Sep 30 05:17:31 2021 user.notice lora_pkt_fwd[4664]: # CRC_OK: 0.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Thu Sep 30 05:17:31 2021 user.notice lora_pkt_fwd[4664]: # RF packets forwarded: 0 (0 bytes)
Thu Sep 30 05:17:31 2021 user.notice lora_pkt_fwd[4664]: # PUSH_DATA datagrams sent: 1 (133 bytes)
Thu Sep 30 05:17:31 2021 user.notice lora_pkt_fwd[4664]: # PUSH_DATA acknowledged: 0.00
Thu Sep 30 05:17:31 2021 user.notice lora_pkt_fwd[4664]: ### [DOWNSTREAM] ###
Thu Sep 30 05:17:31 2021 user.notice lora_pkt_fwd[4664]: # PULL_DATA sent: 1 (0.00 acknowledged)
Thu Sep 30 05:17:31 2021 user.notice lora_pkt_fwd[4664]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 05:17:31 2021 user.notice lora_pkt_fwd[4664]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 05:17:31 2021 user.notice lora_pkt_fwd[4664]: # TX errors: 0
Thu Sep 30 05:17:31 2021 user.notice lora_pkt_fwd[4664]: # BEACON queued: 0
Thu Sep 30 05:17:31 2021 user.notice lora_pkt_fwd[4664]: # BEACON sent so far: 0
Thu Sep 30 05:17:31 2021 user.notice lora_pkt_fwd[4664]: # BEACON rejected: 0
Thu Sep 30 05:17:31 2021 user.notice lora_pkt_fwd[4664]: ### [JIT] ###
Thu Sep 30 05:17:31 2021 user.notice lora_pkt_fwd[4664]: # SX1301 time (PPS): 132960629, offset us 0
Thu Sep 30 05:17:31 2021 user.notice lora_pkt_fwd[4664]: ### [GPS] ###
Thu Sep 30 05:17:31 2021 user.notice lora_pkt_fwd[4664]: # Invalid time reference (age: 1632979051 sec)
Thu Sep 30 05:17:31 2021 user.notice lora_pkt_fwd[4664]: # no valid GPS coordinates available yet
Thu Sep 30 05:17:31 2021 user.notice lora_pkt_fwd[4664]: ##### END #####
Thu Sep 30 05:17:31 2021 user.warn lora_pkt_fwd[4664]: WARNING: failed to close GPS successfully
Thu Sep 30 05:17:31 2021 user.notice lora_pkt_fwd[4664]: INFO: concentrator stopped successfully
Thu Sep 30 05:17:31 2021 user.notice lora_pkt_fwd[4664]: INFO: Exiting packet forwarder program
Thu Sep 30 05:17:41 2021 user.notice lora_pkt_fwd[5239]: INFO: [main] concentrator started, packet can now be received
Thu Sep 30 05:18:23 2021 user.notice lora_pkt_fwd[5239]:
2021-09-30 05:18:23 UTC
Thu Sep 30 05:18:23 2021 user.notice lora_pkt_fwd[5239]: ### [UPSTREAM] ###
Thu Sep 30 05:18:23 2021 user.notice lora_pkt_fwd[5239]: # RF packets received by concentrator: 0
Thu Sep 30 05:18:23 2021 user.notice lora_pkt_fwd[5239]: # CRC_OK: 0.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Thu Sep 30 05:18:23 2021 user.notice lora_pkt_fwd[5239]: # RF packets forwarded: 0 (0 bytes)
Thu Sep 30 05:18:23 2021 user.notice lora_pkt_fwd[5239]: # PUSH_DATA datagrams sent: 0 (0 bytes)
Thu Sep 30 05:18:23 2021 user.notice lora_pkt_fwd[5239]: # PUSH_DATA acknowledged: 0.00
Thu Sep 30 05:18:23 2021 user.notice lora_pkt_fwd[5239]: ### [DOWNSTREAM] ###
Thu Sep 30 05:18:23 2021 user.notice lora_pkt_fwd[5239]: # PULL_DATA sent: 6 (0.00 acknowledged)
Thu Sep 30 05:18:23 2021 user.notice lora_pkt_fwd[5239]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 05:18:23 2021 user.notice lora_pkt_fwd[5239]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 05:18:23 2021 user.notice lora_pkt_fwd[5239]: # SX1301 time (PPS): 14349685, offset us 0
Thu Sep 30 05:18:23 2021 user.notice lora_pkt_fwd[5239]: ### [GPS] ###
Thu Sep 30 05:18:23 2021 user.notice lora_pkt_fwd[5239]: # Invalid time reference (age: 1632979103 sec)
Thu Sep 30 05:18:23 2021 user.notice lora_pkt_fwd[5239]: # no valid GPS coordinates available yet
Thu Sep 30 05:18:23 2021 user.notice lora_pkt_fwd[5239]: ##### END #####
Thu Sep 30 05:18:53 2021 user.notice lora_pkt_fwd[5239]:
2021-09-30 05:18:53 UTC
Thu Sep 30 05:18:53 2021 user.notice lora_pkt_fwd[5239]: ### [UPSTREAM] ###
Thu Sep 30 05:18:53 2021 user.notice lora_pkt_fwd[5239]: # RF packets received by concentrator: 0
Thu Sep 30 05:18:53 2021 user.notice lora_pkt_fwd[5239]: # CRC_OK: 0.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Thu Sep 30 05:18:53 2021 user.notice lora_pkt_fwd[5239]: # RF packets forwarded: 0 (0 bytes)
Thu Sep 30 05:18:53 2021 user.notice lora_pkt_fwd[5239]: # PUSH_DATA datagrams sent: 1 (133 bytes)
Thu Sep 30 05:18:53 2021 user.notice lora_pkt_fwd[5239]: # PUSH_DATA acknowledged: 0.00
Thu Sep 30 05:18:53 2021 user.notice lora_pkt_fwd[5239]: ### [DOWNSTREAM] ###
Thu Sep 30 05:18:53 2021 user.notice lora_pkt_fwd[5239]: # PULL_DATA sent: 6 (0.00 acknowledged)
Thu Sep 30 05:18:53 2021 user.notice lora_pkt_fwd[5239]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 05:18:53 2021 user.notice lora_pkt_fwd[5239]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 05:18:53 2021 user.notice lora_pkt_fwd[5239]: # SX1301 time (PPS): 74350017, offset us 0
Thu Sep 30 05:18:53 2021 user.notice lora_pkt_fwd[5239]: ### [GPS] ###
Thu Sep 30 05:18:53 2021 user.notice lora_pkt_fwd[5239]: # Invalid time reference (age: 1632979133 sec)
Thu Sep 30 05:18:53 2021 user.notice lora_pkt_fwd[5239]: # no valid GPS coordinates available yet
Thu Sep 30 05:18:53 2021 user.notice lora_pkt_fwd[5239]: ##### END #####
Thu Sep 30 05:19:23 2021 user.notice lora_pkt_fwd[5239]:
2021-09-30 05:19:23 UTC
Thu Sep 30 05:19:23 2021 user.notice lora_pkt_fwd[5239]: ### [UPSTREAM] ###
Thu Sep 30 05:19:23 2021 user.notice lora_pkt_fwd[5239]: # RF packets received by concentrator: 0
Thu Sep 30 05:19:23 2021 user.notice lora_pkt_fwd[5239]: # CRC_OK: 0.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Thu Sep 30 05:19:23 2021 user.notice lora_pkt_fwd[5239]: # RF packets forwarded: 0 (0 bytes)
Thu Sep 30 05:19:23 2021 user.notice lora_pkt_fwd[5239]: # PUSH_DATA datagrams sent: 1 (133 bytes)
Thu Sep 30 05:19:23 2021 user.notice lora_pkt_fwd[5239]: # PUSH_DATA acknowledged: 0.00
Thu Sep 30 05:19:23 2021 user.notice lora_pkt_fwd[5239]: ### [DOWNSTREAM] ###
Thu Sep 30 05:19:23 2021 user.notice lora_pkt_fwd[5239]: # PULL_DATA sent: 6 (0.00 acknowledged)
Thu Sep 30 05:19:23 2021 user.notice lora_pkt_fwd[5239]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 05:19:23 2021 user.notice lora_pkt_fwd[5239]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 05:19:23 2021 user.notice lora_pkt_fwd[5239]: # TX errors: 0
Thu Sep 30 05:19:23 2021 user.notice lora_pkt_fwd[5239]: # BEACON queued: 0
Thu Sep 30 05:19:23 2021 user.notice lora_pkt_fwd[5239]: # BEACON sent so far: 0
Thu Sep 30 05:19:23 2021 user.notice lora_pkt_fwd[5239]: # BEACON rejected: 0
Thu Sep 30 05:19:23 2021 user.notice lora_pkt_fwd[5239]: ### [JIT] ###
Thu Sep 30 05:19:23 2021 user.notice lora_pkt_fwd[5239]: # SX1301 time (PPS): 74350017, offset us 0
Thu Sep 30 05:19:23 2021 user.notice lora_pkt_fwd[5239]: ### [GPS] ###
Thu Sep 30 05:19:23 2021 user.notice lora_pkt_fwd[5239]: # Invalid time reference (age: 1632979163 sec)
Thu Sep 30 05:19:23 2021 user.notice lora_pkt_fwd[5239]: # no valid GPS coordinates available yet
Thu Sep 30 05:19:23 2021 user.notice lora_pkt_fwd[5239]: ##### END #####
Thu Sep 30 05:19:53 2021 user.notice lora_pkt_fwd[5239]:
2021-09-30 05:19:53 UTC
Thu Sep 30 05:19:53 2021 user.notice lora_pkt_fwd[5239]: ### [UPSTREAM] ###
Thu Sep 30 05:19:53 2021 user.notice lora_pkt_fwd[5239]: # RF packets received by concentrator: 0
Thu Sep 30 05:19:53 2021 user.notice lora_pkt_fwd[5239]: # CRC_OK: 0.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Thu Sep 30 05:19:53 2021 user.notice lora_pkt_fwd[5239]: # RF packets forwarded: 0 (0 bytes)
Thu Sep 30 05:19:53 2021 user.notice lora_pkt_fwd[5239]: # PUSH_DATA datagrams sent: 1 (133 bytes)
Thu Sep 30 05:19:53 2021 user.notice lora_pkt_fwd[5239]: # PUSH_DATA acknowledged: 0.00
Thu Sep 30 05:19:53 2021 user.notice lora_pkt_fwd[5239]: ### [DOWNSTREAM] ###
Thu Sep 30 05:19:53 2021 user.notice lora_pkt_fwd[5239]: # PULL_DATA sent: 6 (0.00 acknowledged)
Thu Sep 30 05:19:53 2021 user.notice lora_pkt_fwd[5239]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 05:19:53 2021 user.notice lora_pkt_fwd[5239]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 05:19:53 2021 user.notice lora_pkt_fwd[5239]: # TX errors: 0
Thu Sep 30 05:19:53 2021 user.notice lora_pkt_fwd[5239]: # BEACON queued: 0
Thu Sep 30 05:19:53 2021 user.notice lora_pkt_fwd[5239]: # BEACON sent so far: 0
Thu Sep 30 05:19:53 2021 user.notice lora_pkt_fwd[5239]: # BEACON rejected: 0
Thu Sep 30 05:19:53 2021 user.notice lora_pkt_fwd[5239]: ### [JIT] ###
Thu Sep 30 05:19:53 2021 user.notice lora_pkt_fwd[5239]: # SX1301 time (PPS): 134351722, offset us 0
Thu Sep 30 05:19:53 2021 user.notice lora_pkt_fwd[5239]: ### [GPS] ###
