i got some Ebyte E78-868LN22S SW Version 4.0, the datasheet seems to be older than the firmware…
I tried to set it up in a german lorawan so 868MHz, in both methods OTAA / ABP. Nothing to see in my console for the device nor the gateway. the module doesn’t even draw more current when I await it to connect to gateway. I’ver the break out board USB version as well as the single chip with DIY breakout, same behviour.
So may question is, anybody had a successfull join and datatransfer with those modules?
In addition i’ve a CDEBYTE E78-DTU(900LN22) which is working just fine.
Any suggestions anyone? Looking forward for some support, thanks in advance!!
About two years ago I was successful with some E78 868LN22S modules in OTAA and ABP modes
I live in France (868MHz) , my TTIG gateway is in the attic
Modules came from EBYTE/CDEBYTE chop on Aliexpress
No firmware changed for the inside ASR6501 chip
As I look to log notes I see that :
Device used LoRaWAN version 1.0.2, Regional Parameters 1.0.2 rev B
AT+CGMM? reported E78-900M22S (but E7868LN22S seen on module’s metal lid)
AT+CGMR? reported SF V1.0
I have the USB breakouts with Firmware 4.0 which does Not Work. I got two stamps / barr Chips with FW 3.0 those Work. Furthermore i tested a DTU 78 steal cased device, using also an E78 868 ln 22s with a Special DTU Firmware in Alpha state, working properly also.
For gateway i am using a sensecap.
I requested some Firmware Infos at Ebyte, WE will See how their Support will react…
Please format the log output with the </> - it makes it much easier to read.
As you’re able to get the serial output, perhaps consider showing us what actually happens which is the heart of the matter - show us the serial output of a join attempt.
that sounds quite promising. I got following parameters:
+CGMI=Ebyte
OK
+CGMM=E78-868LN22S
OK
+CGMR=v4.0
OK
So exactly the same, are there any other parameters you nedeed to set? Are you using it on an own PCB or on the preconfigurated USB Testboard?
Which device settings are you using in the TTN Console?
@descartes: sorry missed your answer, there is no further serial output:
AT+CJOIN=1,0,10,8
gives me (after some time) a:
OK
+CJOIN:FAIL
is there any hint getting more detailed information from the device?
can’t find any reaction in the console of gateway or device…
In general I tested my gateway with several EByte devices as descripted above, even the chip familiy with FW Version 3 is working, I can’t catch the point what’s wrong here,.Even I’ve two identical USB Boards assembled by Ebyte and sourced from their webshop, so I don’t think they are faked or whatever…
Not from me. I use eByte SX126x modules occasionally but I’m not a user of AT based modules.
Can you look on the gateway logs - the internal ‘what’s just happened’ bit - to see if anything is being heard by the gateway, even if it’s not passing the CRC check.
An OK join request that’s heard by the gateway would appear in the gateway console on TTN. So that’s the first step to solve. Maybe an antenna issue. Maybe the firmware is borked - can you downgrade to v3.
If got standalone module and usb-testboard - both working.
Modules are configured as described in manual from Ebyte.
AT+CAPPEUI=<you’re key>
AT+CDEVEUI=<you’re key>
AT+CAPPKEY=<you’re key>
AT+CCONFIRM=0
AT+CCLASS=2
AT+CULDLMODE=2
AT+CSAVE
AT+IREBOOT=0
Have you maybe swapped CAPPEUI with CDEVEUI? (That was my first fault ;))
thanks for your advices, tried once more, no progress made, double checked the correct usage of the parameters with Ebytes “DTU-78” config tool, not 100% perfect for this devices but at least the join credentials appear in the correct boxes.
anything to set with those jumpers for VCC? What is about the stand by LED, @snatch any peripheral jumper wires used on the USB break out?
little bit lost, as the chip only solutions work as desired, the preassembled break out won’t…
I guess this is my last try, before i’ll try to resolder another chip onto the break out… See what’s happening then.
