Fuota ts-004
Hello TTN Forum - At 37:55 in this video, the presenter conveys the CID for a FUOTA data fragment as being 0x05. TS004 lists the CID for a FUOTA data fragment as being 0x08. Which is correct? Thanks much!
I suspect this would be in the realm of the deep deep (onion) layer of knowledge that @kersing or @stevencellist brings to the party.
However I’d note that the written, high-structured, version-controlled with line numbers PDF will be the specification and someone talking on YouTube not so much.
Given that the document in frame at 37:55 shows 0x08, it clearly is a simple mistake by the speaker, nothing more. (Also X-reffed both TS004-1.0.0 and TS004-2.0.0, both show 0x08.)
Thank you for validating.