Thu Sep 30 05:19:53 2021 user.notice lora_pkt_fwd[5239]: # Invalid time reference (age: 1632979193 sec)
Thu Sep 30 05:19:53 2021 user.notice lora_pkt_fwd[5239]: # no valid GPS coordinates available yet
Thu Sep 30 05:19:53 2021 user.notice lora_pkt_fwd[5239]: ##### END #####
Thu Sep 30 05:20:23 2021 user.notice lora_pkt_fwd[5239]:
2021-09-30 05:20:23 UTC
Thu Sep 30 05:20:23 2021 user.notice lora_pkt_fwd[5239]: ### [UPSTREAM] ###
Thu Sep 30 05:20:23 2021 user.notice lora_pkt_fwd[5239]: # RF packets received by concentrator: 0
Thu Sep 30 05:20:23 2021 user.notice lora_pkt_fwd[5239]: # CRC_OK: 0.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Thu Sep 30 05:20:23 2021 user.notice lora_pkt_fwd[5239]: # RF packets forwarded: 0 (0 bytes)
Thu Sep 30 05:20:23 2021 user.notice lora_pkt_fwd[5239]: # PUSH_DATA datagrams sent: 1 (133 bytes)
Thu Sep 30 05:20:23 2021 user.notice lora_pkt_fwd[5239]: # PUSH_DATA acknowledged: 0.00
Thu Sep 30 05:20:23 2021 user.notice lora_pkt_fwd[5239]: ### [DOWNSTREAM] ###
Thu Sep 30 05:20:23 2021 user.notice lora_pkt_fwd[5239]: # PULL_DATA sent: 5 (0.00 acknowledged)
Thu Sep 30 05:20:23 2021 user.notice lora_pkt_fwd[5239]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 05:20:23 2021 user.notice lora_pkt_fwd[5239]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 05:20:23 2021 user.notice lora_pkt_fwd[5239]: # BEACON queued: 0
Thu Sep 30 05:20:23 2021 user.notice lora_pkt_fwd[5239]: # BEACON sent so far: 0
Thu Sep 30 05:20:23 2021 user.notice lora_pkt_fwd[5239]: # BEACON rejected: 0
Thu Sep 30 05:20:23 2021 user.notice lora_pkt_fwd[5239]: ### [JIT] ###
Thu Sep 30 05:20:23 2021 user.notice lora_pkt_fwd[5239]: # SX1301 time (PPS): 134351722, offset us 0
Thu Sep 30 05:20:23 2021 user.notice lora_pkt_fwd[5239]: ### [GPS] ###
Thu Sep 30 05:20:23 2021 user.notice lora_pkt_fwd[5239]: # Invalid time reference (age: 1632979223 sec)
Thu Sep 30 05:20:23 2021 user.notice lora_pkt_fwd[5239]: # no valid GPS coordinates available yet
Thu Sep 30 05:20:23 2021 user.notice lora_pkt_fwd[5239]: ##### END #####
Thu Sep 30 05:20:29 2021 user.crit lora_pkt_fwd[5239]: INFO: [down] the last 30 PULL_DATA were not ACKed, exiting application
Thu Sep 30 05:20:53 2021 user.notice lora_pkt_fwd[5239]:
2021-09-30 05:20:53 UTC
Thu Sep 30 05:20:53 2021 user.notice lora_pkt_fwd[5239]: ### [UPSTREAM] ###
Thu Sep 30 05:20:53 2021 user.notice lora_pkt_fwd[5239]: # RF packets received by concentrator: 0
Thu Sep 30 05:20:53 2021 user.notice lora_pkt_fwd[5239]: # CRC_OK: 0.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Thu Sep 30 05:20:53 2021 user.notice lora_pkt_fwd[5239]: # RF packets forwarded: 0 (0 bytes)
Thu Sep 30 05:20:53 2021 user.notice lora_pkt_fwd[5239]: # PUSH_DATA datagrams sent: 1 (133 bytes)
Thu Sep 30 05:20:53 2021 user.notice lora_pkt_fwd[5239]: # PUSH_DATA acknowledged: 0.00
Thu Sep 30 05:20:53 2021 user.notice lora_pkt_fwd[5239]: ### [DOWNSTREAM] ###
Thu Sep 30 05:20:53 2021 user.notice lora_pkt_fwd[5239]: # PULL_DATA sent: 1 (0.00 acknowledged)
Thu Sep 30 05:20:53 2021 user.notice lora_pkt_fwd[5239]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 05:20:53 2021 user.notice lora_pkt_fwd[5239]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 05:20:53 2021 user.notice lora_pkt_fwd[5239]: # TX errors: 0
Thu Sep 30 05:20:53 2021 user.notice lora_pkt_fwd[5239]: # BEACON queued: 0
Thu Sep 30 05:20:53 2021 user.notice lora_pkt_fwd[5239]: # BEACON sent so far: 0
Thu Sep 30 05:20:53 2021 user.notice lora_pkt_fwd[5239]: # BEACON rejected: 0
Thu Sep 30 05:20:53 2021 user.notice lora_pkt_fwd[5239]: ### [JIT] ###
Thu Sep 30 05:20:53 2021 user.notice lora_pkt_fwd[5239]: # SX1301 time (PPS): 134351722, offset us 0
Thu Sep 30 05:20:53 2021 user.notice lora_pkt_fwd[5239]: ### [GPS] ###
Thu Sep 30 05:20:53 2021 user.notice lora_pkt_fwd[5239]: # Invalid time reference (age: 1632979253 sec)
Thu Sep 30 05:20:53 2021 user.notice lora_pkt_fwd[5239]: # no valid GPS coordinates available yet
Thu Sep 30 05:20:53 2021 user.notice lora_pkt_fwd[5239]: ##### END #####
Thu Sep 30 05:20:53 2021 user.warn lora_pkt_fwd[5239]: WARNING: failed to close GPS successfully
Thu Sep 30 05:20:53 2021 user.notice lora_pkt_fwd[5239]: INFO: concentrator stopped successfully
Thu Sep 30 05:20:53 2021 user.notice lora_pkt_fwd[5239]: INFO: Exiting packet forwarder program
Thu Sep 30 05:21:03 2021 user.notice lora_pkt_fwd[5559]: INFO: [main] concentrator started, packet can now be received
Thu Sep 30 05:21:43 2021 user.notice lora_pkt_fwd[5559]:
2021-09-30 05:21:43 UTC
Thu Sep 30 05:21:43 2021 user.notice lora_pkt_fwd[5559]: ### [UPSTREAM] ###
Thu Sep 30 05:21:43 2021 user.notice lora_pkt_fwd[5559]: # RF packets received by concentrator: 0
Thu Sep 30 05:21:43 2021 user.notice lora_pkt_fwd[5559]: # CRC_OK: 0.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Thu Sep 30 05:21:43 2021 user.notice lora_pkt_fwd[5559]: # RF packets forwarded: 0 (0 bytes)
Thu Sep 30 05:21:43 2021 user.notice lora_pkt_fwd[5559]: # PUSH_DATA datagrams sent: 0 (0 bytes)
Thu Sep 30 05:21:43 2021 user.notice lora_pkt_fwd[5559]: # PUSH_DATA acknowledged: 0.00
Thu Sep 30 05:21:43 2021 user.notice lora_pkt_fwd[5559]: ### [DOWNSTREAM] ###
Thu Sep 30 05:21:43 2021 user.notice lora_pkt_fwd[5559]: # PULL_DATA sent: 6 (0.00 acknowledged)
Thu Sep 30 05:21:43 2021 user.notice lora_pkt_fwd[5559]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 05:21:43 2021 user.notice lora_pkt_fwd[5559]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 05:21:43 2021 user.notice lora_pkt_fwd[5559]: # SX1301 time (PPS): 12809324, offset us 0
Thu Sep 30 05:21:43 2021 user.notice lora_pkt_fwd[5559]: ### [GPS] ###
Thu Sep 30 05:21:43 2021 user.notice lora_pkt_fwd[5559]: # Invalid time reference (age: 1632979303 sec)
Thu Sep 30 05:21:43 2021 user.notice lora_pkt_fwd[5559]: # no valid GPS coordinates available yet
Thu Sep 30 05:21:43 2021 user.notice lora_pkt_fwd[5559]: ##### END #####
Thu Sep 30 05:22:13 2021 user.notice lora_pkt_fwd[5559]:
2021-09-30 05:22:13 UTC
Thu Sep 30 05:22:13 2021 user.notice lora_pkt_fwd[5559]: ### [UPSTREAM] ###
Thu Sep 30 05:22:13 2021 user.notice lora_pkt_fwd[5559]: # RF packets received by concentrator: 0
Thu Sep 30 05:22:13 2021 user.notice lora_pkt_fwd[5559]: # CRC_OK: 0.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Thu Sep 30 05:22:13 2021 user.notice lora_pkt_fwd[5559]: # RF packets forwarded: 0 (0 bytes)
Thu Sep 30 05:22:13 2021 user.notice lora_pkt_fwd[5559]: # PUSH_DATA datagrams sent: 1 (133 bytes)
Thu Sep 30 05:22:13 2021 user.notice lora_pkt_fwd[5559]: # PUSH_DATA acknowledged: 0.00
Thu Sep 30 05:22:13 2021 user.notice lora_pkt_fwd[5559]: ### [DOWNSTREAM] ###
Thu Sep 30 05:22:13 2021 user.notice lora_pkt_fwd[5559]: # PULL_DATA sent: 6 (0.00 acknowledged)
Thu Sep 30 05:22:13 2021 user.notice lora_pkt_fwd[5559]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 05:22:13 2021 user.notice lora_pkt_fwd[5559]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 05:22:13 2021 user.notice lora_pkt_fwd[5559]: # SX1301 time (PPS): 72809729, offset us 0
Thu Sep 30 05:22:13 2021 user.notice lora_pkt_fwd[5559]: ### [GPS] ###
Thu Sep 30 05:22:13 2021 user.notice lora_pkt_fwd[5559]: # Invalid time reference (age: 1632979333 sec)
Thu Sep 30 05:22:13 2021 user.notice lora_pkt_fwd[5559]: # no valid GPS coordinates available yet
Thu Sep 30 05:22:13 2021 user.notice lora_pkt_fwd[5559]: ##### END #####
Thu Sep 30 05:22:29 2021 daemon.info db[1494]: DataBase Backup
Thu Sep 30 05:22:43 2021 user.notice lora_pkt_fwd[5559]:
2021-09-30 05:22:43 UTC
Thu Sep 30 05:22:43 2021 user.notice lora_pkt_fwd[5559]: ### [UPSTREAM] ###
Thu Sep 30 05:22:43 2021 user.notice lora_pkt_fwd[5559]: # RF packets received by concentrator: 2
Thu Sep 30 05:22:43 2021 user.notice lora_pkt_fwd[5559]: # CRC_OK: 50.00, CRC_FAIL: 50.00, NO_CRC: 0.00
Thu Sep 30 05:22:43 2021 user.notice lora_pkt_fwd[5559]: # RF packets forwarded: 1 (19 bytes)
Thu Sep 30 05:22:43 2021 user.notice lora_pkt_fwd[5559]: # PUSH_DATA datagrams sent: 2 (335 bytes)
Thu Sep 30 05:22:43 2021 user.notice lora_pkt_fwd[5559]: # PUSH_DATA acknowledged: 0.00
Thu Sep 30 05:22:43 2021 user.notice lora_pkt_fwd[5559]: ### [DOWNSTREAM] ###
Thu Sep 30 05:22:43 2021 user.notice lora_pkt_fwd[5559]: # PULL_DATA sent: 6 (0.00 acknowledged)
Thu Sep 30 05:22:43 2021 user.notice lora_pkt_fwd[5559]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 05:22:43 2021 user.notice lora_pkt_fwd[5559]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 05:22:43 2021 user.notice lora_pkt_fwd[5559]: # TX errors: 0
