I am right now looking for an solution to very slow TX_Interval problems.
Each time I sent the EV_TXSTART is fired I need to wait 270 sec(4min) until I get a EV_TXCOMPLETE.
My Code:
OTAA Example Code
In Setup I disabled linkCheckMode with LMIC_setLinkCheckMode(0);
Set MAX Clock Error with LMIC_setClockError(MAX_CLOCK_ERROR * 10 / 100);
Disable Confirmed Uplinks with LMIC_setTxData2(1, buffer, sizeof(buffer), 0
TX_INTERVAL = 30; (sec)
Reset Frame Counter in TTN Network done
Used mcci-catena/arduino-lmic Stack from Jan 2020
Used HW:
ESP32 with a 40 MHz XCO and proper ppm rate = TTGO T5
RFM95 Module
DIO00 connected to GPIO 34 of ESP32
DIO01 connected to GPIO 25 of ESP32
Enabled Pulldown on GPIO25 and GPIO34 with Command
pinMode(LORA_PIN_SPI_DIO, INPUT_PULLDOWN);
Joining works after some join requests
Identical HW on 2 nodes, happens on both
Pinning:
//Lora Pinning for TTGO T5 Addon Board
#define LORA_PIN_SPI_MOSI 15
#define LORA_PIN_SPI_MISO 2
#define LORA_PIN_SPI_SCK 14
#define LORA_PIN_SPI_NSS 26
#define LORA_PIN_SPI_RST 33
#define LORA_PIN_SPI_DIO 25
#define LORA_PIN_SPI_DIO0 34
and some modifications in the file hal.cpp LMIC to make this pinning accepted
static void hal_spi_init () {
//SPI.begin(lmic_pins.sck, lmic_pins.miso, lmic_pins.mosi, 0x00);
SPI.begin(14, 2, 15, 26);
Gateway Traffic:
I can not see any Downlink Gateway Traffic on my Gateway which requires a Wait for RX.
I can not see any Downlink Traffic on the TTN Application Console.
I installed a Single Channel Gateway (with a terrible Antenna) which only recieves packages from this node.
Same issue as well happens on other 3 Public professional RAK Gateways which are in sight and good recivable
My Issue:
In Serial log below you see at 21:12:20.312 a TX_START
After 2 Minutes I get RXTimeout at 21:14:19.960
After Another 2 Minutes I get another RXTimeout at 21:15:19.959
And finally at 21:16:19.965 I got a TX_Complete.
In total 4 minutes to sent a Message for 51ms Airtime
This is going on for every packet transmitted
**My Question is: **
Why does RXTimeout takes sooo long?
What causes the RXTimeout?
Why is there even a Recieving window if I do not enable ACK in txdata2?
How can I shorten or Disable RX Window
If I try out to Reieve Messages with the Uplink function they are never recieved…
If I use different nodes with similar ESP32 and similar RM95(different GPIOs used) modules an the
matthijskooijman/arduino-lmic it works like a charm and trasnmits within seconds
Serial Logs:
20:54:47.246 -> Starting
20:54:47.246 -> ** Stopping WiFi+BT
20:54:47.339 -> BME check: 1 BMP280 Temp Sensor found on I2C
20:54:47.339 -> BMP280 I2C: Temp = 23.37 *C Pressure = 975.61 hPa Approx altitude = 318.18 m
20:54:49.915 -> Display setup done
20:54:50.009 -> _PowerOn : 91001
20:54:53.938 -> _Update_Full : 3858001
20:54:54.172 -> _PowerOff : 232001
20:54:54.172 -> Basic E-Ink Display Update done -> No more E-Ink Display is Touched
20:54:54.172 -> RXMODE_RSSI
20:54:54.172 -> 562181: engineUpdate, opmode=0x8
20:54:54.172 -> Temp:23.37Packet queued
20:54:54.172 -> 562202: EV_JOINING
20:54:54.172 -> 562205: engineUpdate, opmode=0xc
20:54:55.813 -> 662454: engineUpdate, opmode=0xc
20:54:55.813 -> 662470: EV_TXSTART
20:54:55.813 -> 662535: TXMODE, freq=868100000, len=23, SF=8, BW=125, CR=4/5, IH=0
20:55:00.902 -> start single rx: now-rxtime: 3
20:55:00.902 -> 980748: RXMODE_SINGLE, freq=868100000, SF=8, BW=125, CR=4/5, IH=0
20:55:00.949 -> rxtimeout: entry: 984221 rxtime: 980742 entry-rxtime: 3479 now-entry: 3 rxtime-txend: 311126
20:55:01.886 -> start single rx: now-rxtime: 3
