I’m trying to design a PCB with an ESP32 and a RFM95w (and of course a few other stuff). Unfortunately I found no Linear converter which can deliver up to 500mA (which are needed when the ESP does wifi stuff) and has a low quiescence current.
Did anyone of you build a ESP32 Lora board which is driven by a LiPo Cell and can recommend a good linear converter (low dropout)?
Most electronic distributors will have a parameter search capability, so assuming you have decided on the dropout voltage you require, and you know the current handling capability (500mA min) then you can get a list of regulators that you can check the datasheets for your required quiescent current.
I’m using the ME6211C33M5G-N SOT-23 for a basic ESP32 PCB board and Lora via a CLICK board. The ME6210A33PG SOT-89 is the 2nd choice (easier to solder, but haven’t used them yet).
Thanks this was exactly what I was looking for!
I created a KiCAD symbol and later this week I will order my first prototype.
4ct per unit is absolutely cheap compared to similar products by Texas Instruments.
For OTA firmware updates and configuration via a Web Interface.
I also want to implement Bluetooth Low Energy.