Thu Sep 30 05:22:43 2021 user.notice lora_pkt_fwd[5559]: # BEACON queued: 0
Thu Sep 30 05:22:43 2021 user.notice lora_pkt_fwd[5559]: # BEACON sent so far: 0
Thu Sep 30 05:22:43 2021 user.notice lora_pkt_fwd[5559]: # BEACON rejected: 0
Thu Sep 30 05:22:43 2021 user.notice lora_pkt_fwd[5559]: ### [JIT] ###
Thu Sep 30 05:22:43 2021 user.notice lora_pkt_fwd[5559]: # SX1301 time (PPS): 72809729, offset us 0
Thu Sep 30 05:22:43 2021 user.notice lora_pkt_fwd[5559]: ### [GPS] ###
Thu Sep 30 05:22:43 2021 user.notice lora_pkt_fwd[5559]: # Invalid time reference (age: 1632979363 sec)
Thu Sep 30 05:22:43 2021 user.notice lora_pkt_fwd[5559]: # no valid GPS coordinates available yet
Thu Sep 30 05:22:43 2021 user.notice lora_pkt_fwd[5559]: ##### END #####
Thu Sep 30 05:23:13 2021 user.notice lora_pkt_fwd[5559]:
2021-09-30 05:23:13 UTC
Thu Sep 30 05:23:13 2021 user.notice lora_pkt_fwd[5559]: ### [UPSTREAM] ###
Thu Sep 30 05:23:13 2021 user.notice lora_pkt_fwd[5559]: # RF packets received by concentrator: 0
Thu Sep 30 05:23:13 2021 user.notice lora_pkt_fwd[5559]: # CRC_OK: 0.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Thu Sep 30 05:23:13 2021 user.notice lora_pkt_fwd[5559]: # RF packets forwarded: 0 (0 bytes)
Thu Sep 30 05:23:13 2021 user.notice lora_pkt_fwd[5559]: # PUSH_DATA datagrams sent: 1 (133 bytes)
Thu Sep 30 05:23:13 2021 user.notice lora_pkt_fwd[5559]: # PUSH_DATA acknowledged: 0.00
Thu Sep 30 05:23:13 2021 user.notice lora_pkt_fwd[5559]: ### [DOWNSTREAM] ###
Thu Sep 30 05:23:13 2021 user.notice lora_pkt_fwd[5559]: # PULL_DATA sent: 6 (0.00 acknowledged)
Thu Sep 30 05:23:13 2021 user.notice lora_pkt_fwd[5559]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 05:23:13 2021 user.notice lora_pkt_fwd[5559]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 05:23:13 2021 user.notice lora_pkt_fwd[5559]: # SX1301 time (PPS): 132810169, offset us 0
Thu Sep 30 05:23:13 2021 user.notice lora_pkt_fwd[5559]: ### [GPS] ###
Thu Sep 30 05:23:13 2021 user.notice lora_pkt_fwd[5559]: # Invalid time reference (age: 1632979393 sec)
Thu Sep 30 05:23:13 2021 user.notice lora_pkt_fwd[5559]: # no valid GPS coordinates available yet
Thu Sep 30 05:23:13 2021 user.notice lora_pkt_fwd[5559]: ##### END #####
Thu Sep 30 05:23:43 2021 user.notice lora_pkt_fwd[5559]:
2021-09-30 05:23:43 UTC
Thu Sep 30 05:23:43 2021 user.notice lora_pkt_fwd[5559]: ### [UPSTREAM] ###
Thu Sep 30 05:23:43 2021 user.notice lora_pkt_fwd[5559]: # RF packets received by concentrator: 0
Thu Sep 30 05:23:43 2021 user.notice lora_pkt_fwd[5559]: # CRC_OK: 0.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Thu Sep 30 05:23:43 2021 user.notice lora_pkt_fwd[5559]: # RF packets forwarded: 0 (0 bytes)
Thu Sep 30 05:23:43 2021 user.notice lora_pkt_fwd[5559]: # PUSH_DATA datagrams sent: 1 (133 bytes)
Thu Sep 30 05:23:43 2021 user.notice lora_pkt_fwd[5559]: # PUSH_DATA acknowledged: 0.00
Thu Sep 30 05:23:43 2021 user.notice lora_pkt_fwd[5559]: ### [DOWNSTREAM] ###
Thu Sep 30 05:23:43 2021 user.notice lora_pkt_fwd[5559]: # PULL_DATA sent: 5 (0.00 acknowledged)
Thu Sep 30 05:23:43 2021 user.notice lora_pkt_fwd[5559]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 05:23:43 2021 user.notice lora_pkt_fwd[5559]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 05:23:43 2021 user.notice lora_pkt_fwd[5559]: # TX errors: 0
Thu Sep 30 05:23:43 2021 user.notice lora_pkt_fwd[5559]: # BEACON queued: 0
Thu Sep 30 05:23:43 2021 user.notice lora_pkt_fwd[5559]: # BEACON sent so far: 0
Thu Sep 30 05:23:43 2021 user.notice lora_pkt_fwd[5559]: # BEACON rejected: 0
Thu Sep 30 05:23:43 2021 user.notice lora_pkt_fwd[5559]: ### [JIT] ###
Thu Sep 30 05:23:43 2021 user.notice lora_pkt_fwd[5559]: # SX1301 time (PPS): 132810169, offset us 0
Thu Sep 30 05:23:43 2021 user.notice lora_pkt_fwd[5559]: ### [GPS] ###
Thu Sep 30 05:23:43 2021 user.notice lora_pkt_fwd[5559]: # Invalid time reference (age: 1632979423 sec)
Thu Sep 30 05:23:43 2021 user.notice lora_pkt_fwd[5559]: # no valid GPS coordinates available yet
Thu Sep 30 05:23:43 2021 user.notice lora_pkt_fwd[5559]: ##### END #####
Thu Sep 30 05:23:49 2021 user.crit lora_pkt_fwd[5559]: INFO: [down] the last 30 PULL_DATA were not ACKed, exiting application
Thu Sep 30 05:24:13 2021 user.notice lora_pkt_fwd[5559]:
2021-09-30 05:24:13 UTC
Thu Sep 30 05:24:13 2021 user.notice lora_pkt_fwd[5559]: ### [UPSTREAM] ###
Thu Sep 30 05:24:13 2021 user.notice lora_pkt_fwd[5559]: # RF packets received by concentrator: 0
Thu Sep 30 05:24:13 2021 user.notice lora_pkt_fwd[5559]: # CRC_OK: 0.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Thu Sep 30 05:24:13 2021 user.notice lora_pkt_fwd[5559]: # RF packets forwarded: 0 (0 bytes)
Thu Sep 30 05:24:13 2021 user.notice lora_pkt_fwd[5559]: # PUSH_DATA datagrams sent: 1 (133 bytes)
Thu Sep 30 05:24:13 2021 user.notice lora_pkt_fwd[5559]: # PUSH_DATA acknowledged: 0.00
Thu Sep 30 05:24:13 2021 user.notice lora_pkt_fwd[5559]: ### [DOWNSTREAM] ###
Thu Sep 30 05:24:13 2021 user.notice lora_pkt_fwd[5559]: # PULL_DATA sent: 1 (0.00 acknowledged)
Thu Sep 30 05:24:13 2021 user.notice lora_pkt_fwd[5559]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 05:24:13 2021 user.notice lora_pkt_fwd[5559]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 05:24:13 2021 user.notice lora_pkt_fwd[5559]: # SX1301 time (PPS): 132810169, offset us 0
Thu Sep 30 05:24:13 2021 user.notice lora_pkt_fwd[5559]: ### [GPS] ###
Thu Sep 30 05:24:13 2021 user.notice lora_pkt_fwd[5559]: # Invalid time reference (age: 1632979453 sec)
Thu Sep 30 05:24:13 2021 user.notice lora_pkt_fwd[5559]: # no valid GPS coordinates available yet
Thu Sep 30 05:24:13 2021 user.notice lora_pkt_fwd[5559]: ##### END #####
Thu Sep 30 05:24:13 2021 user.warn lora_pkt_fwd[5559]: WARNING: failed to close GPS successfully
Thu Sep 30 05:24:13 2021 user.notice lora_pkt_fwd[5559]: INFO: concentrator stopped successfully
Thu Sep 30 05:24:13 2021 user.notice lora_pkt_fwd[5559]: INFO: Exiting packet forwarder program
Thu Sep 30 05:24:23 2021 user.notice lora_pkt_fwd[5679]: INFO: [main] concentrator started, packet can now be received
Thu Sep 30 05:25:04 2021 user.notice lora_pkt_fwd[5679]:
2021-09-30 05:25:03 UTC
Thu Sep 30 05:25:04 2021 user.notice lora_pkt_fwd[5679]: ### [UPSTREAM] ###
Thu Sep 30 05:25:04 2021 user.notice lora_pkt_fwd[5679]: # RF packets received by concentrator: 0
Thu Sep 30 05:25:04 2021 user.notice lora_pkt_fwd[5679]: # CRC_OK: 0.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Thu Sep 30 05:25:04 2021 user.notice lora_pkt_fwd[5679]: # RF packets forwarded: 0 (0 bytes)
Thu Sep 30 05:25:04 2021 user.notice lora_pkt_fwd[5679]: # PUSH_DATA datagrams sent: 0 (0 bytes)
Thu Sep 30 05:25:04 2021 user.notice lora_pkt_fwd[5679]: # PUSH_DATA acknowledged: 0.00
Thu Sep 30 05:25:04 2021 user.notice lora_pkt_fwd[5679]: ### [DOWNSTREAM] ###
Thu Sep 30 05:25:04 2021 user.notice lora_pkt_fwd[5679]: # PULL_DATA sent: 6 (0.00 acknowledged)
Thu Sep 30 05:25:04 2021 user.notice lora_pkt_fwd[5679]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 05:25:04 2021 user.notice lora_pkt_fwd[5679]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 05:25:04 2021 user.notice lora_pkt_fwd[5679]: ### [JIT] ###
Thu Sep 30 05:25:04 2021 user.notice lora_pkt_fwd[5679]: # SX1301 time (PPS): 12789902, offset us 0
Thu Sep 30 05:25:04 2021 user.notice lora_pkt_fwd[5679]: ### [GPS] ###
Thu Sep 30 05:25:04 2021 user.notice lora_pkt_fwd[5679]: # Invalid time reference (age: 1632979504 sec)
Thu Sep 30 05:25:04 2021 user.notice lora_pkt_fwd[5679]: # no valid GPS coordinates available yet
Thu Sep 30 05:25:04 2021 user.notice lora_pkt_fwd[5679]: ##### END #####
Thu Sep 30 05:25:34 2021 user.notice lora_pkt_fwd[5679]:
Thu Sep 30 05:25:34 2021 user.notice lora_pkt_fwd[5679]: ### [UPSTREAM] ###
Thu Sep 30 05:25:34 2021 user.notice lora_pkt_fwd[5679]: # RF packets received by concentrator: 1
Thu Sep 30 05:25:34 2021 user.notice lora_pkt_fwd[5679]: # CRC_OK: 0.00, CRC_FAIL: 100.00, NO_CRC: 0.00
Thu Sep 30 05:25:34 2021 user.notice lora_pkt_fwd[5679]: # RF packets forwarded: 0 (0 bytes)
Thu Sep 30 05:25:34 2021 user.notice lora_pkt_fwd[5679]: # PUSH_DATA datagrams sent: 1 (133 bytes)
Thu Sep 30 05:25:34 2021 user.notice lora_pkt_fwd[5679]: # PUSH_DATA acknowledged: 0.00
Thu Sep 30 05:25:34 2021 user.notice lora_pkt_fwd[5679]: ### [DOWNSTREAM] ###
