Hi all,
I’m having packet loss issues with an installation of 20 Elsys sensors (ERS CO2, Sound, Desk and EMS Desk) in the US_902_928 region.
I have a single Multitech Conduit MTCAP-915-041A located in an adjacent building approx 60m from devices.
I have two IM buildings break beam people counters in the same install that are rock solid, so I must have configured something incorrectly in the Elsys phone app when programming the devices.
I’ve configured the Elsys sensors to use OTAA with ADR, with DR0 min (SF10 125), DR1 default (SF9 125) and DR4 max (SF8 500)(https://www.thethingsnetwork.org/docs/lorawan/regional-parameters/ US902-928 Data Rates)
In the Elsys app, the frequency plan I selected is the vanilla US915 and I have left the sub-band as ‘Band0 Ch:0-7’. The notes in the app for sub-band say 'only in combination with hybrid mode, i.e. US915 hybrid, which I have NOT selected.
For the packets that do get through, I’m seeing RSSI values above -100 and SNR values above 0. Most sensors are sitting at SF7.
One thing I have set that may be unusual is link period to 8 and link threshold to 2. I was advised by a supplier in the UK to to do this. I would appreciate feedback on whether this is generally necessary or not.
It’s clear from monitoring the f_cnt that all the Elsys sensors are regularly rebooting to try and re-join (assuming a function of the link period setting)
Reading the link below, I note reference to sub-band-2. Does this mean I should be using the Elsys app setting 'US915 hybrid and ‘Band2 Ch:16-23’? https://www.thethingsindustries.com/docs/reference/frequency-plans/
I’ve included two screenshots of my settings from the Elsys app below for reference.
I will try the hybrid and sub-band-2 setting when I can next access the sensors.
Any advice would be appreciated.
