Hello, everyone,
i have just installed a private instance of thingsnetwork according to this tutorial: https://thethingsstack.io/v3.6.0/guides/getting-started/
The installation worked without problems. Unfortunately, I’m not able to use the web console properly. The reason for this is that after I login in the web-console I’m redirect to a webpage saying: Forbidden Invalid redirect URI.
The shell output of this error looks as follows:
stack_1 | WARN OAuth error error=error:pkg/oauth:invalid_redirect_uri (invalid redirect URI) error_cause=urls don't validate: https://thethings.example.com/console/oauth/callback / /console/oauth/callback method=GET namespace=web remote_addr=172.18.0.1:54238 request_id=01E4JZZAF0MVJYY98KVJZY9TH9 url=/oauth/authorize?client_id=console&redirect_uri=%2Fconsole%2Foauth%2Fcallback&response_type=code&state=WSg0i-WsagCvdGPg
stack_1 | INFO Request handled duration=14.840563ms method=GET namespace=web remote_addr=172.18.0.1:54238 request_id=01E4JZZAF0MVJYY98KVJZY9TH9 response_size=1665 status=403 url=/oauth/authorize?client_id=console&redirect_uri=%2Fconsole%2Foauth%2Fcallback&response_type=code&state=WSg0i-WsagCvdGPg
stack_1 | INFO Request handled duration=21.716396ms method=GET namespace=web remote_addr=172.18.0.1:54242 request_id=01E4JZZAPJXYAABX7W26C15G9Y response_size=209 status=200 url=/oauth/api/me
Some further information:
- I tried to access the console via 127.0.0.1:1885 and via thethings.example.com:1885 (I maped the domain to my localhost in my /etc/hosts file. Threfore thethings.example.com -> 127.0.0.1).
- The HTTPS port 8885 do not work at all. As soon as I open the website with https://127.0.0.1:8885 I get the following error message: SSL_ERROR_INTERNAL_ERROR_ALERT. In the shell I get the following error
2020/03/29 11:48:36 http: TLS handshake error from 172.18.0.1:37460: open /var/lib/acme/acme_account+key093647609: permission denied
[EDIT]
I fixed some issues regarding the https access but now I keep getting the following error message:
stack_1 | 2020/03/29 12:56:06 http: TLS handshake error from 172.21.0.1:55864: acme/autocert: server name component count invalid
stack_1 | 2020/03/29 12:56:25 http: TLS handshake error from 172.21.0.1:55868: mkdir /var/lib/acme: permission denied
stack_1 | 2020/03/29 12:56:45 http: TLS handshake error from 172.21.0.1:55882: acme/autocert: missing certificate - I do not use self-encrypted certificates. I use Let’s encrypt as mentioned in the documentation
- I use docker-compose 1.25.4 and docker 19.03.08-ce
- The operating system that I’m using is archlinux
Here is my docker-compose.yml:
version: '3.7'
services:
cockroach:
image: cockroachdb/cockroach
command: start --http-port 26256 --insecure
restart: unless-stopped
volumes:
- ${DEV_DATA_DIR:-.env/data}/cockroach:/cockroach/cockroach-data
ports:
- "127.0.0.1:26257:26257" # Cockroach
- "127.0.0.1:26256:26256" # WebUI
redis:
image: redis
command: redis-server --appendonly yes
volumes:
- ${DEV_DATA_DIR:-.env/data}/redis:/data
ports:
- "127.0.0.1:6379:6379"
stack:
image: thethingsnetwork/lorawan-stack