Thu Sep 30 05:25:34 2021 user.notice lora_pkt_fwd[5679]: # PULL_DATA sent: 6 (0.00 acknowledged)
Thu Sep 30 05:25:34 2021 user.notice lora_pkt_fwd[5679]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 05:25:34 2021 user.notice lora_pkt_fwd[5679]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 05:25:34 2021 user.notice lora_pkt_fwd[5679]: # BEACON queued: 0
Thu Sep 30 05:25:34 2021 user.notice lora_pkt_fwd[5679]: # BEACON sent so far: 0
Thu Sep 30 05:25:34 2021 user.notice lora_pkt_fwd[5679]: # BEACON rejected: 0
Thu Sep 30 05:25:34 2021 user.notice lora_pkt_fwd[5679]: ### [JIT] ###
Thu Sep 30 05:25:34 2021 user.notice lora_pkt_fwd[5679]: # SX1301 time (PPS): 72790321, offset us 0
Thu Sep 30 05:25:34 2021 user.notice lora_pkt_fwd[5679]: ### [GPS] ###
Thu Sep 30 05:25:34 2021 user.notice lora_pkt_fwd[5679]: # Invalid time reference (age: 1632979534 sec)
Thu Sep 30 05:25:34 2021 user.notice lora_pkt_fwd[5679]: # no valid GPS coordinates available yet
Thu Sep 30 05:25:34 2021 user.notice lora_pkt_fwd[5679]: ##### END #####
Thu Sep 30 05:26:04 2021 user.notice lora_pkt_fwd[5679]:
2021-09-30 05:26:04 UTC
Thu Sep 30 05:26:04 2021 user.notice lora_pkt_fwd[5679]: ### [UPSTREAM] ###
Thu Sep 30 05:26:04 2021 user.notice lora_pkt_fwd[5679]: # RF packets received by concentrator: 0
Thu Sep 30 05:26:04 2021 user.notice lora_pkt_fwd[5679]: # CRC_OK: 0.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Thu Sep 30 05:26:04 2021 user.notice lora_pkt_fwd[5679]: # RF packets forwarded: 0 (0 bytes)
Thu Sep 30 05:26:04 2021 user.notice lora_pkt_fwd[5679]: # PUSH_DATA datagrams sent: 1 (133 bytes)
Thu Sep 30 05:26:04 2021 user.notice lora_pkt_fwd[5679]: # PUSH_DATA acknowledged: 0.00
Thu Sep 30 05:26:04 2021 user.notice lora_pkt_fwd[5679]: ### [DOWNSTREAM] ###
Thu Sep 30 05:26:04 2021 user.notice lora_pkt_fwd[5679]: # PULL_DATA sent: 6 (0.00 acknowledged)
Thu Sep 30 05:26:04 2021 user.notice lora_pkt_fwd[5679]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 05:26:04 2021 user.notice lora_pkt_fwd[5679]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 05:26:04 2021 user.notice lora_pkt_fwd[5679]: # TX errors: 0
Thu Sep 30 05:26:04 2021 user.notice lora_pkt_fwd[5679]: # BEACON queued: 0
Thu Sep 30 05:26:04 2021 user.notice lora_pkt_fwd[5679]: # BEACON sent so far: 0
Thu Sep 30 05:26:04 2021 user.notice lora_pkt_fwd[5679]: # BEACON rejected: 0
Thu Sep 30 05:26:04 2021 user.notice lora_pkt_fwd[5679]: ### [JIT] ###
Thu Sep 30 05:26:04 2021 user.notice lora_pkt_fwd[5679]: # SX1301 time (PPS): 72790321, offset us 0
Thu Sep 30 05:26:04 2021 user.notice lora_pkt_fwd[5679]: ### [GPS] ###
Thu Sep 30 05:26:04 2021 user.notice lora_pkt_fwd[5679]: # Invalid time reference (age: 1632979564 sec)
Thu Sep 30 05:26:04 2021 user.notice lora_pkt_fwd[5679]: # no valid GPS coordinates available yet
Thu Sep 30 05:26:04 2021 user.notice lora_pkt_fwd[5679]: ##### END #####
Thu Sep 30 05:26:34 2021 user.notice lora_pkt_fwd[5679]:
2021-09-30 05:26:34 UTC
Thu Sep 30 05:26:34 2021 user.notice lora_pkt_fwd[5679]: ### [UPSTREAM] ###
Thu Sep 30 05:26:34 2021 user.notice lora_pkt_fwd[5679]: # RF packets received by concentrator: 0
Thu Sep 30 05:26:34 2021 user.notice lora_pkt_fwd[5679]: # CRC_OK: 0.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Thu Sep 30 05:26:34 2021 user.notice lora_pkt_fwd[5679]: # RF packets forwarded: 0 (0 bytes)
Thu Sep 30 05:26:34 2021 user.notice lora_pkt_fwd[5679]: # PUSH_DATA datagrams sent: 1 (133 bytes)
Thu Sep 30 05:26:34 2021 user.notice lora_pkt_fwd[5679]: # PUSH_DATA acknowledged: 0.00
Thu Sep 30 05:26:34 2021 user.notice lora_pkt_fwd[5679]: ### [DOWNSTREAM] ###
Thu Sep 30 05:26:34 2021 user.notice lora_pkt_fwd[5679]: # PULL_DATA sent: 6 (0.00 acknowledged)
Thu Sep 30 05:26:34 2021 user.notice lora_pkt_fwd[5679]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 05:26:34 2021 user.notice lora_pkt_fwd[5679]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 05:26:34 2021 user.notice lora_pkt_fwd[5679]: # SX1301 time (PPS): 132790923, offset us 0
Thu Sep 30 05:26:34 2021 user.notice lora_pkt_fwd[5679]: ### [GPS] ###
Thu Sep 30 05:26:34 2021 user.notice lora_pkt_fwd[5679]: # Invalid time reference (age: 1632979594 sec)
Thu Sep 30 05:26:34 2021 user.notice lora_pkt_fwd[5679]: # no valid GPS coordinates available yet
Thu Sep 30 05:26:34 2021 user.notice lora_pkt_fwd[5679]: ##### END #####
Thu Sep 30 05:27:04 2021 user.notice lora_pkt_fwd[5679]:
2021-09-30 05:27:04 UTC
Thu Sep 30 05:27:04 2021 user.notice lora_pkt_fwd[5679]: ### [UPSTREAM] ###
Thu Sep 30 05:27:04 2021 user.notice lora_pkt_fwd[5679]: # RF packets received by concentrator: 0
Thu Sep 30 05:27:04 2021 user.notice lora_pkt_fwd[5679]: # CRC_OK: 0.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Thu Sep 30 05:27:04 2021 user.notice lora_pkt_fwd[5679]: # RF packets forwarded: 0 (0 bytes)
Thu Sep 30 05:27:04 2021 user.notice lora_pkt_fwd[5679]: # PUSH_DATA datagrams sent: 1 (133 bytes)
Thu Sep 30 05:27:04 2021 user.notice lora_pkt_fwd[5679]: # PUSH_DATA acknowledged: 0.00
Thu Sep 30 05:27:04 2021 user.notice lora_pkt_fwd[5679]: ### [DOWNSTREAM] ###
Thu Sep 30 05:27:04 2021 user.notice lora_pkt_fwd[5679]: # PULL_DATA sent: 5 (0.00 acknowledged)
Thu Sep 30 05:27:04 2021 user.notice lora_pkt_fwd[5679]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 05:27:04 2021 user.notice lora_pkt_fwd[5679]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 05:27:04 2021 user.notice lora_pkt_fwd[5679]: # SX1301 time (PPS): 132790923, offset us 0
Thu Sep 30 05:27:04 2021 user.notice lora_pkt_fwd[5679]: ### [GPS] ###
Thu Sep 30 05:27:04 2021 user.notice lora_pkt_fwd[5679]: # Invalid time reference (age: 1632979624 sec)
Thu Sep 30 05:27:04 2021 user.notice lora_pkt_fwd[5679]: # no valid GPS coordinates available yet
Thu Sep 30 05:27:04 2021 user.notice lora_pkt_fwd[5679]: ##### END #####
Thu Sep 30 05:27:09 2021 user.crit lora_pkt_fwd[5679]: INFO: [down] the last 30 PULL_DATA were not ACKed, exiting application
Thu Sep 30 05:27:29 2021 daemon.info db[1494]: DataBase Backup
Thu Sep 30 05:27:34 2021 user.notice lora_pkt_fwd[5679]:
2021-09-30 05:27:34 UTC
Thu Sep 30 05:27:34 2021 user.notice lora_pkt_fwd[5679]: ### [UPSTREAM] ###
Thu Sep 30 05:27:34 2021 user.notice lora_pkt_fwd[5679]: # RF packets received by concentrator: 0
Thu Sep 30 05:27:34 2021 user.notice lora_pkt_fwd[5679]: # CRC_OK: 0.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Thu Sep 30 05:27:34 2021 user.notice lora_pkt_fwd[5679]: # RF packets forwarded: 0 (0 bytes)
Thu Sep 30 05:27:34 2021 user.notice lora_pkt_fwd[5679]: # PUSH_DATA datagrams sent: 1 (133 bytes)
Thu Sep 30 05:27:34 2021 user.notice lora_pkt_fwd[5679]: # PUSH_DATA acknowledged: 0.00
Thu Sep 30 05:27:34 2021 user.notice lora_pkt_fwd[5679]: ### [DOWNSTREAM] ###
Thu Sep 30 05:27:34 2021 user.notice lora_pkt_fwd[5679]: # PULL_DATA sent: 1 (0.00 acknowledged)
Thu Sep 30 05:27:34 2021 user.notice lora_pkt_fwd[5679]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 05:27:34 2021 user.notice lora_pkt_fwd[5679]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 05:27:34 2021 user.notice lora_pkt_fwd[5679]: # TX errors: 0
Thu Sep 30 05:27:34 2021 user.notice lora_pkt_fwd[5679]: # BEACON queued: 0
Thu Sep 30 05:27:34 2021 user.notice lora_pkt_fwd[5679]: # BEACON sent so far: 0
Thu Sep 30 05:27:34 2021 user.notice lora_pkt_fwd[5679]: # BEACON rejected: 0
Thu Sep 30 05:27:34 2021 user.notice lora_pkt_fwd[5679]: ### [JIT] ###
Thu Sep 30 05:27:34 2021 user.notice lora_pkt_fwd[5679]: # SX1301 time (PPS): 132790923, offset us 0
Thu Sep 30 05:27:34 2021 user.notice lora_pkt_fwd[5679]: ### [GPS] ###
Thu Sep 30 05:27:34 2021 user.notice lora_pkt_fwd[5679]: # Invalid time reference (age: 1632979654 sec)
Thu Sep 30 05:27:34 2021 user.notice lora_pkt_fwd[5679]: # no valid GPS coordinates available yet
Thu Sep 30 05:27:34 2021 user.notice lora_pkt_fwd[5679]: ##### END #####
Thu Sep 30 05:27:34 2021 user.warn lora_pkt_fwd[5679]: WARNING: failed to close GPS successfully
Thu Sep 30 05:27:34 2021 user.notice lora_pkt_fwd[5679]: INFO: concentrator stopped successfully
Thu Sep 30 05:27:34 2021 user.notice lora_pkt_fwd[5679]: INFO: Exiting packet forwarder program
Thu Sep 30 05:27:35 2021 daemon.notice netifd: wan0 (1675): Sending renew…
Thu Sep 30 05:27:35 2021 daemon.notice netifd: wan0 (1675): Lease of 192.168.43.187 obtained, lease time 3599
Thu Sep 30 05:27:35 2021 user.notice ping-watchdog: wan0 apcli0 ifupdate
