We want to test our Gateways range with Adeunis Field Tester. The Gateway receives the Field Tester Uplink message but at the same time shows the following error in the Live data console.
Does anyone know why our Gateway Live data console shows this error? Thank you so much.
Go on @kschiffer, do explain how do we generate a console log line that is just an error message …
It is very intermittent so you’re going to have to run with how long before someone sees it again, or not. So if no one reports it in the next month, then like Schrodingers Cat, it is half-fixed.