entrypoint: ttn-lw-stack
command: start
depends_on:
- redis
- cockroach
volumes:
- ./blob:/srv/ttn-lorawan/public/blob
- ./acme:/var/lib/acme
ports:
- "80:1885"
- "443:8885"
- "1881:1881"
- "8881:8881"
- "1882:1882"
- "8882:8882"
- "1883:1883"
- "8883:8883"
- "1884:1884"
- "8884:8884"
- "1885:1885"
- "8885:8885"
- "1887:1887"
- "8887:8887"
- "1700:1700/udp"
environment:
# If using CockroachDB:
- TTN_LW_IS_DATABASE_URI=postgres://root@cockroach:26257/${DEV_DATABASE_NAME:-ttn_lorawan}?sslmode=disable
- TTN_LW_REDIS_ADDRESS=redis:6379
- TTN_LW_TLS_SOURCE=acme
- TTN_LW_TLS_ACME_DIR=/var/lib/acme
- TTN_LW_TLS_ACME_EMAIL=you@thethings.example.com
- TTN_LW_TLS_ACME_HOSTS=thethings.example.com
- TTN_LW_TLS_ACME_DEFAULT_HOST=thethings.example.com
# HTTP Server configuration:
- TTN_LW_HTTP_COOKIE_HASH_KEY=1196c3904d12e748e84187b68b976c373548f06265756ce9b02d4a746b369d2b341c8125e94ffd0ed7029b9236f9ab0ffc816b1d93d1e3ee051198d8af642430
- TTN_LW_HTTP_COOKIE_BLOCK_KEY=8eed19fd9db8bfeaa8d914fe8d3066a3c33f25968a0219f5ecb1afac0b261ebe
- TTN_LW_HTTP_METRICS_PASSWORD=password
- TTN_LW_HTTP_PPROF_PASSWORD=password
# Email configuration for "thethings.example.com":
- TTN_LW_IS_EMAIL_SENDER_NAME=The Things Stack
- TTN_LW_IS_EMAIL_SENDER_ADDRESS=noreply@thethings.example.com
- TTN_LW_IS_EMAIL_NETWORK_CONSOLE_URL=https://thethings.example.com/console
- TTN_LW_IS_EMAIL_NETWORK_IDENTITY_SERVER_URL=https://thethings.example.com/oauth
# If sending email with Sendgrid:
# - TTN_LW_IS_EMAIL_PROVIDER=sendgrid
# - TTN_LW_IS_EMAIL_SENDGRID_API_KEY=enter Sendgrid API key
# If sending email with SMTP:
- TTN_LW_IS_EMAIL_PROVIDER=smtp
- TTN_LW_IS_EMAIL_SMTP_ADDRESS=enter mail server address
- TTN_LW_IS_EMAIL_SMTP_USERNAME=enter username
- TTN_LW_IS_EMAIL_SMTP_PASSWORD=enter password
# If Application Server enabled, defaults for "thethings.example.com":
- TTN_LW_AS_MQTT_PUBLIC_ADDRESS=thethings.example.com:1883
- TTN_LW_AS_MQTT_PUBLIC_TLS_ADDRESS=thethings.example.com:8883
# If Application Server enabled, Application Server interoperability configuration:
# If interoperability configuration repository is a directory on OS FS:
# - TTN_LW_AS_INTEROP_DIRECTORY=/path/to/interop/repository
# If interoperability configuration repository is a URL:
# - TTN_LW_AS_INTEROP_URL=https://thethings.example.com
# If interoperability configuration repository is a blob:
# - TTN_LW_AS_INTEROP_BLOB_PATH=/path/to/interop/directory
# - TTN_LW_AS_INTEROP_BLOB_BUCKET=enter bucket name
# If Gateway Server enabled, defaults for "thethings.example.com":
- TTN_LW_GS_MQTT_PUBLIC_ADDRESS=thethings.example.com:1882
- TTN_LW_GS_MQTT_PUBLIC_TLS_ADDRESS=thethings.example.com:8882
- TTN_LW_GS_MQTT_V2_PUBLIC_ADDRESS=thethings.example.com:1881
- TTN_LW_GS_MQTT_V2_PUBLIC_TLS_ADDRESS=thethings.example.com:8881
# If Gateway Configuration Server enabled, defaults for "thethings.example.com":
- TTN_LW_GCS_BASIC_STATION_DEFAULT_LNS_URI=wss://thethings.example.com:8887
- TTN_LW_GCS_THE_THINGS_GATEWAY_DEFAULT_MQTT_SERVER=mqtts://thethings.example.com:8881