Thu Sep 30 05:27:44 2021 user.notice lora_pkt_fwd[5845]: INFO: [main] concentrator started, packet can now be received
Thu Sep 30 05:28:12 2021 kern.warn kernel: [ 1887.250000] da match,0xac1f09016282
Thu Sep 30 05:28:12 2021 daemon.info dnsmasq-dhcp[1632]: DHCPREQUEST(br-lan) 192.168.230.139 84:ef:18:4e:02:f5
Thu Sep 30 05:28:12 2021 daemon.info dnsmasq-dhcp[1632]: DHCPACK(br-lan) 192.168.230.139 84:ef:18:4e:02:f5 MY-PC
Thu Sep 30 05:28:25 2021 user.notice lora_pkt_fwd[5845]:
2021-09-30 05:28:25 UTC
Thu Sep 30 05:28:25 2021 user.notice lora_pkt_fwd[5845]: ### [UPSTREAM] ###
Thu Sep 30 05:28:25 2021 user.notice lora_pkt_fwd[5845]: # RF packets received by concentrator: 0
Thu Sep 30 05:28:25 2021 user.notice lora_pkt_fwd[5845]: # CRC_OK: 0.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Thu Sep 30 05:28:25 2021 user.notice lora_pkt_fwd[5845]: # RF packets forwarded: 0 (0 bytes)
Thu Sep 30 05:28:25 2021 user.notice lora_pkt_fwd[5845]: # PUSH_DATA datagrams sent: 0 (0 bytes)
Thu Sep 30 05:28:25 2021 user.notice lora_pkt_fwd[5845]: # PUSH_DATA acknowledged: 0.00
Thu Sep 30 05:28:25 2021 user.notice lora_pkt_fwd[5845]: ### [DOWNSTREAM] ###
Thu Sep 30 05:28:25 2021 user.notice lora_pkt_fwd[5845]: # PULL_DATA sent: 6 (0.00 acknowledged)
Thu Sep 30 05:28:25 2021 user.notice lora_pkt_fwd[5845]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 05:28:25 2021 user.notice lora_pkt_fwd[5845]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 05:28:25 2021 user.notice lora_pkt_fwd[5845]: # SX1301 time (PPS): 13608064, offset us 0
Thu Sep 30 05:28:25 2021 user.notice lora_pkt_fwd[5845]: ### [GPS] ###
Thu Sep 30 05:28:25 2021 user.notice lora_pkt_fwd[5845]: # Invalid time reference (age: 1632979705 sec)
Thu Sep 30 05:28:25 2021 user.notice lora_pkt_fwd[5845]: # no valid GPS coordinates available yet
Thu Sep 30 05:28:25 2021 user.notice lora_pkt_fwd[5845]: ##### END #####
Thu Sep 30 05:28:55 2021 user.notice lora_pkt_fwd[5845]:
2021-09-30 05:28:55 UTC
Thu Sep 30 05:28:55 2021 user.notice lora_pkt_fwd[5845]: ### [UPSTREAM] ###
Thu Sep 30 05:28:55 2021 user.notice lora_pkt_fwd[5845]: # RF packets received by concentrator: 0
Thu Sep 30 05:28:55 2021 user.notice lora_pkt_fwd[5845]: # CRC_OK: 0.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Thu Sep 30 05:28:55 2021 user.notice lora_pkt_fwd[5845]: # RF packets forwarded: 0 (0 bytes)
Thu Sep 30 05:28:55 2021 user.notice lora_pkt_fwd[5845]: # PUSH_DATA datagrams sent: 1 (133 bytes)
Thu Sep 30 05:28:55 2021 user.notice lora_pkt_fwd[5845]: # PUSH_DATA acknowledged: 0.00
Thu Sep 30 05:28:55 2021 user.notice lora_pkt_fwd[5845]: ### [DOWNSTREAM] ###
Thu Sep 30 05:28:55 2021 user.notice lora_pkt_fwd[5845]: # PULL_DATA sent: 6 (0.00 acknowledged)
Thu Sep 30 05:28:55 2021 user.notice lora_pkt_fwd[5845]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 05:28:55 2021 user.notice lora_pkt_fwd[5845]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 05:28:55 2021 user.notice lora_pkt_fwd[5845]: # SX1301 time (PPS): 73608750, offset us 0
Thu Sep 30 05:28:55 2021 user.notice lora_pkt_fwd[5845]: ### [GPS] ###
Thu Sep 30 05:28:55 2021 user.notice lora_pkt_fwd[5845]: # Invalid time reference (age: 1632979735 sec)
Thu Sep 30 05:28:55 2021 user.notice lora_pkt_fwd[5845]: # no valid GPS coordinates available yet
Thu Sep 30 05:28:55 2021 user.notice lora_pkt_fwd[5845]: ##### END #####
Thu Sep 30 05:29:25 2021 user.notice lora_pkt_fwd[5845]:
2021-09-30 05:29:25 UTC
Thu Sep 30 05:29:25 2021 user.notice lora_pkt_fwd[5845]: ### [UPSTREAM] ###
Thu Sep 30 05:29:25 2021 user.notice lora_pkt_fwd[5845]: # RF packets received by concentrator: 0
Thu Sep 30 05:29:25 2021 user.notice lora_pkt_fwd[5845]: # CRC_OK: 0.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Thu Sep 30 05:29:25 2021 user.notice lora_pkt_fwd[5845]: # RF packets forwarded: 0 (0 bytes)
Thu Sep 30 05:29:25 2021 user.notice lora_pkt_fwd[5845]: # PUSH_DATA datagrams sent: 1 (133 bytes)
Thu Sep 30 05:29:25 2021 user.notice lora_pkt_fwd[5845]: # PUSH_DATA acknowledged: 0.00
Thu Sep 30 05:29:25 2021 user.notice lora_pkt_fwd[5845]: ### [DOWNSTREAM] ###
Thu Sep 30 05:29:25 2021 user.notice lora_pkt_fwd[5845]: # PULL_DATA sent: 6 (0.00 acknowledged)
Thu Sep 30 05:29:25 2021 user.notice lora_pkt_fwd[5845]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 05:29:25 2021 user.notice lora_pkt_fwd[5845]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 05:29:25 2021 user.notice lora_pkt_fwd[5845]: # TX errors: 0
Thu Sep 30 05:29:25 2021 user.notice lora_pkt_fwd[5845]: # BEACON queued: 0
Thu Sep 30 05:29:25 2021 user.notice lora_pkt_fwd[5845]: # BEACON sent so far: 0
Thu Sep 30 05:29:25 2021 user.notice lora_pkt_fwd[5845]: # BEACON rejected: 0
Thu Sep 30 05:29:25 2021 user.notice lora_pkt_fwd[5845]: ### [JIT] ###
Thu Sep 30 05:29:25 2021 user.notice lora_pkt_fwd[5845]: # SX1301 time (PPS): 73608750, offset us 0
Thu Sep 30 05:29:25 2021 user.notice lora_pkt_fwd[5845]: ### [GPS] ###
Thu Sep 30 05:29:25 2021 user.notice lora_pkt_fwd[5845]: # Invalid time reference (age: 1632979765 sec)
Thu Sep 30 05:29:25 2021 user.notice lora_pkt_fwd[5845]: # no valid GPS coordinates available yet
Thu Sep 30 05:29:25 2021 user.notice lora_pkt_fwd[5845]: ##### END #####
Thu Sep 30 05:29:55 2021 user.notice lora_pkt_fwd[5845]:
2021-09-30 05:29:55 UTC
Thu Sep 30 05:29:55 2021 user.notice lora_pkt_fwd[5845]: ### [UPSTREAM] ###
Thu Sep 30 05:29:55 2021 user.notice lora_pkt_fwd[5845]: # RF packets received by concentrator: 0
Thu Sep 30 05:29:55 2021 user.notice lora_pkt_fwd[5845]: # CRC_OK: 0.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Thu Sep 30 05:29:55 2021 user.notice lora_pkt_fwd[5845]: # RF packets forwarded: 0 (0 bytes)
Thu Sep 30 05:29:55 2021 user.notice lora_pkt_fwd[5845]: # PUSH_DATA datagrams sent: 1 (133 bytes)
Thu Sep 30 05:29:55 2021 user.notice lora_pkt_fwd[5845]: # PUSH_DATA acknowledged: 0.00
Thu Sep 30 05:29:55 2021 user.notice lora_pkt_fwd[5845]: ### [DOWNSTREAM] ###
Thu Sep 30 05:29:55 2021 user.notice lora_pkt_fwd[5845]: # PULL_DATA sent: 6 (0.00 acknowledged)
Thu Sep 30 05:29:55 2021 user.notice lora_pkt_fwd[5845]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 05:29:55 2021 user.notice lora_pkt_fwd[5845]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 05:29:55 2021 user.notice lora_pkt_fwd[5845]: # SX1301 time (PPS): 133609395, offset us 0
Thu Sep 30 05:29:55 2021 user.notice lora_pkt_fwd[5845]: ### [GPS] ###
Thu Sep 30 05:29:55 2021 user.notice lora_pkt_fwd[5845]: # Invalid time reference (age: 1632979795 sec)
Thu Sep 30 05:29:55 2021 user.notice lora_pkt_fwd[5845]: # no valid GPS coordinates available yet
Thu Sep 30 05:29:55 2021 user.notice lora_pkt_fwd[5845]: ##### END #####
Thu Sep 30 05:30:25 2021 user.notice lora_pkt_fwd[5845]:
2021-09-30 05:30:25 UTC
Thu Sep 30 05:30:25 2021 user.notice lora_pkt_fwd[5845]: ### [UPSTREAM] ###
Thu Sep 30 05:30:25 2021 user.notice lora_pkt_fwd[5845]: # RF packets received by concentrator: 0
Thu Sep 30 05:30:25 2021 user.notice lora_pkt_fwd[5845]: # CRC_OK: 0.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Thu Sep 30 05:30:25 2021 user.notice lora_pkt_fwd[5845]: # RF packets forwarded: 0 (0 bytes)
Thu Sep 30 05:30:25 2021 user.notice lora_pkt_fwd[5845]: # PUSH_DATA datagrams sent: 1 (133 bytes)
Thu Sep 30 05:30:25 2021 user.notice lora_pkt_fwd[5845]: # PUSH_DATA acknowledged: 0.00
Thu Sep 30 05:30:25 2021 user.notice lora_pkt_fwd[5845]: ### [DOWNSTREAM] ###
Thu Sep 30 05:30:25 2021 user.notice lora_pkt_fwd[5845]: # PULL_DATA sent: 5 (0.00 acknowledged)
Thu Sep 30 05:30:25 2021 user.notice lora_pkt_fwd[5845]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 05:30:25 2021 user.notice lora_pkt_fwd[5845]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 05:30:25 2021 user.notice lora_pkt_fwd[5845]: # TX errors: 0
Thu Sep 30 05:30:25 2021 user.notice lora_pkt_fwd[5845]: # BEACON queued: 0
Thu Sep 30 05:30:25 2021 user.notice lora_pkt_fwd[5845]: # BEACON sent so far: 0
Thu Sep 30 05:30:25 2021 user.notice lora_pkt_fwd[5845]: # BEACON rejected: 0
Thu Sep 30 05:30:25 2021 user.notice lora_pkt_fwd[5845]: ### [JIT] ###
Thu Sep 30 05:30:25 2021 user.notice lora_pkt_fwd[5845]: # SX1301 time (PPS): 133609395, offset us 0
Thu Sep 30 05:30:25 2021 user.notice lora_pkt_fwd[5845]: ### [GPS] ###
Thu Sep 30 05:30:25 2021 user.notice lora_pkt_fwd[5845]: # Invalid time reference (age: 1632979825 sec)
Thu Sep 30 05:30:25 2021 user.notice lora_pkt_fwd[5845]: # no valid GPS coordinates available yet
