netmonk
(Netmonk)
October 13, 2019, 5:22pm
1
I just came back home on switched on my lora ttnmapper.
It cannot join anymore using my home gateway.
Restarted the GW, everything seems fine in the log. But i cannot see any traffic from the gateway console data section in TTN.
I used to have LORIOT and Bouygues PAcket from it, appearing in the console. every minutes, but nothing anymore. My join attempt with my regular ttn-mapper isnt appearing too, and join is in wait state on my node.
My gw is connected to : router.eu.thethings.network
Is there any issue in the TTN backoffice currently ?
netmonk
(Netmonk)
October 13, 2019, 5:31pm
2
Status is “connected”
last seen 36 minutes ago.
netmonk
(Netmonk)
October 13, 2019, 5:51pm
3
Oct 13 19:49:45 rak-gateway ttn-gateway[551]: INFO: Received pkt from mote: D0021F03 (fcnt=46037)
Oct 13 19:49:45 rak-gateway ttn-gateway[551]: JSON up: {"rxpk":[{"tmst":688454620,"time":"2019-10-01T01:48:38.767117Z","tmms":1255024138767,"chan":1,"rfch":1,"freq":868.300000,"stat":1,"modu":"LORA","datr":"SF9BW125","codr":"4/5","lsnr":12.5,"rssi":-23,"size":23,"data":"AAMfAtB+1bNwPRo2/uwYrwC9mZeuxZQ="}]}
Oct 13 19:49:45 rak-gateway ttn-gateway[551]: INFO: [up] PUSH_ACK received in 22 ms
Oct 13 19:49:45 rak-gateway ttn-gateway[551]: INFO: [down] PULL_ACK received in 21 ms
Oct 13 19:49:45 rak-gateway ttn-gateway[551]: ##### 2019-10-13 17:48:44 GMT #####
Oct 13 19:49:45 rak-gateway ttn-gateway[551]: ### [UPSTREAM] ###
Oct 13 19:49:45 rak-gateway ttn-gateway[551]: # RF packets received by concentrator: 1
Oct 13 19:49:45 rak-gateway ttn-gateway[551]: # CRC_OK: 100.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Oct 13 19:49:45 rak-gateway ttn-gateway[551]: # RF packets forwarded: 1 (23 bytes)
Oct 13 19:49:45 rak-gateway ttn-gateway[551]: # PUSH_DATA datagrams sent: 2 (419 bytes)
Oct 13 19:49:45 rak-gateway ttn-gateway[551]: # PUSH_DATA acknowledged: 100.00%
Oct 13 19:49:45 rak-gateway ttn-gateway[551]: ### [DOWNSTREAM] ###
Oct 13 19:49:45 rak-gateway ttn-gateway[551]: # PULL_DATA sent: 3 (100.00% acknowledged)
Oct 13 19:49:45 rak-gateway ttn-gateway[551]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Oct 13 19:49:45 rak-gateway ttn-gateway[551]: # RF packets sent to concentrator: 0 (0 bytes)
Oct 13 19:49:45 rak-gateway ttn-gateway[551]: # TX errors: 0
Oct 13 19:49:45 rak-gateway ttn-gateway[551]: # BEACON queued: 0
Oct 13 19:49:45 rak-gateway ttn-gateway[551]: # BEACON sent so far: 0
Oct 13 19:49:45 rak-gateway ttn-gateway[551]: # BEACON rejected: 0
Oct 13 19:49:45 rak-gateway ttn-gateway[551]: ### [JIT] ###
Oct 13 19:49:45 rak-gateway ttn-gateway[551]: # SX1301 time (PPS): 691687503
Oct 13 19:49:45 rak-gateway ttn-gateway[551]: src/jitqueue.c:448:jit_print_queue(): INFO: [jit] queue is empty
Oct 13 19:49:45 rak-gateway ttn-gateway[551]: ### [GPS] ###
Oct 13 19:49:45 rak-gateway ttn-gateway[551]: # Valid time reference (age: 0 sec)
Oct 13 19:49:45 rak-gateway ttn-gateway[551]: # no valid GPS coordinates available yet
Oct 13 19:49:45 rak-gateway ttn-gateway[551]: ##### END #####
But packet doesnt appear in the console.
netmonk
(Netmonk)
October 13, 2019, 6:04pm
4
Ok everything seems to be back to normal, i see traffic again in the console. More than 50 minutes of white page data in the console.