20:55:01.886 -> 1042998: RXMODE_SINGLE, freq=869525000, SF=12, BW=125, CR=4/5, IH=0
20:55:02.167 -> rxtimeout: entry: 1059399 rxtime: 1042992 entry-rxtime: 16407 now-entry: 3 rxtime-txend: 373376
20:55:02.167 -> 1059418: EV_JOIN_TXCOMPLETE: No JoinAccept
20:55:02.167 -> 1059467: engineUpdate, opmode=0xc
20:56:53.303 -> 8007806: engineUpdate, opmode=0xc
20:56:53.303 -> 8007820: EV_TXSTART
20:56:53.303 -> 8007884: TXMODE, freq=868300000, len=23, SF=8, BW=125, CR=4/5, IH=0
20:56:58.421 -> start single rx: now-rxtime: 3
20:56:58.421 -> 8326097: RXMODE_SINGLE, freq=868300000, SF=8, BW=125, CR=4/5, IH=0
20:56:58.466 -> rxtimeout: entry: 8329569 rxtime: 8326091 entry-rxtime: 3478 now-entry: 4 rxtime-txend: 311126
20:56:59.390 -> start single rx: now-rxtime: 3
20:56:59.390 -> 8388347: RXMODE_SINGLE, freq=869525000, SF=12, BW=125, CR=4/5, IH=0
20:56:59.702 -> rxtimeout: entry: 8404748 rxtime: 8388341 entry-rxtime: 16407 now-entry: 3 rxtime-txend: 373376
20:56:59.702 -> 8404767: EV_JOIN_TXCOMPLETE: No JoinAccept
20:56:59.702 -> 8404816: engineUpdate, opmode=0xc
20:58:59.570 -> 15899208: engineUpdate, opmode=0xc
20:58:59.570 -> 15899222: EV_TXSTART
20:58:59.570 -> 15899286: TXMODE, freq=868500000, len=23, SF=8, BW=125, CR=4/5, IH=0
20:59:04.669 -> start single rx: now-rxtime: 3
20:59:04.669 -> 16217498: RXMODE_SINGLE, freq=868500000, SF=8, BW=125, CR=4/5, IH=0
20:59:04.843 -> 16227370: EV_JOINED
20:59:04.843 -> netid: 19
20:59:04.843 -> devaddr: XXXXX
20:59:04.843 -> AppSKey: XXXXXX
20:59:04.843 -> NwkSKey: XXXXXXX
20:59:04.843 -> 16227580: engineUpdate, opmode=0x808
20:59:04.843 -> 16227797: EV_TXSTART
20:59:04.843 -> 16227957: TXMODE, freq=867500000, len=15, SF=8, BW=125, CR=4/5, IH=0
21:00:19.963 -> start single rx: now-rxtime: 3687927
21:00:19.963 -> 20922061: RXMODE_SINGLE, freq=867500000, SF=8, BW=125, CR=4/5, IH=0
21:00:49.939 -> rxtimeout: entry: 22797069 rxtime: 17234130 entry-rxtime: 5562939 now-entry: 3 rxtime-txend: 62126
21:01:49.942 -> start single rx: now-rxtime: 9250739
21:01:49.942 -> 26547122: RXMODE_SINGLE, freq=869525000, SF=9, BW=125, CR=4/5, IH=0
21:02:19.942 -> rxtimeout: entry: 28422131 rxtime: 17296380 entry-rxtime: 11125751 now-entry: 4 rxtime-txend: 124376
21:02:49.954 -> 30297136: EV_TXCOMPLETE (includes waiting for RX windows)
21:02:49.954 -> 30297140: engineUpdate, opmode=0x900
21:03:20.046 -> _PowerOn : 91001
21:03:20.352 -> _Update_Part : 292001
21:03:20.385 -> next_time:544728
21:03:20.385 -> BMP280 I2C: Temp = 23.36 *C Druck = 975.55 hPa Approx altitude = 318.71 m
21:03:20.385 -> 32199447: engineUpdate, opmode=0x908
21:03:20.385 -> 32199474: EV_TXSTART
21:03:20.385 -> 32199534: TXMODE, freq=867700000, len=15, SF=8, BW=125, CR=4/5, IH=0
21:03:20.385 -> Temp:23.36Packet queued
21:04:49.930 -> start single rx: now-rxtime: 3687926
21:04:49.930 -> 37796623: RXMODE_SINGLE, freq=867700000, SF=8, BW=125, CR=4/5, IH=0
21:05:19.949 -> rxtimeout: entry: 39671631 rxtime: 34108693 entry-rxtime: 5562938 now-entry: 4 rxtime-txend: 62126
21:06:19.945 -> start single rx: now-rxtime: 9250738
21:06:19.945 -> 43421685: RXMODE_SINGLE, freq=869525000, SF=9, BW=125, CR=4/5, IH=0
21:06:49.961 -> rxtimeout: entry: 45296693 rxtime: 34170943 entry-rxtime: 11125750 now-entry: 4 rxtime-txend: 124376
21:07:19.956 -> 47171694: EV_TXCOMPLETE (includes waiting for RX windows)
21:07:19.956 -> 47171697: engineUpdate, opmode=0x900
21:07:50.273 -> _Update_Part : 292001
21:07:50.305 -> next_time:814728
21:07:50.305 -> BMP280 I2C: Temp = 23.21 *C Druck = 975.49 hPa Approx altitude = 319.24 m
21:07:50.305 -> 49068254: engineUpdate, opmode=0x908