Thu Sep 30 05:30:25 2021 user.notice lora_pkt_fwd[5845]: ##### END #####
Thu Sep 30 05:30:31 2021 user.crit lora_pkt_fwd[5845]: INFO: [down] the last 30 PULL_DATA were not ACKed, exiting application
Thu Sep 30 05:30:55 2021 user.notice lora_pkt_fwd[5845]:
2021-09-30 05:30:55 UTC
Thu Sep 30 05:30:55 2021 user.notice lora_pkt_fwd[5845]: ### [UPSTREAM] ###
Thu Sep 30 05:30:55 2021 user.notice lora_pkt_fwd[5845]: # RF packets received by concentrator: 0
Thu Sep 30 05:30:55 2021 user.notice lora_pkt_fwd[5845]: # CRC_OK: 0.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Thu Sep 30 05:30:55 2021 user.notice lora_pkt_fwd[5845]: # RF packets forwarded: 0 (0 bytes)
Thu Sep 30 05:30:55 2021 user.notice lora_pkt_fwd[5845]: # PUSH_DATA datagrams sent: 1 (133 bytes)
Thu Sep 30 05:30:55 2021 user.notice lora_pkt_fwd[5845]: # PUSH_DATA acknowledged: 0.00
Thu Sep 30 05:30:55 2021 user.notice lora_pkt_fwd[5845]: ### [DOWNSTREAM] ###
Thu Sep 30 05:30:55 2021 user.notice lora_pkt_fwd[5845]: # PULL_DATA sent: 1 (0.00 acknowledged)
Thu Sep 30 05:30:55 2021 user.notice lora_pkt_fwd[5845]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 05:30:55 2021 user.notice lora_pkt_fwd[5845]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 05:30:55 2021 user.notice lora_pkt_fwd[5845]: # SX1301 time (PPS): 133609395, offset us 0
Thu Sep 30 05:30:55 2021 user.notice lora_pkt_fwd[5845]: ### [GPS] ###
Thu Sep 30 05:30:55 2021 user.notice lora_pkt_fwd[5845]: # Invalid time reference (age: 1632979855 sec)
Thu Sep 30 05:30:55 2021 user.notice lora_pkt_fwd[5845]: # no valid GPS coordinates available yet
Thu Sep 30 05:30:55 2021 user.notice lora_pkt_fwd[5845]: ##### END #####
Thu Sep 30 05:30:55 2021 user.warn lora_pkt_fwd[5845]: WARNING: failed to close GPS successfully
Thu Sep 30 05:30:55 2021 user.notice lora_pkt_fwd[5845]: INFO: concentrator stopped successfully
Thu Sep 30 05:30:55 2021 user.notice lora_pkt_fwd[5845]: INFO: Exiting packet forwarder program
Thu Sep 30 05:31:05 2021 user.notice lora_pkt_fwd[6219]: INFO: [main] concentrator started, packet can now be received
Thu Sep 30 05:31:45 2021 user.notice lora_pkt_fwd[6219]:
2021-09-30 05:31:45 UTC
Thu Sep 30 05:31:45 2021 user.notice lora_pkt_fwd[6219]: ### [UPSTREAM] ###
Thu Sep 30 05:31:45 2021 user.notice lora_pkt_fwd[6219]: # RF packets received by concentrator: 1
Thu Sep 30 05:31:45 2021 user.notice lora_pkt_fwd[6219]: # CRC_OK: 0.00, CRC_FAIL: 100.00, NO_CRC: 0.00
Thu Sep 30 05:31:45 2021 user.notice lora_pkt_fwd[6219]: # RF packets forwarded: 0 (0 bytes)
Thu Sep 30 05:31:45 2021 user.notice lora_pkt_fwd[6219]: # PUSH_DATA datagrams sent: 0 (0 bytes)
Thu Sep 30 05:31:45 2021 user.notice lora_pkt_fwd[6219]: # PUSH_DATA acknowledged: 0.00
Thu Sep 30 05:31:45 2021 user.notice lora_pkt_fwd[6219]: ### [DOWNSTREAM] ###
Thu Sep 30 05:31:45 2021 user.notice lora_pkt_fwd[6219]: # PULL_DATA sent: 6 (0.00 acknowledged)
Thu Sep 30 05:31:45 2021 user.notice lora_pkt_fwd[6219]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 05:31:45 2021 user.notice lora_pkt_fwd[6219]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 05:31:45 2021 user.notice lora_pkt_fwd[6219]: # SX1301 time (PPS): 12831972, offset us 0
Thu Sep 30 05:31:45 2021 user.notice lora_pkt_fwd[6219]: ### [GPS] ###
Thu Sep 30 05:31:45 2021 user.notice lora_pkt_fwd[6219]: # Invalid time reference (age: 1632979905 sec)
Thu Sep 30 05:31:45 2021 user.notice lora_pkt_fwd[6219]: # no valid GPS coordinates available yet
Thu Sep 30 05:31:45 2021 user.notice lora_pkt_fwd[6219]: ##### END #####
Thu Sep 30 05:32:15 2021 user.notice lora_pkt_fwd[6219]:
2021-09-30 05:32:15 UTC
Thu Sep 30 05:32:15 2021 user.notice lora_pkt_fwd[6219]: ### [UPSTREAM] ###
Thu Sep 30 05:32:15 2021 user.notice lora_pkt_fwd[6219]: # RF packets received by concentrator: 0
Thu Sep 30 05:32:15 2021 user.notice lora_pkt_fwd[6219]: # CRC_OK: 0.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Thu Sep 30 05:32:15 2021 user.notice lora_pkt_fwd[6219]: # RF packets forwarded: 0 (0 bytes)
Thu Sep 30 05:32:15 2021 user.notice lora_pkt_fwd[6219]: # PUSH_DATA datagrams sent: 1 (133 bytes)
Thu Sep 30 05:32:15 2021 user.notice lora_pkt_fwd[6219]: # PUSH_DATA acknowledged: 0.00
Thu Sep 30 05:32:15 2021 user.notice lora_pkt_fwd[6219]: ### [DOWNSTREAM] ###
Thu Sep 30 05:32:15 2021 user.notice lora_pkt_fwd[6219]: # PULL_DATA sent: 6 (0.00 acknowledged)
Thu Sep 30 05:32:15 2021 user.notice lora_pkt_fwd[6219]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 05:32:15 2021 user.notice lora_pkt_fwd[6219]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 05:32:15 2021 user.notice lora_pkt_fwd[6219]: # TX errors: 0
Thu Sep 30 05:32:15 2021 user.notice lora_pkt_fwd[6219]: # BEACON queued: 0
Thu Sep 30 05:32:15 2021 user.notice lora_pkt_fwd[6219]: # BEACON sent so far: 0
Thu Sep 30 05:32:15 2021 user.notice lora_pkt_fwd[6219]: # BEACON rejected: 0
Thu Sep 30 05:32:15 2021 user.notice lora_pkt_fwd[6219]: ### [JIT] ###
Thu Sep 30 05:32:15 2021 user.notice lora_pkt_fwd[6219]: # SX1301 time (PPS): 72832498, offset us 0
Thu Sep 30 05:32:15 2021 user.notice lora_pkt_fwd[6219]: ### [GPS] ###
Thu Sep 30 05:32:15 2021 user.notice lora_pkt_fwd[6219]: # Invalid time reference (age: 1632979935 sec)
Thu Sep 30 05:32:15 2021 user.notice lora_pkt_fwd[6219]: # no valid GPS coordinates available yet
Thu Sep 30 05:32:15 2021 user.notice lora_pkt_fwd[6219]: ##### END #####
Thu Sep 30 05:32:29 2021 daemon.info db[1494]: DataBase Backup
Thu Sep 30 05:32:45 2021 user.notice lora_pkt_fwd[6219]:
2021-09-30 05:32:45 UTC
Thu Sep 30 05:32:45 2021 user.notice lora_pkt_fwd[6219]: ### [UPSTREAM] ###
Thu Sep 30 05:32:45 2021 user.notice lora_pkt_fwd[6219]: # RF packets received by concentrator: 2
Thu Sep 30 05:32:45 2021 user.notice lora_pkt_fwd[6219]: # CRC_OK: 100.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Thu Sep 30 05:32:45 2021 user.notice lora_pkt_fwd[6219]: # RF packets forwarded: 2 (42 bytes)
Thu Sep 30 05:32:45 2021 user.notice lora_pkt_fwd[6219]: # PUSH_DATA datagrams sent: 3 (536 bytes)
Thu Sep 30 05:32:45 2021 user.notice lora_pkt_fwd[6219]: # PUSH_DATA acknowledged: 0.00
Thu Sep 30 05:32:45 2021 user.notice lora_pkt_fwd[6219]: ### [DOWNSTREAM] ###
Thu Sep 30 05:32:45 2021 user.notice lora_pkt_fwd[6219]: # PULL_DATA sent: 6 (0.00 acknowledged)
Thu Sep 30 05:32:45 2021 user.notice lora_pkt_fwd[6219]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 05:32:45 2021 user.notice lora_pkt_fwd[6219]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 05:32:45 2021 user.notice lora_pkt_fwd[6219]: # SX1301 time (PPS): 72832498, offset us 0
Thu Sep 30 05:32:45 2021 user.notice lora_pkt_fwd[6219]: ### [GPS] ###
Thu Sep 30 05:32:45 2021 user.notice lora_pkt_fwd[6219]: # Invalid time reference (age: 1632979965 sec)
Thu Sep 30 05:32:45 2021 user.notice lora_pkt_fwd[6219]: # no valid GPS coordinates available yet
Thu Sep 30 05:32:45 2021 user.notice lora_pkt_fwd[6219]: ##### END #####
Thu Sep 30 05:33:12 2021 kern.warn kernel: [ 2187.490000] da match,0xac1f09016282
Thu Sep 30 05:33:12 2021 daemon.info dnsmasq-dhcp[1632]: DHCPREQUEST(br-lan) 192.168.230.139 84:ef:18:4e:02:f5
Thu Sep 30 05:33:12 2021 daemon.info dnsmasq-dhcp[1632]: DHCPACK(br-lan) 192.168.230.139 84:ef:18:4e:02:f5 MY-PC
Thu Sep 30 05:33:15 2021 user.notice lora_pkt_fwd[6219]:
2021-09-30 05:33:15 UTC
Thu Sep 30 05:33:15 2021 user.notice lora_pkt_fwd[6219]: ### [UPSTREAM] ###
Thu Sep 30 05:33:15 2021 user.notice lora_pkt_fwd[6219]: # RF packets received by concentrator: 0
Thu Sep 30 05:33:15 2021 user.notice lora_pkt_fwd[6219]: # CRC_OK: 0.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Thu Sep 30 05:33:15 2021 user.notice lora_pkt_fwd[6219]: # RF packets forwarded: 0 (0 bytes)
Thu Sep 30 05:33:15 2021 user.notice lora_pkt_fwd[6219]: # PUSH_DATA datagrams sent: 1 (133 bytes)
Thu Sep 30 05:33:15 2021 user.notice lora_pkt_fwd[6219]: # PUSH_DATA acknowledged: 0.00
Thu Sep 30 05:33:15 2021 user.notice lora_pkt_fwd[6219]: ### [DOWNSTREAM] ###
Thu Sep 30 05:33:15 2021 user.notice lora_pkt_fwd[6219]: # PULL_DATA sent: 6 (0.00 acknowledged)
Thu Sep 30 05:33:15 2021 user.notice lora_pkt_fwd[6219]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 05:33:15 2021 user.notice lora_pkt_fwd[6219]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 05:33:15 2021 user.notice lora_pkt_fwd[6219]: # SX1301 time (PPS): 132833030, offset us 0
