I am using Node-red to listen the data form The things stack (LoRa) with MQTT node and then save the data to SQL and showing it on Dashboard.
The integration works fine but every night node red stops running with the error “Disconnected from broker”. The Node-red log is below. I have already set the log level to trace
to get detailed logs.
4 Dec 00:00:44 - [trace] Stopped node ui_group:820f6eb8cfb19b5f (2217ms)
4 Dec 00:00:44 - [trace] Stopped node file:acd436a6.915b58 (11167ms)
4 Dec 00:00:44 - [trace] Stopped node file:c81b1fa38ca9a1a9 (9780ms)
4 Dec 00:00:44 - [trace] Stopped node persist out:920af82a52d974fe (8162ms)
4 Dec 00:00:44 - [trace] Stopped node persist out:208943d6ca80d596 (8077ms)
4 Dec 00:00:44 - [trace] Stopped node persist out:d864d3592b0a402d (8042ms)
4 Dec 00:00:44 - [trace] Stopped node file:c68e384ebbf990ca (7684ms)
4 Dec 00:00:44 - [trace] Stopped node persist-store:fc55cc01139f2355 (2270ms)
4 Dec 00:00:44 - [trace] Stopped node persist-store:44000ea4a5a8e0cc (2190ms)
4 Dec 00:00:44 - [trace] Stopped node persist-store:5783905d29c6d349 (2188ms)
4 Dec 00:00:45 - [trace] Stopped node MySQLdatabase:8d9e671a.fe43f8 (4813ms)
4 Dec 00:00:46 - [info] [mqtt-broker:pce-rs485-ln] Disconnected from broker: mqtts://thethings.pce-service.net:8883
4 Dec 00:00:46 - [trace] Stopped node mqtt-broker:5a4affde40f9961b (4883ms)
4 Dec 00:00:46 - [info] [mqtt-broker:pce-lht65] Disconnected from broker: mqtts://thethings.pce-service.net:8883
4 Dec 00:00:46 - [trace] Stopped node mqtt-broker:331ab51.7038a4a (4848ms)
4 Dec 00:00:46 - [info] [mqtt-broker:pce-df703] Disconnected from broker: mqtts://thethings.pce-service.net:8883
4 Dec 00:00:46 - [trace] Stopped node mqtt-broker:4ecf1b4c38c80bc6 (5076ms)
4 Dec 00:00:47 - [error] [mqtt in:pce-lht65] Error stopping node: Close timed out
4 Dec 00:00:47 - [debug] undefined
4 Dec 00:00:49 - [error] [mqtt in:pce-df703] Error stopping node: Close timed out
4 Dec 00:00:49 - [debug] undefined
4 Dec 00:00:50 - [error] [mqtt in:pce-rs485-ln] Error stopping node: Close timed out
4 Dec 00:00:50 - [debug] undefined
4 Dec 00:00:50 - [info] Stopped flows
Stopped Node-RED graphical event wiring tool.
I am not able to figure out what is the issue here. Why it is keep happening ever night between midnight and 1 O’clock?
Additional Info:
- The Things stack and Node-red are running on the same remote server Ubantu 18.04
- Node-RED version: v2.0.6
- Node.js version: v12.22.7
