ESP32, rfm95w, deep sleep. How to save and restore OTAA Session?
Hi
Im trying to get my device to not do an OTAA join every time it wakes up from deep sleep. Im aware there is some topics in the forum on the same subject but I find it difficult to understand how I can implement this feature.
im using this library in my code (version 5.0.1)
My hardware is:
ESP32-C3
RFM95W
BMP280
If anyone has any tips or suggestions on how I can implement this in the code, I would really appreciate it.
This is my code so far without saving and restoring OTAA:
#include <lmic.h>
#include <hal/hal.h>
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_BMP280.h>
#include <esp_sleep.h>  // Inkluder for deep sleep
Adafruit_BMP280 bmp; // Oppretter sensorobjekt
RTC_DATA_ATTR float lastTemperature = -1000.0;
RTC_DATA_ATTR float lastPressure = -1000.0;
RTC_DATA_ATTR float tempThreshold = 0.1;
RTC_DATA_ATTR float pressureThreshold = 1.0;
static osjob_t sendjob;
const unsigned TX_INTERVAL = 60; // 60 sekunder
// Pin mapping
    .nss = 7,
    .rxtx = LMIC_UNUSED_PIN,
    .rst = 3,
    .dio = {2, 21, LMIC_UNUSED_PIN},
static const u1_t PROGMEM APPEUI[8] = {  };
void os_getArtEui (u1_t* buf) { memcpy_P(buf, APPEUI, 8); }
static const u1_t PROGMEM DEVEUI[8] = {  };
void os_getDevEui (u1_t* buf) { memcpy_P(buf, DEVEUI, 8); }
static const u1_t PROGMEM APPKEY[16] = {  };
void os_getDevKey (u1_t* buf) {  memcpy_P(buf, APPKEY, 16); }
void printHex2(unsigned v) {
    v &= 0xff;
    if (v < 16)
        Serial.print('0');
    Serial.print(v, HEX);
void onEvent (ev_t ev) {
    Serial.print(os_getTime());
    Serial.print(": ");
    switch(ev) {
        case EV_SCAN_TIMEOUT:
            break;
        case EV_BEACON_FOUND:
            break;
        case EV_BEACON_MISSED:
            break;
        case EV_BEACON_TRACKED:
            break;
        case EV_JOINING:
            break;
        case EV_JOINED:
              u4_t netid = 0;
              devaddr_t devaddr = 0;
              u1_t nwkKey[16];
              u1_t artKey[16];
              Serial.print("netid: ");
              Serial.println(netid, DEC);
              Serial.print("devaddr: ");
              Serial.println(devaddr, HEX);
              Serial.print("AppSKey: ");
              for (size_t i=0; i<sizeof(artKey); ++i) {
                if (i != 0)
                  Serial.print("-");
                printHex2(artKey[i]);
              Serial.println("");
              Serial.print("NwkSKey: ");
              for (size_t i=0; i<sizeof(nwkKey); ++i) {
                      if (i != 0)
                              Serial.print("-");
                      printHex2(nwkKey[i]);
              Serial.println();
            LMIC_setLinkCheckMode(0);
            break;
        case EV_JOIN_FAILED:
            break;
        case EV_REJOIN_FAILED:
            break;
        case EV_TXCOMPLETE:
            Serial.print(F("LMIC.txrxFlags: "));
            Serial.println(LMIC.txrxFlags, HEX);
            Serial.print(F("LMIC.dataLen: "));
            Serial.println(LMIC.dataLen);
            if (LMIC.dataLen) {
              Serial.print(F("Received "));
              Serial.print(LMIC.dataLen);
              // Print the received payload
              Serial.print(F("Payload: "));
              for (int i = 0; i < LMIC.dataLen; i++) {
                  Serial.print(LMIC.frame[LMIC.dataBeg + i], HEX);
                  Serial.print(" ");
              Serial.println();
              // Oppdater terskelverdier fra downlink payload
              if (LMIC.dataLen == 4) {
                  int16_t newTempThreshold = (LMIC.frame[LMIC.dataBeg] << 8) | LMIC.frame[LMIC.dataBeg + 1];
