I’m looking for some advice / recommendations for enterprise grade hardware for work. A hundred temp sensors for shipping containers and a dual (for redundancy) base station gateway set up in the 923MHz range pumping data to Azure. I don’t want the most expensive on the market but I do want a robust setup that requires minimal maintenance and will happily serve us for years. Ideally readily available kit in NZ.
All thoughts and ideas most welcome, especially around kit that you have hands on experience with.
Thanks, Pete