21:07:50.305 -> 49068280: EV_TXSTART
21:07:50.305 -> 49068341: TXMODE, freq=867900000, len=15, SF=8, BW=125, CR=4/5, IH=0
21:07:50.305 -> Temp:23.21Packet queued
21:09:19.954 -> start single rx: now-rxtime: 3687927
21:09:19.954 -> 54671686: RXMODE_SINGLE, freq=867900000, SF=8, BW=125, CR=4/5, IH=0
21:09:49.960 -> rxtimeout: entry: 56546693 rxtime: 50983755 entry-rxtime: 5562938 now-entry: 4 rxtime-txend: 62126
21:10:49.952 -> start single rx: now-rxtime: 9250738
21:10:49.952 -> 60296747: RXMODE_SINGLE, freq=869525000, SF=9, BW=125, CR=4/5, IH=0
21:11:19.948 -> rxtimeout: entry: 62171755 rxtime: 51046005 entry-rxtime: 11125750 now-entry: 4 rxtime-txend: 124376
21:11:49.968 -> 64046756: EV_TXCOMPLETE (includes waiting for RX windows)
21:11:49.968 -> 64046759: engineUpdate, opmode=0x900
21:12:20.276 -> _Update_Part : 292001
21:12:20.312 -> next_time:1084728
21:12:20.312 -> BMP280 I2C: Temp = 23.14 *C Druck = 975.43 hPa Approx altitude = 319.75 m
21:12:20.312 -> 65943316: engineUpdate, opmode=0x908
21:12:20.312 -> 65943343: EV_TXSTART
21:12:20.312 -> 65943403: TXMODE, freq=868100000, len=15, SF=8, BW=125, CR=4/5, IH=0
21:12:20.312 -> Temp:23.14Packet queued
21:13:49.967 -> start single rx: now-rxtime: 3687927
21:13:49.967 -> 71546748: RXMODE_SINGLE, freq=868100000, SF=8, BW=125, CR=4/5, IH=0
21:14:19.960 -> rxtimeout: entry: 73421755 rxtime: 67858817 entry-rxtime: 5562938 now-entry: 4 rxtime-txend: 62126
21:15:19.959 -> start single rx: now-rxtime: 9250738
21:15:19.959 -> 77171809: RXMODE_SINGLE, freq=869525000, SF=9, BW=125, CR=4/5, IH=0
21:15:49.968 -> rxtimeout: entry: 79046817 rxtime: 67921067 entry-rxtime: 11125750 now-entry: 4 rxtime-txend: 124376
21:16:19.965 -> 80921818: EV_TXCOMPLETE (includes waiting for RX windows)
21:16:19.965 -> 80921821: engineUpdate, opmode=0x900
21:16:50.287 -> _Update_Part : 292001
21:16:50.321 -> next_time:1354728
21:16:50.321 -> BMP280 I2C: Temp = 23.05 *C Druck = 975.35 hPa Approx altitude = 320.42 m
21:16:50.321 -> 82818378: engineUpdate, opmode=0x908
21:16:50.321 -> 82818404: EV_TXSTART
21:16:50.321 -> 82818465: TXMODE, freq=868300000, len=15, SF=8, BW=125, CR=4/5, IH=0
21:16:50.321 -> Temp:23.05Packet queued
TTN Console
Public Gateway:
"time": "2020-01-16T20:03:28.232177553Z",
"frequency": 867.7,
"modulation": "LORA",
"data_rate": "SF8BW125",
"coding_rate": "4/5",
"gateways": [
"gtw_id": "eui-7276ff000b0325b8",
"timestamp": 237909852,
"time": "",
"channel": 3,
"rssi": -123,
"snr": -10.2,
"latitude": xxx,
"longitude": xxx,
"location_source": "registry"
"gtw_id": "eui-7276ff000b031dec",
"timestamp": 776810852,
"time": "",
"channel": 3,
"rssi": -121,
"snr": -6.8,
"latitude": xxx,
"longitude": xxx,
"gtw_id": "eui-7276ff000b031f26",
"timestamp": 127337836,
"time": "",
"channel": 3,
"rssi": -120,
"snr": -1.8,
"latitude": xxxx,
"longitude":xxx,
"latitude": 48.76929,
"longitude": 8.935963,
"altitude": 440,
Another Packet with good SNR
"time": "2020-01-16T19:59:12.220644021Z",
"frequency": 867.5,
"gateways": [
"timestamp": 4277333764,
"time": "",
"channel": 2,
"rssi": -121,
"snr": -8.2,
"latitude": xxxx,
"longitude": XXXX,
"timestamp": 4166761740,
"time": "",
"channel": 2,
"rssi": -117,
"snr": 0.8,
"latitude": XXXXX,
"longitude": XXXX,
"latitude": XXX,
"longitude": XXXX,
"altitude": 440,
Single Channel Gateway:
"time": "2020-01-16T20:16:57.762160282Z",
"frequency": 868.3,
"gateways": [
"gtw_id": "eui-d8a01dffff63473c",
"timestamp": 1124468549,
"time": "",
"channel": 0,
"rssi": -31,
"snr": 11,
"latitude": xxx
"longitude": xxxx
"altitude": 440
"latitude": xxx
"longitude": xxx
"altitude": 440,
