Hi. When programming my end node, there is no connection taking place or activity registered on the application end devices, although the device is within range to the gateway (same room).
When I use the same code, and same (physical) board, and I use the deveui and appkey for end_device_01, it works perfectly, eliminating the possibility of a hardware or software problem. However, when I just change the deveui and appkey to that for end_device_05, it does not work at all. Why could this be?
end_device_05 has worked before, but it doesnt anymore (last activity February 22, 2023, if that is relevant).
I have reset the MAC state and generated a new appkey, but the problem still persists.
Please let me know if there is any advice. Thanks.
