I want to send to TTN the GPS coordinates provided by an Arduino Mega with the Dragino GPS/LORA shield.
In order to encode the GPS coordinates, I use the GitHub - thesolarnomad/lora-serialization: LoraWAN serialization/deserialization library for The Things Network library =>
byte buffer[8];
LoraEncoder encoder(buffer);
void do_send(osjob_t* j){
else
if (checkGpsFix()) {
buildPacket(txBuffer);
encoder.writeLatLng(gps.location.lat(), gps.location.lng());
LMIC_setTxData2(1, buffer, sizeof(buffer), 0);
The code of encoder.writeLatLng is the following (I took a look at the code of the library) =>
void LoraEncoder::writeLatLng(double latitude, double longitude) {
int32_t lat = latitude * 1e6;
int32_t lng = longitude * 1e6;
_intToBytes(_buffer, lat, 4);
_intToBytes(_buffer + 4, lng, 4);
_buffer += 8;
The problem is as follows :
On the Arduino side, the Lat, Long (as provided by the TinyGPS++ library - functions gps.location.lat() and gps.location.lng()) are =>
Lat=48.576763 Long=1.941792
On the TTN side, the Lat, Long are =>
"decoded_payload": {
"decoded": [
48.576628,
1.941793
The decoder is as follows =>
// js code copied from https://github.com/thesolarnomad/lora-serialization/blob/master/src/decoder.js
var decoded = {};
decoded = latLng(input.bytes.slice(0, 8))
return {
data: {decoded},
warnings: [],
errors: []
So why such a difference between the latitude from the Arduino side and from the TTN side ? The serialization/deserialization of the coordinates (latitude/longitude) is however realized with a precision of 6 decimals (see code above) ?
