Hi All,
I’ve inherited a few spare Elsys ELT-2-HP nodes and thought I would have a play around with them.
However I found at least for the first one, I am having issues with the stability of the node.
Probably due to them running quite OLD firmware 2.2.4, this version doesn’t support half the sensors etc I wouldn’t mind trying.
Little back story of troubleshooting too, for anyone interested with the devices on old firmware. I thought it would be good to post this as there hasn’t been much talk about this brand in terms of support (at least in the case of TTNv3/TTS)
I’ve got the device setup on TTNv3 Public, currently set as AU915 SB2 on the endpoint, and AU915 “Hybrid” on the device with subband 2 (aka 1 on the device is 8-15), AU915 normal mode doesn’t appear to work - not sure what the point of the different between these two settings?
When set to OTAA mode I get:
- A constant Join Loop, where every 20 seconds or so it will loop over and over, never gets to transmit any sensor data and frames up never changes.
When switched to ABP as a test:
a) I do get data as expected (as they are not joining - so good troubleshooting step to see a change) - but delayed to the 15minutes after booting ( i just get a diagnostic/fPort 6 payload at first, then followed by good onboard data after 15minutes has elapsed).
b) ADR doesn’t appear to work, no matter what settings are placed for Data Rate min and max values on the device it just always stays at the “default” value - mostly SF12, unless I force it to stick to one other than this like SF9/SF10, I was under the impression ADR is still supposed to work with ABP devices? (this is the first time using ABP and I typically have used OTAA so I am unsure).
c) LoRa Confirmed bug - with it set OFF or ON, the node receives equal Downlinks to match its uplink no matter what - so this doesn’t seem right.
c) Worked for about 97x uplinks (set on every 15 minutes as a test) then just stopped, battery is healthy and brand new @ 3.64volts, node never moved from where I placed it.
Plan is to firmware update to get around the ABP issues and/or at least switch back to OTAA
I have seen other ELT-2-HP devices I worked with that had newer firmware - so worked without issues.
I am wondering if anyone has a tutorial for Firmware Update that doesn’t involve Elsys proprietary “USB Stick” thing - their online store doesn’t accept PayPal and shipping from them and other vendors such as the UK has an $80 AUD postage to Australia for something worth $30 at most that I will use exactly once to firmware update the device, so any suggestions would be handy.
Or does anyone have a Elsys USB firmware update stick I can borrow
Regards
Toby