Thu Sep 30 05:33:15 2021 user.notice lora_pkt_fwd[6219]: ### [GPS] ###
Thu Sep 30 05:33:15 2021 user.notice lora_pkt_fwd[6219]: # Invalid time reference (age: 1632979995 sec)
Thu Sep 30 05:33:15 2021 user.notice lora_pkt_fwd[6219]: # no valid GPS coordinates available yet
Thu Sep 30 05:33:15 2021 user.notice lora_pkt_fwd[6219]: ##### END #####
Thu Sep 30 05:33:25 2021 daemon.info bufrd[1494]: ENTER bufrdCreate SrvCtrlClient Read buffer' Thu Sep 30 05:33:25 2021 daemon.info bufwr[1494]: ENTER bufwrCreate SrvCtrlClient Write buffer’
Thu Sep 30 05:33:25 2021 daemon.info bufrd[1494]: ENTER bufrdDestroy `SrvCtrlClient Read buffer’
Thu Sep 30 05:33:45 2021 user.notice lora_pkt_fwd[6219]:
2021-09-30 05:33:45 UTC
Thu Sep 30 05:33:45 2021 user.notice lora_pkt_fwd[6219]: ### [UPSTREAM] ###
Thu Sep 30 05:33:45 2021 user.notice lora_pkt_fwd[6219]: # RF packets received by concentrator: 0
Thu Sep 30 05:33:45 2021 user.notice lora_pkt_fwd[6219]: # CRC_OK: 0.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Thu Sep 30 05:33:45 2021 user.notice lora_pkt_fwd[6219]: # RF packets forwarded: 0 (0 bytes)
Thu Sep 30 05:33:45 2021 user.notice lora_pkt_fwd[6219]: # PUSH_DATA datagrams sent: 1 (133 bytes)
Thu Sep 30 05:33:45 2021 user.notice lora_pkt_fwd[6219]: # PUSH_DATA acknowledged: 0.00
Thu Sep 30 05:33:45 2021 user.notice lora_pkt_fwd[6219]: ### [DOWNSTREAM] ###
Thu Sep 30 05:33:45 2021 user.notice lora_pkt_fwd[6219]: # PULL_DATA sent: 5 (0.00 acknowledged)
Thu Sep 30 05:33:45 2021 user.notice lora_pkt_fwd[6219]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 05:33:45 2021 user.notice lora_pkt_fwd[6219]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 05:33:45 2021 user.notice lora_pkt_fwd[6219]: # TX errors: 0
Thu Sep 30 05:33:45 2021 user.notice lora_pkt_fwd[6219]: # BEACON queued: 0
Thu Sep 30 05:33:45 2021 user.notice lora_pkt_fwd[6219]: # BEACON sent so far: 0
Thu Sep 30 05:33:45 2021 user.notice lora_pkt_fwd[6219]: # BEACON rejected: 0
Thu Sep 30 05:33:45 2021 user.notice lora_pkt_fwd[6219]: ### [JIT] ###
Thu Sep 30 05:33:45 2021 user.notice lora_pkt_fwd[6219]: # SX1301 time (PPS): 132833030, offset us 0
Thu Sep 30 05:33:45 2021 user.notice lora_pkt_fwd[6219]: ### [GPS] ###
Thu Sep 30 05:33:45 2021 user.notice lora_pkt_fwd[6219]: # Invalid time reference (age: 1632980025 sec)
Thu Sep 30 05:33:45 2021 user.notice lora_pkt_fwd[6219]: # no valid GPS coordinates available yet
Thu Sep 30 05:33:45 2021 user.notice lora_pkt_fwd[6219]: ##### END #####
Thu Sep 30 05:33:51 2021 user.crit lora_pkt_fwd[6219]: INFO: [down] the last 30 PULL_DATA were not ACKed, exiting application
Thu Sep 30 05:34:15 2021 user.notice lora_pkt_fwd[6219]:
2021-09-30 05:34:15 UTC
Thu Sep 30 05:34:15 2021 user.notice lora_pkt_fwd[6219]: ### [UPSTREAM] ###
Thu Sep 30 05:34:15 2021 user.notice lora_pkt_fwd[6219]: # RF packets received by concentrator: 0
Thu Sep 30 05:34:15 2021 user.notice lora_pkt_fwd[6219]: # CRC_OK: 0.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Thu Sep 30 05:34:15 2021 user.notice lora_pkt_fwd[6219]: # RF packets forwarded: 0 (0 bytes)
Thu Sep 30 05:34:15 2021 user.notice lora_pkt_fwd[6219]: # PUSH_DATA datagrams sent: 1 (133 bytes)
Thu Sep 30 05:34:15 2021 user.notice lora_pkt_fwd[6219]: # PUSH_DATA acknowledged: 0.00
Thu Sep 30 05:34:15 2021 user.notice lora_pkt_fwd[6219]: ### [DOWNSTREAM] ###
Thu Sep 30 05:34:15 2021 user.notice lora_pkt_fwd[6219]: # PULL_DATA sent: 1 (0.00 acknowledged)
Thu Sep 30 05:34:15 2021 user.notice lora_pkt_fwd[6219]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 05:34:15 2021 user.notice lora_pkt_fwd[6219]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 05:34:15 2021 user.notice lora_pkt_fwd[6219]: # SX1301 time (PPS): 132833030, offset us 0
Thu Sep 30 05:34:15 2021 user.notice lora_pkt_fwd[6219]: ### [GPS] ###
Thu Sep 30 05:34:15 2021 user.notice lora_pkt_fwd[6219]: # Invalid time reference (age: 1632980055 sec)
Thu Sep 30 05:34:15 2021 user.notice lora_pkt_fwd[6219]: # no valid GPS coordinates available yet
Thu Sep 30 05:34:15 2021 user.notice lora_pkt_fwd[6219]: ##### END #####
Thu Sep 30 05:34:15 2021 user.warn lora_pkt_fwd[6219]: WARNING: failed to close GPS successfully
Thu Sep 30 05:34:15 2021 user.notice lora_pkt_fwd[6219]: INFO: concentrator stopped successfully
Thu Sep 30 05:34:15 2021 user.notice lora_pkt_fwd[6219]: INFO: Exiting packet forwarder program
Thu Sep 30 05:34:26 2021 user.notice lora_pkt_fwd[6260]: INFO: [main] concentrator started, packet can now be received
Thu Sep 30 05:35:08 2021 user.notice lora_pkt_fwd[6260]:
2021-09-30 05:35:08 UTC
Thu Sep 30 05:35:08 2021 user.notice lora_pkt_fwd[6260]: ### [UPSTREAM] ###
Thu Sep 30 05:35:08 2021 user.notice lora_pkt_fwd[6260]: # RF packets received by concentrator: 0
Thu Sep 30 05:35:08 2021 user.notice lora_pkt_fwd[6260]: # CRC_OK: 0.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Thu Sep 30 05:35:08 2021 user.notice lora_pkt_fwd[6260]: # RF packets forwarded: 0 (0 bytes)
Thu Sep 30 05:35:08 2021 user.notice lora_pkt_fwd[6260]: # PUSH_DATA datagrams sent: 0 (0 bytes)
Thu Sep 30 05:35:08 2021 user.notice lora_pkt_fwd[6260]: # PUSH_DATA acknowledged: 0.00
Thu Sep 30 05:35:08 2021 user.notice lora_pkt_fwd[6260]: ### [DOWNSTREAM] ###
Thu Sep 30 05:35:08 2021 user.notice lora_pkt_fwd[6260]: # PULL_DATA sent: 6 (0.00 acknowledged)
Thu Sep 30 05:35:08 2021 user.notice lora_pkt_fwd[6260]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 05:35:08 2021 user.notice lora_pkt_fwd[6260]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 05:35:08 2021 user.notice lora_pkt_fwd[6260]: # SX1301 time (PPS): 15089701, offset us 0
Thu Sep 30 05:35:08 2021 user.notice lora_pkt_fwd[6260]: ### [GPS] ###
Thu Sep 30 05:35:08 2021 user.notice lora_pkt_fwd[6260]: # Invalid time reference (age: 1632980108 sec)
Thu Sep 30 05:35:08 2021 user.notice lora_pkt_fwd[6260]: # no valid GPS coordinates available yet
Thu Sep 30 05:35:38 2021 user.notice lora_pkt_fwd[6260]:
2021-09-30 05:35:38 UTC
Thu Sep 30 05:35:38 2021 user.notice lora_pkt_fwd[6260]: ### [UPSTREAM] ###
Thu Sep 30 05:35:38 2021 user.notice lora_pkt_fwd[6260]: # RF packets received by concentrator: 0
Thu Sep 30 05:35:38 2021 user.notice lora_pkt_fwd[6260]: # CRC_OK: 0.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Thu Sep 30 05:35:38 2021 user.notice lora_pkt_fwd[6260]: # RF packets forwarded: 0 (0 bytes)
Thu Sep 30 05:35:38 2021 user.notice lora_pkt_fwd[6260]: # PUSH_DATA datagrams sent: 1 (133 bytes)
Thu Sep 30 05:35:38 2021 user.notice lora_pkt_fwd[6260]: # PUSH_DATA acknowledged: 0.00
Thu Sep 30 05:35:38 2021 user.notice lora_pkt_fwd[6260]: ### [DOWNSTREAM] ###
Thu Sep 30 05:35:38 2021 user.notice lora_pkt_fwd[6260]: # PULL_DATA sent: 6 (0.00 acknowledged)
Thu Sep 30 05:35:38 2021 user.notice lora_pkt_fwd[6260]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 05:35:38 2021 user.notice lora_pkt_fwd[6260]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 05:35:38 2021 user.notice lora_pkt_fwd[6260]: # SX1301 time (PPS): 75090154, offset us 0
Thu Sep 30 05:35:38 2021 user.notice lora_pkt_fwd[6260]: ### [GPS] ###
Thu Sep 30 05:35:38 2021 user.notice lora_pkt_fwd[6260]: # Invalid time reference (age: 1632980138 sec)
Thu Sep 30 05:35:38 2021 user.notice lora_pkt_fwd[6260]: # no valid GPS coordinates available yet
Thu Sep 30 05:35:38 2021 user.notice lora_pkt_fwd[6260]: ##### END #####
Thu Sep 30 05:36:08 2021 user.notice lora_pkt_fwd[6260]:
2021-09-30 05:36:08 UTC
Thu Sep 30 05:36:08 2021 user.notice lora_pkt_fwd[6260]: ### [UPSTREAM] ###
Thu Sep 30 05:36:08 2021 user.notice lora_pkt_fwd[6260]: # RF packets received by concentrator: 0
Thu Sep 30 05:36:08 2021 user.notice lora_pkt_fwd[6260]: # CRC_OK: 0.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Thu Sep 30 05:36:08 2021 user.notice lora_pkt_fwd[6260]: # RF packets forwarded: 0 (0 bytes)
Thu Sep 30 05:36:08 2021 user.notice lora_pkt_fwd[6260]: # PUSH_DATA datagrams sent: 1 (133 bytes)
Thu Sep 30 05:36:08 2021 user.notice lora_pkt_fwd[6260]: # PUSH_DATA acknowledged: 0.00
Thu Sep 30 05:36:08 2021 user.notice lora_pkt_fwd[6260]: ### [DOWNSTREAM] ###
Thu Sep 30 05:36:08 2021 user.notice lora_pkt_fwd[6260]: # PULL_DATA sent: 6 (0.00 acknowledged)
Thu Sep 30 05:36:08 2021 user.notice lora_pkt_fwd[6260]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 05:36:08 2021 user.notice lora_pkt_fwd[6260]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 05:36:08 2021 user.notice lora_pkt_fwd[6260]: # TX errors: 0
