Can anyone tell me what are the values: spreading factor, bandwidth, syncWord, error coding and other important ones that Ebyte’s E32 trx uses?
E32 (Ebyte) has a convenient user interface, but you cannot use it to define the above-mentioned parameters.
Thanks in advance for your support.
g.
The E32 is a UART front ended plain LoRa module with very limited configuration ability, as you have discovered and thus is not suited for TTN.
This is a support forum for TTN, so modules not for TTN use are not supported here.
