Hi I am from Uzbekistan, I tried make gateway with OrangePi one Ebyte e106 915MHZ SX1302 module, and I tried Uzbekistan frequency plan in frequency plan list I registered it, it connected to TTN but I use US915 configuration in source code of gateway and end node (ra-08h kit, asr6601) source code also configured with US915. I am looking for gateway and end node configuration for Uzbekistan freq plan.
This is piece of code: {
“SX130x_conf”: {
“com_type”: “SPI”,
“com_path”: “/dev/spidev0.0”,
“lorawan_public”: true,
“clksrc”: 0,
“antenna_gain”: 0, /* antenna gain, in dBi /
“full_duplex”: false,
“fine_timestamp”: {
“enable”: false,
“mode”: “all_sf” / high_capacity or all_sf /
“lbt”: {
“enable”: false / LBT for 500 Khz channels is not supported /
“radio_0”: {
“enable”: true,
“type”: “SX1250”,
“freq”: 904300000,
“rssi_offset”: -215.4,
“rssi_tcomp”: {“coeff_a”: 0, “coeff_b”: 0, “coeff_c”: 20.41, “coeff_d”: 2162.56, “coeff_e”: 0},
“tx_enable”: true,
“tx_freq_min”: 923000000,
“tx_freq_max”: 928000000,
“tx_gain_lut”:[
{“rf_power”: 12, “pa_gain”: 0, “pwr_idx”: 15},
{“rf_power”: 13, “pa_gain”: 0, “pwr_idx”: 16},
{“rf_power”: 14, “pa_gain”: 0, “pwr_idx”: 17},
{“rf_power”: 15, “pa_gain”: 0, “pwr_idx”: 19},
{“rf_power”: 16, “pa_gain”: 0, “pwr_idx”: 20},
{“rf_power”: 17, “pa_gain”: 0, “pwr_idx”: 22},
{“rf_power”: 18, “pa_gain”: 1, “pwr_idx”: 1},
{“rf_power”: 19, “pa_gain”: 1, “pwr_idx”: 2},
{“rf_power”: 20, “pa_gain”: 1, “pwr_idx”: 3},
{“rf_power”: 21, “pa_gain”: 1, “pwr_idx”: 4},
{“rf_power”: 22, “pa_gain”: 1, “pwr_idx”: 5},
{“rf_power”: 23, “pa_gain”: 1, “pwr_idx”: 6},
{“rf_power”: 24, “pa_gain”: 1, “pwr_idx”: 7},
{“rf_power”: 25, “pa_gain”: 1, “pwr_idx”: 9},
{“rf_power”: 26, “pa_gain”: 1, “pwr_idx”: 11},
{“rf_power”: 27, “pa_gain”: 1, “pwr_idx”: 14}
“radio_1”: {
“enable”: true,
“type”: “SX1250”,
“freq”: 905000000,
“tx_enable”: false
“chan_multiSF_All”: {“spreading_factor_enable”: [ 5, 6, 7, 8, 9, 10, 11, 12 ]},
“chan_multiSF_0”: {“enable”: true, “radio”: 0, “if”: -400000}, / Freq : 903.9 MHz*/
“chan_multiSF_1”: {“enable”: true, “radio”: 0, “if”: -200000}, /* Freq : 904.1 MHz*/
“chan_multiSF_2”: {“enable”: true, “radio”: 0, “if”: 0}, /* Freq : 904.3 MHz*/
“chan_multiSF_3”: {“enable”: true, “radio”: 0, “if”: 200000}, /* Freq : 904.5 MHz*/
“chan_multiSF_4”: {“enable”: true, “radio”: 1, “if”: -300000}, /* Freq : 904.7 MHz*/
“chan_multiSF_5”: {“enable”: true, “radio”: 1, “if”: -100000}, /* Freq : 904.9 MHz*/
“chan_multiSF_6”: {“enable”: true, “radio”: 1, “if”: 100000}, /* Freq : 905.1 MHz*/
“chan_multiSF_7”: {“enable”: true, “radio”: 1, “if”: 300000}, /* Freq : 905.3 MHz*/
“chan_Lora_std”: {“enable”: true, “radio”: 0, “if”: 300000, “bandwidth”: 500000, “spread_factor”: 8, /* Freq : 904.6 MHz*/
“implicit_hdr”: false, “implicit_payload_length”: 17, “implicit_crc_en”: false, “implicit_coderate”: 1},
“chan_FSK”: {“enable”: false, “radio”: 1, “if”: 300000, “bandwidth”: 125000, “datarate”: 50000} /* Freq : 868.8 MHz*/
"gateway_conf": {
"gateway_ID": "-----------------",
/* change with default server address/ports */
"server_address": "au1.cloud.thethings.network",
"serv_port_up": 1700,
"serv_port_down": 1700,
/* adjust the following parameters for your network */
"keepalive_interval": 10,
"stat_interval": 30,
"push_timeout_ms": 100,
/* forward only valid packets */
"forward_crc_valid": true,
"forward_crc_error": false,
"forward_crc_disabled": false,
/* GPS configuration */
"gps_tty_path": "/dev/ttyS0",
/* GPS reference coordinates */
"ref_latitude": 0.0,
"ref_longitude": 0.0,
"ref_altitude": 0,
/* Beaconing parameters */
"beacon_period": 0, /* disable class B beacon */
"beacon_freq_hz": 869525000,
"beacon_datarate": 9,
"beacon_bw_hz": 125000,
"beacon_power": 14,
"beacon_infodesc": 0
"debug_conf": {
"ref_payload":[
{"id": "0xCAFE1234"},
{"id": "0xCAFE2345"}
"log_file": "loragw_hal.log"