Thu Sep 30 05:36:08 2021 user.notice lora_pkt_fwd[6260]: # BEACON queued: 0
Thu Sep 30 05:36:08 2021 user.notice lora_pkt_fwd[6260]: # BEACON sent so far: 0
Thu Sep 30 05:36:08 2021 user.notice lora_pkt_fwd[6260]: # BEACON rejected: 0
Thu Sep 30 05:36:08 2021 user.notice lora_pkt_fwd[6260]: ### [JIT] ###
Thu Sep 30 05:36:08 2021 user.notice lora_pkt_fwd[6260]: # SX1301 time (PPS): 75090154, offset us 0
Thu Sep 30 05:36:08 2021 user.notice lora_pkt_fwd[6260]: ### [GPS] ###
Thu Sep 30 05:36:08 2021 user.notice lora_pkt_fwd[6260]: # Invalid time reference (age: 1632980168 sec)
Thu Sep 30 05:36:08 2021 user.notice lora_pkt_fwd[6260]: # no valid GPS coordinates available yet
Thu Sep 30 05:36:08 2021 user.notice lora_pkt_fwd[6260]: ##### END #####
Thu Sep 30 05:36:38 2021 user.notice lora_pkt_fwd[6260]:
2021-09-30 05:36:38 UTC
Thu Sep 30 05:36:38 2021 user.notice lora_pkt_fwd[6260]: ### [UPSTREAM] ###
Thu Sep 30 05:36:38 2021 user.notice lora_pkt_fwd[6260]: # RF packets received by concentrator: 2
Thu Sep 30 05:36:38 2021 user.notice lora_pkt_fwd[6260]: # CRC_OK: 50.00, CRC_FAIL: 50.00, NO_CRC: 0.00
Thu Sep 30 05:36:38 2021 user.notice lora_pkt_fwd[6260]: # RF packets forwarded: 1 (19 bytes)
Thu Sep 30 05:36:38 2021 user.notice lora_pkt_fwd[6260]: # PUSH_DATA datagrams sent: 2 (336 bytes)
Thu Sep 30 05:36:38 2021 user.notice lora_pkt_fwd[6260]: # PUSH_DATA acknowledged: 0.00
Thu Sep 30 05:36:38 2021 user.notice lora_pkt_fwd[6260]: ### [DOWNSTREAM] ###
Thu Sep 30 05:36:38 2021 user.notice lora_pkt_fwd[6260]: # PULL_DATA sent: 6 (0.00 acknowledged)
Thu Sep 30 05:36:38 2021 user.notice lora_pkt_fwd[6260]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 05:36:38 2021 user.notice lora_pkt_fwd[6260]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 05:36:38 2021 user.notice lora_pkt_fwd[6260]: # SX1301 time (PPS): 135090614, offset us 0
Thu Sep 30 05:36:38 2021 user.notice lora_pkt_fwd[6260]: ### [GPS] ###
Thu Sep 30 05:36:38 2021 user.notice lora_pkt_fwd[6260]: # Invalid time reference (age: 1632980198 sec)
Thu Sep 30 05:36:38 2021 user.notice lora_pkt_fwd[6260]: # no valid GPS coordinates available yet
Thu Sep 30 05:36:38 2021 user.notice lora_pkt_fwd[6260]: ##### END #####
Thu Sep 30 05:37:08 2021 user.notice lora_pkt_fwd[6260]:
2021-09-30 05:37:08 UTC
Thu Sep 30 05:37:08 2021 user.notice lora_pkt_fwd[6260]: ### [UPSTREAM] ###
Thu Sep 30 05:37:08 2021 user.notice lora_pkt_fwd[6260]: # RF packets received by concentrator: 0
Thu Sep 30 05:37:08 2021 user.notice lora_pkt_fwd[6260]: # CRC_OK: 0.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Thu Sep 30 05:37:08 2021 user.notice lora_pkt_fwd[6260]: # RF packets forwarded: 0 (0 bytes)
Thu Sep 30 05:37:08 2021 user.notice lora_pkt_fwd[6260]: # PUSH_DATA datagrams sent: 1 (133 bytes)
Thu Sep 30 05:37:08 2021 user.notice lora_pkt_fwd[6260]: # PUSH_DATA acknowledged: 0.00
Thu Sep 30 05:37:08 2021 user.notice lora_pkt_fwd[6260]: ### [DOWNSTREAM] ###
Thu Sep 30 05:37:08 2021 user.notice lora_pkt_fwd[6260]: # PULL_DATA sent: 5 (0.00 acknowledged)
Thu Sep 30 05:37:08 2021 user.notice lora_pkt_fwd[6260]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 05:37:08 2021 user.notice lora_pkt_fwd[6260]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 05:37:08 2021 user.notice lora_pkt_fwd[6260]: # SX1301 time (PPS): 135090614, offset us 0
Thu Sep 30 05:37:08 2021 user.notice lora_pkt_fwd[6260]: ### [GPS] ###
Thu Sep 30 05:37:08 2021 user.notice lora_pkt_fwd[6260]: # Invalid time reference (age: 1632980228 sec)
Thu Sep 30 05:37:08 2021 user.notice lora_pkt_fwd[6260]: # no valid GPS coordinates available yet
Thu Sep 30 05:37:08 2021 user.notice lora_pkt_fwd[6260]: ##### END #####
Thu Sep 30 05:37:14 2021 user.crit lora_pkt_fwd[6260]: INFO: [down] the last 30 PULL_DATA were not ACKed, exiting application
Thu Sep 30 05:37:29 2021 daemon.info db[1494]: DataBase Backup
Thu Sep 30 05:37:38 2021 user.notice lora_pkt_fwd[6260]:
2021-09-30 05:37:38 UTC
Thu Sep 30 05:37:38 2021 user.notice lora_pkt_fwd[6260]: ### [UPSTREAM] ###
Thu Sep 30 05:37:38 2021 user.notice lora_pkt_fwd[6260]: # RF packets received by concentrator: 0
Thu Sep 30 05:37:38 2021 user.notice lora_pkt_fwd[6260]: # CRC_OK: 0.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Thu Sep 30 05:37:38 2021 user.notice lora_pkt_fwd[6260]: # RF packets forwarded: 0 (0 bytes)
Thu Sep 30 05:37:38 2021 user.notice lora_pkt_fwd[6260]: # PUSH_DATA datagrams sent: 1 (133 bytes)
Thu Sep 30 05:37:38 2021 user.notice lora_pkt_fwd[6260]: # PUSH_DATA acknowledged: 0.00
Thu Sep 30 05:37:38 2021 user.notice lora_pkt_fwd[6260]: ### [DOWNSTREAM] ###
Thu Sep 30 05:37:38 2021 user.notice lora_pkt_fwd[6260]: # PULL_DATA sent: 1 (0.00 acknowledged)
Thu Sep 30 05:37:38 2021 user.notice lora_pkt_fwd[6260]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 05:37:38 2021 user.notice lora_pkt_fwd[6260]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 05:37:38 2021 user.notice lora_pkt_fwd[6260]: # TX errors: 0
Thu Sep 30 05:37:38 2021 user.notice lora_pkt_fwd[6260]: # BEACON queued: 0
Thu Sep 30 05:37:38 2021 user.notice lora_pkt_fwd[6260]: # BEACON sent so far: 0
Thu Sep 30 05:37:38 2021 user.notice lora_pkt_fwd[6260]: # BEACON rejected: 0
Thu Sep 30 05:37:38 2021 user.notice lora_pkt_fwd[6260]: ### [JIT] ###
Thu Sep 30 05:37:38 2021 user.notice lora_pkt_fwd[6260]: # SX1301 time (PPS): 135090614, offset us 0
Thu Sep 30 05:37:38 2021 user.notice lora_pkt_fwd[6260]: ### [GPS] ###
Thu Sep 30 05:37:38 2021 user.notice lora_pkt_fwd[6260]: # Invalid time reference (age: 1632980258 sec)
Thu Sep 30 05:37:38 2021 user.notice lora_pkt_fwd[6260]: # no valid GPS coordinates available yet
Thu Sep 30 05:37:38 2021 user.notice lora_pkt_fwd[6260]: ##### END #####
Thu Sep 30 05:37:38 2021 user.warn lora_pkt_fwd[6260]: WARNING: failed to close GPS successfully
Thu Sep 30 05:37:38 2021 user.notice lora_pkt_fwd[6260]: INFO: concentrator stopped successfully
Thu Sep 30 05:37:38 2021 user.notice lora_pkt_fwd[6260]: INFO: Exiting packet forwarder program
Thu Sep 30 05:37:48 2021 user.notice lora_pkt_fwd[6476]: INFO: [main] concentrator started, packet can now be received
Thu Sep 30 05:38:29 2021 user.notice lora_pkt_fwd[6476]:
2021-09-30 05:38:29 UTC
Thu Sep 30 05:38:29 2021 user.notice lora_pkt_fwd[6476]: ### [UPSTREAM] ###
Thu Sep 30 05:38:29 2021 user.notice lora_pkt_fwd[6476]: # RF packets received by concentrator: 0
Thu Sep 30 05:38:29 2021 user.notice lora_pkt_fwd[6476]: # CRC_OK: 0.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Thu Sep 30 05:38:29 2021 user.notice lora_pkt_fwd[6476]: # RF packets forwarded: 0 (0 bytes)
Thu Sep 30 05:38:29 2021 user.notice lora_pkt_fwd[6476]: # PUSH_DATA datagrams sent: 0 (0 bytes)
Thu Sep 30 05:38:29 2021 user.notice lora_pkt_fwd[6476]: # PUSH_DATA acknowledged: 0.00
Thu Sep 30 05:38:29 2021 user.notice lora_pkt_fwd[6476]: ### [DOWNSTREAM] ###
Thu Sep 30 05:38:29 2021 user.notice lora_pkt_fwd[6476]: # PULL_DATA sent: 6 (0.00 acknowledged)
Thu Sep 30 05:38:29 2021 user.notice lora_pkt_fwd[6476]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Sep 30 05:38:29 2021 user.notice lora_pkt_fwd[6476]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Sep 30 05:38:29 2021 user.notice lora_pkt_fwd[6476]: # TX errors: 0
Thu Sep 30 05:38:29 2021 user.notice lora_pkt_fwd[6476]: # BEACON queued: 0
Thu Sep 30 05:38:29 2021 user.notice lora_pkt_fwd[6476]: # BEACON sent so far: 0
Thu Sep 30 05:38:29 2021 user.notice lora_pkt_fwd[6476]: # BEACON rejected: 0
Thu Sep 30 05:38:29 2021 user.notice lora_pkt_fwd[6476]: ### [JIT] ###
Thu Sep 30 05:38:29 2021 user.notice lora_pkt_fwd[6476]: # SX1301 time (PPS): 13564880, offset us 0
Thu Sep 30 05:38:29 2021 user.notice lora_pkt_fwd[6476]: ### [GPS] ###
Thu Sep 30 05:38:29 2021 user.notice lora_pkt_fwd[6476]: # Invalid time reference (age: 1632980309 sec)
Thu Sep 30 05:38:29 2021 user.notice lora_pkt_fwd[6476]: # no valid GPS coordinates available yet
Thu Sep 30 05:38:29 2021 user.notice lora_pkt_fwd[6476]: ##### END #####
Make sure the ports in general setup are set to 1700.
Hi Kersing,
Thank you for your reply. I changed the MQTT Broker Port to 1700 (I think this is the ports you mentioned) but the gateway is still disconnected. I think there may be something else going wrong.
I think you need to look at the “Server port up” and “Server port down” values, not MQTT.
like this?
Hi Kersing,
thank you, the issue has been resolved.