# If Network Server enabled, Network Server interoperability configuration:
# - TTN_LW_NS_INTEROP_DIRECTORY=/path/to/interop/repository
# - TTN_LW_NS_INTEROP_URL=https://thethings.example.com
# - TTN_LW_NS_INTEROP_BLOB_PATH=/path/to/interop/directory
# - TTN_LW_NS_INTEROP_BLOB_BUCKET=enter bucket name
# Web UI configuration for "thethings.example.com":
- TTN_LW_IS_OAUTH_UI_CANONICAL_URL=https://thethings.example.com/oauth
- TTN_LW_IS_OAUTH_UI_IS_BASE_URL=https://thethings.example.com/api/v3
- TTN_LW_CONSOLE_OAUTH_AUTHORIZE_URL=https://thethings.example.com/oauth/authorize
- TTN_LW_CONSOLE_OAUTH_TOKEN_URL=https://thethings.example.com/oauth/token
- TTN_LW_CONSOLE_UI_CANONICAL_URL=https://thethings.example.com/console
- TTN_LW_CONSOLE_UI_IS_BASE_URL=https://thethings.example.com/api/v3
- TTN_LW_CONSOLE_UI_GS_BASE_URL=https://thethings.example.com/api/v3
- TTN_LW_CONSOLE_UI_NS_BASE_URL=https://thethings.example.com/api/v3
- TTN_LW_CONSOLE_UI_AS_BASE_URL=https://thethings.example.com/api/v3
- TTN_LW_CONSOLE_UI_JS_BASE_URL=https://thethings.example.com/api/v3
- TTN_LW_CONSOLE_UI_EDTC_BASE_URL=https://thethings.example.com/api/v3
- TTN_LW_CONSOLE_UI_QRG_BASE_URL=https://thethings.example.com/api/v3
# Console OAuth client and secret:
- TTN_LW_CONSOLE_OAUTH_CLIENT_ID=console
- TTN_LW_CONSOLE_OAUTH_CLIENT_SECRET=console # generate a good one (openssl rand -hex 32)
And the content of ttn-lw-stack.yml file:
# Example ttn-lw-stack configuration file
# Redis configuration
redis:
address: 'redis:6379'
# Identity Server configuration
is:
database-uri: 'postgres://root@cockroach:26257/ttn_lorawan?sslmode=disable'
email:
sender-name: 'The Things Stack'
sender-address: 'noreply@thethings.example.com'
network:
console-url: 'https://thethings.example.com/console'
identity-server-url: 'https://thethings.example.com/oauth'
oauth:
ui:
canonical-url: 'https://thethings.example.com/oauth'
is:
base-url: 'https://thethings.example.com/api/v3'
# HTTP server configuration
http:
cookie:
# generate 32 bytes (openssl rand -hex 32)
block-key: '0011223344556677001122334455667700112233445566770011223344556677'
# generate 64 bytes (openssl rand -hex 64)
hash-key: '00112233445566770011223344556677001122334455667700112233445566770011223344556677001122334455667700112233445566770011223344556677'
metrics:
password: 'password' # choose a password
pprof:
# Let's encrypt for "thethings.example.com"
tls:
source: 'acme'
acme:
dir: '/var/lib/acme'
email: 'you@thethings.example.com'
hosts: ['thethings.example.com']
default-host: 'thethings.example.com'
gs:
mqtt:
public-address: 'thethings.example.com:1882'
public-tls-address: 'thethings.example.com:8882'
mqtt-v2:
public-address: 'thethings.example.com:1881'
public-tls-address: 'thethings.example.com:8881'
gcs:
basic-station:
default:
lns-uri: 'wss://thethings.example.com:8887'
the-things-gateway:
default:
mqtt-server: 'mqtts://thethings.example.com:8881'
console:
ui:
canonical-url: 'https://thethings.example.com/console'
is:
gs:
ns:
as:
js:
qrg:
edtc:
oauth:
client-id: 'console'
client-secret: 'console' # choose or generate a secret (*)
Does anyone have an idea how to fix the issue ?
