I made a mistake in transfering the ownership of one of our Gateway : I put “Makerspace” instead of “MakerSpace56”…
So now, I can’t modify the parameter to have the ownership back…
Is there a solution ?
Thierry
I don’t think that will be very easy.
Best to contact someone from TTI monday (mail / slack)
how about quickly create another account called makerspace (before someone else does!) and then use that account to hand back? Not sure if that works but worth a try…
If it already exists contact current Makerspace user and ask then to transfer back?
Just a thought…good luck
Hello, do you have a contact? I can’t find any in the non professional part.
Thierry
I’m not sure but you can try a PM to @htdvisser
Thanks a lot.