                  int16_t newPressureThreshold = (LMIC.frame[LMIC.dataBeg + 2] << 8) | LMIC.frame[LMIC.dataBeg + 3];
                  tempThreshold = newTempThreshold / 100.0;
                  pressureThreshold = newPressureThreshold / 10.0;
                  Serial.print(F("New tempThreshold: "));
                  Serial.println(tempThreshold);
                  Serial.print(F("New pressureThreshold: "));
                  Serial.println(pressureThreshold);
              } else {
                  Serial.println(F("Downlink payload length is not 4 bytes"));
            } else {
                Serial.println(F("No downlink payload received"));
            Serial.println(F("Going to deep sleep..."));
            esp_sleep_enable_timer_wakeup(TX_INTERVAL * 1000000ULL); // Vekk etter TX_INTERVAL sekunder
            esp_deep_sleep_start();
            break;
        case EV_LOST_TSYNC:
            break;
        case EV_RESET:
            break;
        case EV_RXCOMPLETE:
            // data received in ping slot
            break;
        case EV_LINK_DEAD:
            break;
        case EV_LINK_ALIVE:
            break;
        case EV_TXSTART:
            break;
        case EV_TXCANCELED:
            Serial.println(F("EV_TXCANCELED"));
            break;
        case EV_RXSTART:
            /* do not print anything -- it wrecks timing */
            break;
        case EV_JOIN_TXCOMPLETE:
            Serial.println(F("EV_JOIN_TXCOMPLETE: no JoinAccept"));
            break;
        default:
            break;
void do_send(osjob_t* j){
    Serial.println(F("do_send called"));
    } else {
        // Les temperatur og trykk fra BMP280
        float temperature = bmp.readTemperature();
        float pressure = bmp.readPressure() / 100.0;
        // Skriv temperatur og trykk til serial porten
        Serial.print("Temp: "); Serial.print(temperature); Serial.print(" C, ");
        Serial.print("Pressure: "); Serial.print(pressure); Serial.println(" hPa");
        // Sjekk om terskelverdiene er oppfylt
        if (abs(temperature - lastTemperature) >= tempThreshold || abs(pressure - lastPressure) >= pressureThreshold) {
            // Oppdater siste verdier
            lastTemperature = temperature;
            lastPressure = pressure;
            // Forbered data for sending
            uint8_t payload[4];
            int16_t tempInt = (int16_t)(temperature * 100);
            int16_t pressInt = (int16_t)(pressure * 10);
            payload[0] = (tempInt >> 8) & 0xFF;
            payload[1] = tempInt & 0xFF;
            payload[2] = (pressInt >> 8) & 0xFF;
            payload[3] = pressInt & 0xFF;
            // Send data on port 1
            LMIC_setTxData2(1, payload, sizeof(payload), 0);
        } else {
            Serial.println(F("No significant change in temperature or pressure"));
            // 🔴 Deep sleep selv om det ikke sendes noe
            Serial.println(F("Skipping transmission, going to deep sleep..."));
void setup() {
    Serial.begin(9600);
    if (!bmp.begin(0x76)) {
        Serial.println(F("Could not find BMP280 sensor!"));
    // LMIC init
    os_init();
    LMIC_reset();
    // Enable ADR
    LMIC_setAdrMode(1);
    // Juster RX-vinduene
    //LMIC_setClockError(MAX_CLOCK_ERROR * 10 / 100); // 10% clock error
    // Sett data rate for RX2-vinduet
    //LMIC.dn2Dr = DR_SF9;
    do_send(&sendjob);
void loop() {
    //Serial.println(F("LOOP"));
    os_runloop_once();
This problem is fully solved with a full solution provided in RadioLib - search forum / GitHub / internet for details
Thank you! I will try it out :slight_smile:
