after adding the gateway not gettting live laways showing disconnected , the gateway is running fine
everything was working fine in version 2 TTN , i tried to migrate to V3 TTS it did not go well, so I deleted all gateways & devices and created it again in TTS as a new application, unfortunately not getting connected , verified the EUI once for gateway all settings looks fine
Hi can anyone support
The support on the forum is provided by volunteers with (mostly) a day job. You need to exercise patience…
Hi Thanks , it is done somehow managed to get it connected , firewall issue the server connectivity was blocked
